Pole Barn Lighting Options
/ Pole Barn Lighting Options #21
64 per sq ft should be plenty. I put in 12 4' 5000 watt Harbor Freight LED's in my 30x40x12 pole barn which is 50 per sq ft, and it is plenty bright in my barn.
/ Pole Barn Lighting Options #22
I must be old. From my previous post I calculated my lumens per sq. foot currently. I have 175 lumens per sq. foot. And it's still not enough. I have had cataract surgery and new glasses since the upgrade. It must be me. TaDa!
/ Pole Barn Lighting Options #23
Those are the ones I commonly see complaints about… with RF interference. If you go up to about $35 each (17500 lumen) you get filtered drivers
Out of all the ones I've bought only 1 light caused RF interference. I keep a radio running about 10 feet from where I test the lights when I first get them.
I do read the reviews first and don't buy if there are complaints about interference.
/ Pole Barn Lighting Options #24
I've been chasing the same animal. LEDs were expensive when I first started, so I had a combination or 3bulb 4' T8 fixtures and plain vanilla ceramic light holders. Put LED light bulbsin the ceramic holders, and life is good. As T8s burn out, I replace them with 4,000 lumen (each) T8 LEDs (=12,000 lumens per fixture). Then I put a few "flower" style LED lights in the ceramic fixtures. I think I like them best.
I do get RF interference, but I like the bright light. When looking at LED lights, pay close attention to the Lumens. They may be the same length, or look alike, but vary widely on light output. I found inexpensive, bright LED lighting that has RF noise, and that works for me. If you find inexpensive, bright LED lighting that has zero RF noise, please let us know.
I’m sort of leaning toward (18) 12000 lumen lights…
That’s 96lm per square foot.
Working with an electrician this week to map out the outlets, since they can be connected (3) in series across each truss
/ Pole Barn Lighting Options #27
You can also hang a 10,000 strip light over a work bench to give it more light than the rest of the shop.
/ Pole Barn Lighting Options #28
Those strip lights reduce the shadows significantly as well.
The plan is to have (3) 8’ strip lights across each 40’ truss
Well, I went with (8) 27000 lumen UFO lights. I’d say that is sufficient
I used Hyperlight, lighting. Very impressed with the output. These are rated for wet conditions too, though the barn is bone dry. I will have to wait on any longevity claims.
/ Pole Barn Lighting Options #34
Looks real good.
I helped a friend build a shop this past December through completion this spring.
He went with the 8' led lights kids. Like $180 or so on Amazon for a 12 pack. I think they were 10-12k lumens each.
His shop was 30x56....and we did 3 runs the length of the building.....6 in a ach run for a total of 18.
And I can say it's one of the brightest shops I have been in. And only about $270 in lighting. Yes leds have came along way
Looks real good.
And I can say it's one of the brightest shops I have been in. And only about $270 in lighting. Yes leds have came along wayView attachment 762581
My concern about the cheaper LEDs was RF interference with my door remotes etc. Ive read of real issues with those??
/ Pole Barn Lighting Options #36
I like the LED lights in my garage, but the FM radio doesn't work when they are on, and the remote won't open the garage door if the lights are on.
/ Pole Barn Lighting Options #37
I wired my 36 x 50 x 12 pole barn this spring. I certainly didn’t overdo it with the lighting, but what I installed works very well. The main space has (3) overhead ceramic fixtures, in which I installed 60 watt eq LED bulbs (Walmart had those on sale for $ 3 for a 4-pack). The main space also has a 100 watt eq LED on a garage door opener up top.
I installed (2) 4 ft LED’s in the 12 x 20 x 7.5 woodshop and (1) in the 12 x 10 x 7.5 metal shop that I built under the post and beam loft that I built inside the pole barn. Those little LED’s light up those shops extremely well.
I only have 45 amps running to the barn (including a 30 amp main from the house box to a sub panel in the barn and another 15 amps to an outside outlet under the barn porch), so I went light on the lighting. That left plenty of power for a small welder and some other power tools. I can even run the AC on my camper, that I keep in there, plugged into a 20 amp outlet, with all those lights on. That came in handy, during a few heat waves this summer.
The LED’s are amazing compared to the fluorescent fixtures I had in my old shop. Way more light, less power, and instant light even when the start up temperature is below zero.
/ Pole Barn Lighting Options #38
These would be dandy in your ceramic fixtures.
/ Pole Barn Lighting Options #39
I will ask my wife to get me some of those for Christmas. There is some junk in the back corner of the barn, that I’d like to sort thru this winter, and that extra light would be good for that.
I also plan on enclosing the back porch, where I installed another ceramic fixture. The second one will make the lighting a lot better in there, than the single 60 watt eq that’s out there now.
/ Pole Barn Lighting Options #40
He hasn't had any issues with with his liftmaster door openers and even FM radio.
I put 4 of these Real Work Lighting™ 48 In my 20x32 little garage that I built this summer. Its plenty bright and while I have no radio, I have had no issues at all with the door opener remote working with the lights on.
Those are 48" 10k lumen.....and I think its about the perfect amount of light. A little over 60 lumen per sq ft. Which is about half the lumen/sq ft as my buddies shop that I posted pic of above
1999 John Deere 345 Lawn Mower (A63116)
1999 John Deere...
UNUSED RAYTREE RMVR76-76" HYD VIBRATORY ROLLER (A62131)
UNUSED RAYTREE...
UNUSED KJ 20'X30' METAL GARAGE (A62131)
UNUSED KJ 20'X30'...
2011 Dodge Charger (Police), VIN # 2B3CL3CG7BH526995 (A61165)
2011 Dodge Charger...
UNUSED WOLVERINE QC1-26-20G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
2024 John Deere 408R Sprayer (A63109)
2024 John Deere...
