Is anyone here familiar with scaffolding?
   / Is anyone here familiar with scaffolding? #101
The hard part about this is trying to think of every use scenario. That sounds like a good setup, but let me throw out two thoughts:
First, there is a certain usefulness to having all of your frames the same size, that way they're interchangeable. The three-footers aren't that much lighter or cheaper than the five-footers, it might be more useful to get a five foot frame instead of the three-footer. The three-footers also aren't walk-through, so if you're working side-to-side you have to go down a level and go back up to go sideways.
Notwithstanding the foregoing, as the lawyers say, I sometimes wish I had some 6.5 foot frames for the bottom two rows. When you've got your feet on solid ground the bigger frames aren't any harder to handle, and you get up 13 feet without leaving the ground. If your bottom two frames were 6.5 feet you wouldn't need the extra three feet. At ground level the 5' frames are kind of a pain because you have to duck to go through them.
All this is true, but as for the 3' frames, there are times where the 5' can be to tall - especially when working under a soffit. Even if the 5' fit under the soffit or ceiling, I find it hard to kneel, so I set my frames so I can stand. All my frames are 5' but I also have 1 set of 3' frames and they do require different cross braces. (I've also used the 3' as a really big work table when we built our cabin.)
I figure with the three footers I can get that extra bit of height without standing on a couple of stacked mil crates on top of three 5’sections. . . I mean, the whole purpose of this exercise is to work safely, isn’t it?
Don't forget the pigtails to tie the sections together. The way I read this is that you plan to have an 18' tower with the guard rails at the top. You'll need 16 pig tails for each tower.
Thank you - this is the type of info I need!
   / Is anyone here familiar with scaffolding? #104
Good Morning!
I will have to do some major home improvement projects, most notably re-staining/sealing our log home, and I don’t want to do it on a ladder. A scaffold (or two) would make for a much easier and safer job.
I have never used scaffolding before.
-EDIT/UPDATE: Terrain and deck preclude the use of a manlift or skyjack.-
My feet need to be 18’ to 20’ above grade level to be able to access all the way to the peak of the roof.
I plan on permanently attaching eyes to the sides of the house in order to rig guys to the scaffold for stability.
What do I need to know when buying scaffolding? There are so many options. I don’t want to rent, because I will have other projects in the future where it will be used, and if I own it, I won’t feel rushed to get it back to the tool rental and maybe screw up or get careless.
childrens etiquette training
thank you for any suggestions, comments etc!
Awrite guys gotta shout offshore overseas but all the company uses is van thiel and layher. I'm a tube and fitting lad an pretty handy with most prefabricated systems but only stumbled over this van thiel gear a few times. I'm pretty sure there's a progressive pattern with the wedge doubles, there was a debate on the forum last year that when building an independent/hanger you needed to fit one of the handrails on the outside in order stop the wedges interfering with one another but I'm sure there's a pattern to follow when fixing these nasty couplers to prevent this. Any info from the van thiel guru's out there would be much appreciated. (Heard there's a few company's in UK using it) apparently rapid system to those familiar with it. Cheers in advance guys
   / Is anyone here familiar with scaffolding? #105
It's important to realize that scaffolding can be dangerous. I'd like to relate what happened to me today as an example of the potential hazards.
I had noticed that a woodpecker had made a hole in the cedar shingles above one of the second-story windows. I decided I should put some putty in it to try to keep him from making it bigger. I got out my 24' extension ladder, but it was just a little bit too short to reach the hole so I decided to use my trusty scaffolding. As I was putting it up, Mrs. Quicksand spotted me, and said, "I want to wash the outside of that window while you have that there."
I got the scaffold up and quickly patched the woodpecker hole, but I realized that there were a few spots on the trim over the window that really needed caulking. So I had to go down and find a caulking gun and a tube of caulk that hadn't hardened and took care of that. When I came down a noticed a piece of cedar shingle on the ground, one of the shingles under the window had come loose. So I went and got a hammer and some siding nails to tack it back up. I noticed some of the other shingles on the same row were loose so I put a few nails in them as well.
Mrs. Quicksand then washed the window. She commented that when we had the house painted the painter for some reason had painted the frame of that window the wrong color. She hadn't noticed it right away but it has bothered her ever since. So I went and found a brush and the can of paint in the basement. It turns out I got the wrong color and had to go back and find the right color. Then she commented that where I had caulked the trim you could really see the caulk so I had to get another can of paint to paint over that.
By then it was lunchtime, and half the day was gone! And that's the danger of scaffolding, once you get up there you find all kinds of things to do.
   / Is anyone here familiar with scaffolding? #107
In my experience, when a woodpecker, or raccoon, or squirrel, makes a hole in a house, the only way to stop them is to put a metal plate over that hole. The metal covers for electrical junction boxes work the best. Once screwed over the hole, I caulk the edges and paint to match. It's still visible, but it blends in well enough not to be an eye sore.
   / Is anyone here familiar with scaffolding? #108
Woodpeckers could be trying to make a nest or they could be going after insects.
   / Is anyone here familiar with scaffolding? #109
I have some scaffolds (Bil-Jak) but the upper pieces are very hard to assemble without extra help. As noted before, rent a boom/man lift. The drive to the rental place may seem far, but most also offer delivery. Kinda pricey. Self propelled are real nice, but may not be needed, depends on the terrain. You won't be sorry.
   / Is anyone here familiar with scaffolding? #110
thank you so much for your suggestion
   / Is anyone here familiar with scaffolding? #111
Man lifts may be nice but a lot of us are so rural that it's an hour or so to the rental company and we work at our own pace.
I had a 40 wide x22 deep carport collapse in a double ice storm. I needed to get up about 20' to neatly disassemble it. With a pair of Bakers scaffolds (cost ~$250 total) it was straight forward and I could do it at my own pace, waiting for good weather.
As quicksandfarmer wrote it's handy for numerous small projects.
In my area the least expensive scissor lift runs about $300/week plus
   / Is anyone here familiar with scaffolding? #112
I suspect the reservations about buying scaffolding is people look at the price tag and wonder if they will use it enough to justify their purchase. When someone has a project like disassembling a collapsed carport or extensive siding repairs having to be made as time allows, then purchasing starts to make sense, especially when rental prices are high.
   / Is anyone here familiar with scaffolding? #113
The towable lift I rent, is $270/day and a 35 minute drive, each way. For the inside work, I rented a small scissor lift, $300/day, 45 min drive (different place). Both worth it, IMHO.
   / Is anyone here familiar with scaffolding? #114
Now days duplex head nails are mostly used for concrete form work. But to buy them today, a lot of times they are still called scaffold nails.
It takes about $125 in materials and 45min to put up 8ft x 16ftlong scaffold, with the materials re-useable afterwards for other projects. In this case I use the loader forks to move it around. 25min to disassemble. Osha has guidelines on scaffolding, including those made of wood. But I think I saw mentioned "My existence can be summed up as an endless series of unreported OSHA violations..."
Since we do not intend to (voluntarily) move ever again, and I am hoping to last at least two more decades, I will be looking at at least 5 more staining projects on the house, so owning DEFINITELY becomes more economical. And that does not include all the other projects it can be used for.
If I thought my wife would let me get away with it, I would go down to the river by the recycle center, cut down a gross or three of bamboo, and lash it together into a work structure like they do in Asia… 😂🤣
   / Is anyone here familiar with scaffolding? #117
The small shed on the left was built in 2016, with the scaffold materials ending up used for part of the shed. The metal roof on the right, scaffold was put up yesterday, gone by tomorrow. So there is something to be said about rent/own/store/build depending on use and abilities.
Like these? I am amazed what humans do with bamboo scaffolds.
Truly an amazing collection of bamboo scaffold pictures here;
All the best, Peter
Well, maybe not THAT elaborate, but basically. . . Yeah.
I figure I can also use the scaffold to hang/age/skin/butcher deer during hunting season, too. 😎
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
Margaritaville Miniature Decorative Truck (A59231)
Margaritaville...
2010 Ford Fusion Sedan (A59231)
2010 Ford Fusion...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
