Buying Advice Small Cab Tractor
/ Small Cab Tractor #1
Olympus
Cape Girardeau, MO
LS R3039
Hey everyone, looking for some advice/suggestions on a small cab tractor. I currently have a 2013 LS R3039 shuttle shift with 500 hours and it's been a great tractor and I've never had a single issue with it. It's 38.5hp which I've never had a single instance where I wished I had more horsepower. I was using it regularly to maintain a 6 acre property with a long gravel driveway. I have since moved to a new house on 3 acres and no more gravel driveway. I own a hunting property where I use it to brush hog trails. I have two one-acre food plots that I till about once every 2-3 years but I've started renting a Deere 3032e and rotary tiller for $350 to use for tilling. I tried just renting the tiller only but the PTO shaft was too long by about 2 inches and the rental shop would not allow me to shorten the shaft so I've had to start renting their Deere tractor along with the tiller. Which is fine by me because my food plots have rocks and roots still that I'm slowly picking out and throwing off to the side so I'd be pissed if I roached a $2000 tiller that I paid for. Anyway, the last few years I've been keeping the entire loader frame on my LS removed from the tractor because it's easier to maneuver through the wooded trails when I'm brush hogging. I find myself only putting the loader frame back on when I need to lift something or carry something, mostly for neighbors.
But I've been thinking about upgrading to a small cab tractor as I'm getting older. I'm thinking that for my uses now, I could probably move down to a smaller size tractor and still be able to do what I want/need to do. I still want a loader, but want to be able to remove the loader easily like I'm doing now. My current tractor has 2 rear remotes and I've never even used them. Not sure if that's something that's necessary on a new tractor considering I've yet to use them on my current tractor. I'm not sure if I have a preference on HST or shuttle shift. Some days I wished I had HST and other days I'm fine with my shuttle. I do think that cruise control on an HST is important, preferably one that you can set any point rather than presets. I've seen some HST cruise where you can only lock into 2 or 3 different positions and I think that might be hard to find the right speed. One preset might be too slow and the next one might be too fast. Right now I have 2 attachments, a brush hog and a boom spray tank that I use to spray weeds in my yard. I've been living at my new house for 3 years now and haven't had a need for any other implements yet aside from the rotary tiller that I'm renting once every few years.
I look forward to hearing suggestions and advice!
/ Small Cab Tractor #2
When I was shopping for my first tractor cabs were not as available on smaller machines as now, so I ran an open station for 15 years or so. By the time I upgraded to a larger machine OEM cabs were more available on smaller tractors. Anyway, for me there's no going back after having a nice climate controlled cab!
As far as recommendations, I tend to prefer Kubota machines. The LX series seems about the size you are looking for. The LX2610 avoids the dpf emissions requirements, and the 3310 does not.
Regardless of what brand you choose, I would think your reduced size and HP needs should keep you out of dpf tractors, and should be a consideration. LS has a large following here on TBN. I'm sure someone with an smaller LS cabbed tractor can provide info on their lineup.
Happy tractor shopping!
/ Small Cab Tractor
Thanks. I’ll take a look at the Kubota models.
Probably the biggest contender for me right now is the Kioti CK2610SE. It looks like it has a ton of features.
/ Small Cab Tractor #4
Whatever manufacturer you choose, keep in mind that your pre emissions 38hp tractor will command a premium price.
/ Small Cab Tractor #5
Kubota makes nice small L & B models.
/ Small Cab Tractor
What do you think mine would be worth? Always stored inside a shop, 500 hours, still looks like new.
/ Small Cab Tractor #7
Here on TBN, for pre-emissions tractors with low hours - which usually means under 1000, stored well, everything works right, and it looks good .... then pre-emissions tractors tend to be priced at what they cost originally. Sometimes more.
/ Small Cab Tractor #8
Hey everyone, looking for some advice/suggestions on a small cab tractor. ---------------- I look forward to hearing suggestions and advice!
You didn't mention mention budget, but a Bobcat Toolcat would do what you need done.
This is my thread if you are not familiar with Toolcats: Toolcat 5610 F and 5610 G Series Pictures
The view of the 7' brush hog from the seat:
And no emission stuff to worry with (y).
/ Small Cab Tractor #9
Don't forget to check out the LS and Yanmar
tractors
Basicely you need to get on them and try them
out to see which one fits your style
willy
/ Small Cab Tractor #11
If the pto shaft is too long get a quick hitch that will give you the distance you need and after the first rental saved it’s paid for
/ Small Cab Tractor
Thats a good idea. I didn’t think of that. But sometimes those quick hitch top hooks don’t fit certain implements. I’d hate to buy one purely for use with a rented tiller and it not fit.
/ Small Cab Tractor
/ Small Cab Tractor #14
Not sure, but I believe you’re going to have to find a tractor with a common rail fuel system and HST to find something with cruise control.
The old school mechanical fuel systems typically wouldn’t have the flexibility and contrl that a modern electronic engine has.
Take a look at the Kioti CK3510 or 4010 SE HST can models. They come equipped with what Kioti calls Linked Pedal and a cruise control button on the dash. I have a CK4010 se hst, and use the cruise function mostly for for road transport, as I don’t have average to bush hog.
/ Small Cab Tractor #15
Branson Cabbed CUT's might fit the bill.
No HPCR and have cruise and Hydrostat
Industrias America 435 (A64119)
Industrias America...
ROANOKE G195 BRUSH-AX LONG ARM MOWER (A63291)
ROANOKE G195...
2016 Ford F-550 4x4 Venturo ET25KXX 2 Ton Crane Service Truck (A61573)
2016 Ford F-550...
2004 INTERNATIONAL 9400 T/A DAY CAB ROAD TRACTOR (A63291)
2004 INTERNATIONAL...
2012 Mercedes-Benz 2500 Sprinter Van (A61573)
2012 Mercedes-Benz...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
