WICKED Toothbar will Transform Your Bucket
/ WICKED Toothbar will Transform Your Bucket
Here's some new Wicked feedback! Transform your bucket. Oldest pending order is currently 2 weeks old.
Travis
EVERYONE with a tractor should have a Custom, USA Made Wicked Toothbar, but don't just take our word for it..
"We've tried several other tooth buckets and edge attachments (and torn them up). This machined tooth bar is hands down the best we've had! It is useful for not only digging but also allows for smooth grading and finish work. The teeth are aggressive when need be, but with the bucket leveled out, it runs level, period, and doesn't try to dig or leave nasty grooves. We originally bought for our skidsteer, and will be buying a 2nd for the tractor!" -Craddock from TN.
/ WICKED Toothbar will Transform Your Bucket #103
I removed a table-top dirt bike jump left from the previous owner using the wicked tooth bar. It was the size of a mini-van and made of mostly hard-packed clay with a little dirt for good measure. I was able to get through it at least; without the teeth I would have just stalled the tractor trying to push.
I had the same feeling digging this out as when someone says "help butter this toast" for a large family breakfast and hands you a plate full of toast, a knife, and a stick of butter straight out of the freezer :)
That's awesome, man. Thanks for the business and for sharing!
Love the analogy, too. Have I used this one, yet?
Travis
You're hearing it here on TBN first.
Wicked Toothbar is getting ready to decrease in price by a LOT, so ordering one for your tractor should really be a no brainer! Take advantage of the savings while it lasts!!
Build time has only been around 3ish weeks.
Travis
Can't remember if I shared my vid from the factory, but if not, here ya go..
/ WICKED Toothbar will Transform Your Bucket #106
are you still making the toothbar that just bolts to the factory bolt holes in the cutting edge? I do not want to put additional holes in my bucket.
/ WICKED Toothbar will Transform Your Bucket #107
Travis
Great for the next guy... I just bought one recently
Hey man,
We can build a Wicked Toothbar to match your bucket holes, but you’d need to filled out a detailed drawing. If built like this, it would not have the side ears or top wedge keepers. More recesses, and not as aggressive, IMO, and takes more to remove it.
Travis
With matching holes..
With side ears..
Here's a fresh EA Factory tour, with LOTS of Wickedness for your viewing pleasure!
Travis
Some fresh feedback! Our customers are awesome.
Travis
"T-Rexes and Raptors AIN'T got nuthin on this tooth bar! This thing RIPS through the ground faster and better than a T-Rex tearing into a Brontosaurus! Has made my Kubota L2501 1000 times better at reclaiming my property from the ravages of time growth! Now all I need is my Wicked Grapple to show up to cleanup my work!"
We just received some Wicked fresh, Wicked great feedback on the Wicked Toothbar Page
"I have wanted this bar for a while and now that I have it, it is great. It cuts through roots and hard clay very easily. I sent the measurements, it was built exactly to my measurements, and I received the bar within the stated timeframe." -Chris from NC.
Hey guys,
We currently have our Wicked Buckets IN STOCK for fast shipping.
The ENTIRE bucket is Hardox 450.
It has a welded on smooth edge and a bolted on WICKED edge, standard.
Travis
New video with Ted..
More goes into making a Wicked Toothbar than one may think.
Check out the milling process, which every single one of our toothbars goes through.
Travis
2022 John Deere 317G Track Loader (A63109)
2022 John Deere...
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
JOHN DEERE 825 - 4R DANISH TINE CULTIVATOR (A63290)
JOHN DEERE 825 -...
COLE MULE PLANTER (A63745)
COLE MULE PLANTER...
Case Steiger 600S Tractor (A64047)
Case Steiger 600S...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
