Why no Ecoboost in the F250?
   / Why no Ecoboost in the F250? #51
I think some of the really big equipment has V12s. I’ve never been around anything that big. The vast majority of cat equipment has I6 engines.
The Cat 793 haul trucks at the mines I worked at had V16 engines with 4 giant turbos on top:
The Cat 797F haul truck uses a V-20 engine!
   / Why no Ecoboost in the F250? #53
Rob, they'd be huge I-6's if that made any sense, but you can only go so large on cylinder bore size before the thermodynamics get really wonky and you end up inefficient and stuck at very low engine speeds for operation (container ship diesels run at 100rpm rated power, for example). So above the 15-20L displacement range, you go back to V12s and above for anything that drives itself. Typically, anyway.
   / Why no Ecoboost in the F250? #54
Is gas was so much better. Wouldn't all the big trucks run gas V8s?
   / Why no Ecoboost in the F250? #55
My point is/was, there's no set "best", things keep changing like CAT is moving to more and more I4's, even in dozers like their D-5's (use to be D-6's) that are a 15 ton dozer! It's the same hp and weight (15T 130hp) as deere's 700 and deer has so far stayed with an I6 in that size dozer.
SR
   / Why no Ecoboost in the F250? #56
Well, how hard have you tried?
My truck's powertrain has the same story - most people with an LQ4 report getting 11-12 mpg no matter what they do - but my own truck easily gets 14-15 in daily driving. It comes down to the details, and you gotta check them all and add them all up to improve your mpg consistently.
  • Tires - you running chunky all terrains? Don't. Michelin LTX tires have loads of traction for mud or snow, but get demonstrably better mpg on the road - LRR = low rolling resistance
  • Aerodynamics - do you have a ladder rack, front bug deflector on the hood, or any other silly stuff catching air like a parachute? Do you have a basic tonneau cover that you keep closed when not hauling bulky stuff in the bed? If not, do it! Tonneau covers help a lot; my nice roll up Access-vanish was only $270, keeps the bed dry, looks slick, perfectly reliable for 6 years now.
  • Front air dam - many HD pickups omit this crucial aerodynamic feature, or guys rip them off themselves for whatever reason. Don't. Sending airflow around the truck instead of under it helps a ton with mpgs. I made one for my truck out of lawn edging, it helped noticeably.
  • Engine maintenance - keep your oil changed on time with fresh synthetic, clean air filter, fresh spark plugs/coils, etc
  • Vehicle alignment - this one is kinda sneaky. But get an alignment recently? If not, do it. Request zero toe-in, for optimal mpg.
  • Driving style - COAST, COAST, COAST. No, don't be blocking traffic. But generally: accelerate briskly, then pretend there's an egg under the pedal once you're up to speed. Look way down the road ahead of you to anticipate and avoid unnecessary slow downs, and try to get into DFCO (deceleration fuel cut-off) when coasting down to a red light. I try to use my brakes as little as possible.
Lotta guys don't think aerodynamics matter on a bulky HD pickup, but they really still do. Go with the small side mirrors and add on towing mirror extensions only when needed. Pull the big long radio antenna if you don't need long-distance reception. Cover the bed with a tonneau. Don't hang a big tow hitch/ball down into the air flow behind you if not towing every day. I could go on and on - the details add up and you can probably save 20% on your fuel bill if you want to.
Also, that other dude might just trust his dashboard mpg display and never actually check it at the pump, LOL.
And finally had the winning comment at the end...
First, I'm actually satisfied with 12.5 mpg. It beats my previous truck by double in all conditions. My old Powerwagon got 6 mpg empty and rolling slow.
I run all terrains. I don't give a toss about improving mpg by sacrificing traction. We get snow here. Bunches of it. It stays all winter long. Many roads and parking lots don't get plowed at all here, or if they do, it's not very often. Spring thaw and there's mud everywhere. Can't drive down the road in front of our house without 4x4 and good tires (those evil "all terrains").
Aerodynamics... you know it's a truck, right? It's about as aerodynamic as a barn. Only thing that helps that is to drive slower for less wind to push against. I get significant savings by running at 60 mph vs 70 mph. You should try it. I try to moderate speed when possible. No sissy-fied "bed cover" here. It's a truck. I use it for "truck stuff". Summer time there's a 5th wheel hitch in it, winter time there's 1200-1400 pounds of sandbags in the bed (back to "we get winter here"). There's a ball hitch in my receiver hitch all the time. It's usually the 2 5/16 ball, as that's the one I need most often. But, it's a truck. I use it for "truck stuff".
My engine oil gets changed every 5K miles. Whether it needs it or not.
Tire wear is perfect. Alignment is fine.
Already drive it like the "egg on pedally thing".
I'm not taking my tow mirrors off. But I use my truck for "truck stuff". Them mirrors are staying. I do push them in to the narrowest when I'm not pulling an enclosed trailer, or a wide load on the flatbed trailer.
I once got 17 mpg coming back from MT one summer. I was driving in a 70 mph tail wind. That doesn't happen to me much, so I don't "count" that one.
Just funnin' ya a bit there.
   / Why no Ecoboost in the F250? #57
SR
The newer Cat D5 sizes are all over the place. They make some that are pretty much a D3 and they make some in the 15 ton range. I have an older D5 which is 15 tons and it has a 3306 which is a huge motor for no more power than it’s making. On the plus side bogging down isn’t in its vocabulary. I looked at buying an earlier 2000s model D5 and it was only 10 tons and it had a considerably lower displacement 4 cylinder motor. I’ve not looked at a newer 15 ton D5 to see what it has. Edit the new series D5 which is really like a D6 at over 20 tons has a Cat C7 which is an I6.
   / Why no Ecoboost in the F250? #58
I feel battered after reading this post! My poor old F350 with a 7.3 V8 diesel and 6 speed manual get driven like I have to fix it, and I am the one paying for the fuel gong in! It gets 16 to 18 pulling 20K as long as I keep it at 65mph, and can go to 11-12mpg if I push the speeds on up.
ECOboost? Isn't that just a turbo'd gas engine? My wife's car has one of those. Quick for a 4 banger, but we don't pull trailers with it.
David from jax
   / Why no Ecoboost in the F250? #59
We've talked about this before. A straight six and a V8. The V8 will produce more HP and Torque than the straight 6 of equal/near equal displacement. However, the straight 6 will produce it's torque at a lower RPM, giving the 'feel' that it's more powerful, even though it's not.
I think the discussion was based on the ford 300 straight 6 vs the ford 302 v8, and similarly, the Chevy 292 vs small block chevy's.
I can't speak for the diesels, as I've never looked at the torque curves, HP, etc.
A v8 has more rpm range. Rpms are a factor in both torque and hp.
   / Why no Ecoboost in the F250? #60
Looks like it’s the C27 engine that’s a V12.
It's a V-16, 8 cylinders on each side. Front one is almost hidden by thr box on the front corner.
An EcoBoost in an F250 would be fine, if it was a 7 liter V-8.
2025 FUTURE X-DM43 SKID STEER DISC MULCHER (A58216)
2025 FUTURE X-DM43...
2003 Ford F-750 Truck Highway HM25 Hydraulic Pressure Digger Truck (A55973)
2003 Ford F-750...
DOUGLAS SERVICE BODY FOR SMALL TRUCK (A52708)
DOUGLAS SERVICE...
JOHN DEERE 544G WHEEL LOADER (A58216)
JOHN DEERE 544G...
2009 MULTIQUIP 25KW GENERATOR (A58214)
2009 MULTIQUIP...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
