rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,871
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
B21 problem
I had a problem this weekend that I had not experienced before and thought some of you might be able to shed some light on what happened. After about 5 hours of continues use of the backhoe and loader on my B21 the hydraulics gave out. The backhoe would not respond at all and the loader would...
Hydraulic Oil Temp.
For no good reason other than I wanted too. I added a temperature indicator to the Hydraulic reservoir. I figured if I knew what normal was I might be able to figure out when things weren't normal. I used a digital probe that fits quite nicely in the hole for the dip stick. The probe comes with...
Mostly what I read is a lot of good reports on the B21 from 20 years ago.
