Need help with pole barn overhead detail - Concrete next week!
/ Need help with pole barn overhead detail - Concrete next week! #1
DrewStyduhar
Member
Reidsville, NC
1978 Massey 20C w/Perkins diesel
We are going to pour concrete late next week and a thought just occurred to me about the overhead door openings. As things sit, the plan is to put a form board on the outside of the door jamb trim and pour the concrete right up to the tin in the door openings. I didnt think/realize that concrete against tin is not cool so I need to figure out what to do asap.
I have attached a pic showing one side of the opening. Note the non PT 2x4 attached to inside of post and left long so the door wont fall out of the track before concrete is poured. This will get cut off flush before pour but thats what is behind the tin if its cut away. Sort of tough to tell but the building has two rows of skirting so there is a row of tin below the rat guard that turns into the door openings. If you cut the door jam trim, this second tin layer is underneath. Cut that away and its the non PT 2x4. Remove the 2x4 and you are looking at the post.
Orange line is grade of concrete inside building
Red line shows 1/2" drop from door track to outside to help shed water.
Blue line is just a rough guess of where I would cut the trim to keep it above the concrete.
Here are some ideas
1. Leave as is but put tarpaper or foam on the tin so it doesnt rust
2. Snip the jamb trim 3/8" above the red line and cover the remaining exposed tin/wood with tarpaper
thank for any ideas or advice.
PS - dont mind the foam in the pic, its used to keep critters out of the barn.
thanks,
Drew
/ Need help with pole barn overhead detail - Concrete next week! #2
You could just wrap the section with Grace Ice and Water Shield (or equivalent)... Leave it a little high but only cut away the adhesive side to cover the concrete pour line, then after the pour cut off the excess. It will be nice & clean, adhere to the structure where needed, watertight & unnoticeable after being trimmed. (Also leave so fudge factor for the pour)
/ Need help with pole barn overhead detail - Concrete next week! #3
Snip the tin, but bend it like flashing at an angle to kick water away. Put typical rigid foam under your new flashing against treated board, then concrete.
/ Need help with pole barn overhead detail - Concrete next week! #4
Is it treated wood behind the tin? OR is the tin there to protect untreated lumber?
IF its treated behind the tin I'd snip and remove.
Personally I dont like the gradual slope away from the door. I like a lip/step cut in that the door closes against. IE: The inside floor is 1" higher. The door closes 1" BELOW the floor level. So everything outside the door is lower.
Any wind blown rain wont jump up the 1" lip and be inside the barn. But as you have it now....a windblown rain blowing toward the door is gonna run across the floor to wherever your drain is.
This is a pic of a buddies barn we just poured back in the early spring. This is the IDEAL garage door transition. IF you have a GOOD concrete contractor they will know exactly how to do this.
Thanks for the advice.
Thanks for the advice. How would you cut the tin without making it look wavy and rough? I would be worried about foam collecting water.
Hello. The 2x4 is untreated. The barn was raised up and a second PT skirt added and turned into the door opening. I guess I could replace the 2x4 with a PT piece but I really dont have the time to tear into things that much.
I like that lip detail. Would be concerned about rolling things in and out of the shop. I understand what you are saying about the slope. My plan was to have the slope start behind the door seal so even if water gets behind the door it will still be fighting uphill battle. Maybe Ill move the beginning of the slope to the rear track
/ Need help with pole barn overhead detail - Concrete next week! #8
Cut tin straight so it won't be wavy. Foam is expanded or extruded. So get foam that doesn't absorb water.
Would I cut both layers or just the door jamb outer layer? If I cut both then that non PT 2x4 is there exposed between bottom of the tin and top of concrete.
I'm not talking about not being able to cut on a line, I'm talking about the waviness that happens when cutting with shears.
/ Need help with pole barn overhead detail - Concrete next week! #11
I'd not pour concrete up against it, but i understand you wanting to be able to move things into and out of the barn without a lip to contend with. Maybe possible to frame your apron so as to not have concrete up against the door jamb.
Yeah I need to protect the metal from the concrete with something There are two overlapping tin layers, one of those is overhead door jam. If I cut the door jam up and leave the second layer of tin then I still need to cover with something. If I remove both layers then I have a non pressure treated 2x4 exposed. One person told me I should just cover what I have in ice and water shield and keep going. If I need to remove the door jam, I can deal with the cutting at that point. Tough call......not sure how I fee about removing all that tin (which is protecting the wood) for the sake of getting the door jam above concrete grade
/ Need help with pole barn overhead detail - Concrete next week! #13
Maybe you need to practice your shear cuts. I cut it all the time.
/ Need help with pole barn overhead detail - Concrete next week! #14
You need a wide pair of sheet metal benders. The foam doesn’t absorb water.
/ Need help with pole barn overhead detail - Concrete next week! #15
I always run a 2x2 inside the form flush with top of form for a tin ledge. Makes putting tin on a lot easier. Then I go from bottom of tin step, inside about a foot and make a slope at the door.
/ Need help with pole barn overhead detail - Concrete next week! #16
You can cut the outside. Get flashing to cover bare wood. J channel for raw edge of cuts. If you don't have a ledge for Tin to set on, how will you keep rats and snakes out? I only say that because you have doors. If you're gonna seal it, then seal it.
/ Need help with pole barn overhead detail - Concrete next week! #17
For the 1" ledge you can put some 1/2" PVC pipe pieces or triangular wood pieces there when you need to roll something in.
/ Need help with pole barn overhead detail - Concrete next week! #18
I have equipment and other means of getting stuff in and out.
No way would I let occasionally needing to "roll" something in and out keep me from doing the BEST garage door transition hands down.
/ Need help with pole barn overhead detail - Concrete next week! #19
Watch the door height, they keep building tractors taller. I went to buy a new tractor, the new models were 2" taller than my roll up door openings. Whatever your tractor height, make your door openings at least 6" taller. You do not want to get a new tractor and then need a new barn.
/ Need help with pole barn overhead detail - Concrete next week! #20
I would not leave non PT wood exposed.. easier to fix now that a few years from now.
And I always nestle in a galvanized 1-1/4" pipe for the garage door to close against. The astragal fits nicely over the pipe, the pipe is straight for a good fit, and the water sheds away both ways. Leave very little pipe exposed.
And I don't let the contractor broom the finish. Trowel it smooth so dirt can be easily swept up and the floor kept clean. Brooming lets them get away with less finish troweling, IMO
Good luck with the pour.
2025 Unused SDLGC80 Electric Golf Cart (A60352)
2025 Unused...
2013 Ford Escape SUV (A61569)
2013 Ford Escape...
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
2018 Ford F-350 (A55973)
2018 Ford F-350...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
2019 GENIE GS-1930...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A60352)
2010 International...
