5inch minus spreadability?
/ 5inch minus spreadability? #1
billboe
Gold Member
Vermont
Kioti DK45SC w/ Backhoe
I want to raise a section of our driveway (where it meets the main road) about 1ft. I'm thinking about putting 5" minus on the bottom and then 3/4" minus on top. How easy will it be to "grade" the 5" minus? I have a back blade and a crappy box blade (and a bucket of course).
Or should I go for all 3/4" minus (it is about $50 more per load)?
Thanks!
p.s. I guess I mention the the existing driveway is in good shape (gravel over fabric). I just want to raise it so it is easier to pull out onto the local 50mph road (especially when it gets a little slippery).
/ 5inch minus spreadability? #2
It will spread with some work getting to where you want it. Keep wheel packing it in as you go.
thanks citydude!
i'll certainly have the truck spread it as they dumps, so, hopefully it won't be too bad.
/ 5inch minus spreadability? #4
I find big material harder to work than the smaller stuff, especially when they start to mix on top. Question is how are you going to finish the sides. Unfinished the fill will tend to fall off or out causing the top to break off
thanks scootr... i was thinking about that. i was either going to feather the new material or pull some soil against the sides to hold everything in place. do those options sound reasonable?
/ 5inch minus spreadability? #6
If you haven't already.. If you have good grade and already on fabric I wouldn't mix size if you don't have to.
The big always "comes up" and once mixed it is hard to work with if you need to put a blade in it/on it. Six inches of 3/4 minus is so much easier to work with than 3" of 3" and 3" of road rock.
Best,
ed
/ 5inch minus spreadability? #7
The local quarry makes a 3” minus that’s not horrible. 5” will be terrible without a dozer.
/ 5inch minus spreadability? #8
If the base is sturdy I wouldn't put the big stuff on...agree^ it is a pain to work with if not needed.
/ 5inch minus spreadability? #9
Did what I think you mean to do for a customer last year. Large “belly” and then steeper rise to the road. His corvette scrapped coming and going. I used just enough 3” to take most of the belly out, about 6” at the deepest part. Then went over it with 4” of 3/4 minus. Worked well, no complaint on about a year.
(He did sell the Vette though….lol.
/ 5inch minus spreadability? #10
In a bad section of my drive, I spread 2" minus that was available locally. I then spread 3/4' minus over it. No problem spreading the 2" minus. Jon
/ 5inch minus spreadability? #11
Thanks!
Go with rock size you know you can grade. Most locations are fine to build up 1 1/4" minus to 12". Then fines for final grade.
/ 5inch minus spreadability? #12
Around here we dont have 5" minus.
We have 2" minus and we call it 304's and we have 3/4" minus and we call that 411's.
The 2" minus is difficult. You have to be good at spreading it the FIRST time. BEcause the more you work it, the more the fines settle to the bottom and the larger stone ends up on top with not enough fines to lock them in.
We also have whats called 1's and 2's. Which is what we use for driveway base. IT has no fines....its just all larger rock, 3"-4" or so, washed and screened.
IF it were me, Id build up with large stone with no fines.....(ones and twos as we call them). Then a generous 2-3" layer of 3/4" minus on top of that. The fines lock in the large stone and you have a solid drive.
Drives around here are 10-12" thick normally....and done with ~6-8" of the large base rock (ones and twos), then 3-4" of 411's (3/4" minus) on top to lock it in. Then a ~1" topcoat of whatever the homeowner wants. Usually 57's (3/4" washed and screened) or #8's (3/8" washed and screened)
/ 5inch minus spreadability? #13
That description leaves me a tad confused.
BUT have you ever heard of this stuff?
/ 5inch minus spreadability? #14
3" minus seems like the easier way to go. If not at least use 1 1/4". last layer can be 3/4"
/ 5inch minus spreadability? #15
I do know that larger rock will try to float to the surface due to frost heave if its not under the frost depth. At least it does in my area.
/ 5inch minus spreadability? #16
Agree 100% with this. You will be frustrated trying to work with big stone like that and the only thing you will likely do is wreck your equipment.
/ 5inch minus spreadability? #17
I did 2" minus in lower areas where I saw a lot of water and put 3/4 minus on top. I do have areas that people say it is bumpy where I spread the 2 and it does seem to mix together over time. I have no fabric so regular maintenance is required.
/ 5inch minus spreadability? #18
The bigger the rock, the bigger the equipment needed to spread it. Five inch minus will surely need a dozer to spread and walk it in some.
The other truism is,” the more fabric you buy, the less rock you buy.” It might be worth putting fabric over the 5”, if you can get it flat enough, before you put 3/4 minus over it. I watched a state road project in Utah where they layered rock and fabric to build the base from about 6” to 3/4”. The fabric for the first layer looked more like the hole size of chain link fence. Drainage I suppose.
/ 5inch minus spreadability? #19
Fabric OVER the 5" is a bad idea.
Fabric first, separate stone from dirt, or no fabric at all
/ 5inch minus spreadability? #20
Thanks!
Unless you're going to put in a really deep lift (like a foot or more) you won't get as much support from the 5" minus base course material as you might think. Without a deep enough lift the pieces don't have the opportunity to interlock. As others have noted, spreading 5" minus is more like dozer work and compacting it almost takes a grid roller. Smaller material like 3" minus or 2" minus will work better for you.
Filter fabric works great to keep aggregate separated from the native material. But, if you put it underneath the surface course instead, that surface course better be pretty thick. Otherwise, at some future date you'll hook it while grading the driveway and filter fabric that gets pulled up through gravel makes a a sweet mess that's hard to ever put back right.
Similar things will happen if your surface course (the 3/4") isn't good and deep over the base course. I see you're in Vermont so you'll surely displace some surface course during snow plowing. At some point you'll try to smooth up the surface course and start pulling up the base course material. That makes a mess of it's own. Most of my driveway is 3/4" minus about 6" deep with no base course underneath. The one spot I did put 3" minus base course has a continuing problem with base course getting pulled up during grading. A few large pieces can really make a mess of the surface when you're back dragging. If I had it to do over I would have just gone full depth there with the 3/4".
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A62129)
2000 CATERPILLAR...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
2022 John Deere 7R 210 Tractor (A63111)
2022 John Deere 7R...
2016 Hyundai Sonata Sedan (A61574)
2016 Hyundai...
2025 SF60 60in Hydraulic Side Shift Forks Skid Steer Attachment (A61572)
2025 SF60 60in...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
