GC2300 frame flexing under certain conditions?
/ GC2300 frame flexing under certain conditions? #21
using them with bucket to lift front (watch rear tire movement when raising front, use bucket tilt to keep in place.. start with cut edge on ground) and a level on the frame helps set you up for hyd oil changes on GC series.
I don't think I would trust the ramps I have to hold up the rear of the tractor while I'm under it.
What are you using for ramps?
/ GC2300 frame flexing under certain conditions? #22
I would imagine if they're drive-up ramps like I got (plastic ones no less), they're for a car or a truck. If they're designed for that, why not a tractor?
/ GC2300 frame flexing under certain conditions? #23
16K lb ramps. I did damage one of them with torch slag so I don't let anything over 4K GVW (so 2k per axle) onto them. thery handle tractor fine, crown vic and ford escape fine, the 2011 silverado 2500 and 2020 dodge cummins 2500....yeah....emergency only.
LOL reminds me I meant to replace on payday (disabled vet) so....just ordered new set.
fwiw on tractor end used on GC2400, GC1710TLB, GC1723TLB, GC1725M TLB and MF 1532.
/ GC2300 frame flexing under certain conditions? #25
Ha! Well, easier not to do that on a tractor, you could just look down and see how far back on the ramp is the rear tire.
/ GC2300 frame flexing under certain conditions? #26
The ones I have a plastic, supposed to be good for 12K vehicle, so they are supposed to be good, but only for 9" tires. I'll have to test them out. I honestly never thought about using them on the rear to help with HST oil changes, but it would be nice to have more room to deal with getting the skid plate off and on. I will probably try this next spring, maybe put my jack stands under the frame, just in case.
/ GC2300 frame flexing under certain conditions? #27
.the backhoe frame mounts actually will not help with side-side flex really. there is no crossover between them.
The rear frame cross member is the entire transmission, and axle assembly.
The rear backhoe mounts are hardened steel. One of mine was off a little from day one. I had a heck of a time trying to bend it. And, I straighten frames for a living.
The way the front loader attaches to the frame is an excellent way to stabilize the frame. Obviously, the engineers thought that too.
It's a real nice set up. In all these years, I can't recall any complaints, or failures here.
/ GC2300 frame flexing under certain conditions? #28
I like to have the door, or the window open, and lean out to look at the ramp. At least your not flying completly bind.
It's not hard to drive past the stops, when they are not very high.
/ GC2300 frame flexing under certain conditions? #29
if box blade on then backhoe is off.
the torsional twist values (resistance/strength) would be the same between a backhoe and non backhoe GC series.
like you said, the transaxle (as well as the rear tow hitch) is the rear side to side crossmember(s) and they are the same transaxle and tow hitch plate for each series TLB or non TLB.
backhoe on then the pins and saddles add crossmember attributes due to hoe itself frame.
backhoe frame tractor side will prevent longitudal flex no matter if hoe on or off.
/ GC2300 frame flexing under certain conditions? #30
One has a substantial part of the frame doubled, plus the FEL mounts.
And, one is just a frame.
So, I'm not able to agree.
/ GC2300 frame flexing under certain conditions? #31
All frames allow for some flex same with unibodies. However on my dads farmall tractor the transmission and axle housings are the frame. Dont see how they can flex.
/ GC2300 frame flexing under certain conditions? #32
take 2 pieces of metal.
put a pencil between them to act as crossmember.
lift one side watch pencil snap.
use thicker metal on the sides (quadruple, whatever. it don;t matter) use that same pencil as crossmember.
pencil will still snap.
think about it.
I'm out.
we need tractorbynet mythbusters team :p
/ GC2300 frame flexing under certain conditions? #34
If you are working aggressively in the dirt with a SCUT, it absolutely can/will flex. As was said earlier, you can with some ease take a SCUT past it's limits and tweak things on them, most often the loader. I had a GC2400 for about 5 years and thought I put it to some pretty hard work, don't remember it flexing but doesn't mean it wouldn't. They are not indestructible.
My little Case SCUT was over loaded or used too hard (before I bought it) as the loader is slightly tweaked, not bad though.
They are equipped with a very torquey engine and powerful hydraulics systems, though the frame is usually equipped to match, they can be "over used".
One of the worst thing you can do is put them under heavy load on an angle.
/ GC2300 frame flexing under certain conditions? #35
Not sure if this is relevant, but a few years ago the bolt in the loader mount sheared, and the pin started walking out. No visible damage, but no idea why it happened. May be related to frame/loader flex.
/ GC2300 frame flexing under certain conditions? #36
think about it.
I'm out.
Yes, but you are over simplifying the forces that are applied to the frame when these guys are using it.
It's not ever a simple one side stays in place, while the other side is moved up or down shearing force,
Because of the rear end housing, and the crossmembers, which transfer the forces to the other rail, it's a twisting force.
The whole frame has to be able to resist it, not just the crossmembers. Flex the rails enough at their weakest point, and you will have a failure. That's exactly why the TLB frame is beefed up, and not the cross members. The weakest point is the side rails.
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2021 John Deere Z960M Zero Turn (A63116)
2021 John Deere...
UNUSED KJ 20'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 20'X12'...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
POLY TANK ON SADDLE MOUNT (A62131)
POLY TANK ON...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
