Mahindra Tractors-Should You Buy One?
/ Mahindra Tractors-Should You Buy One? #21
Some Mahindra models ft and finish look fine. Other models look crude - almost Belarus like. Sorry, I don't think made in India quality stacks up against made in Japan or South Korea.
Many of the Mahindra's ARE made in S. Korea! (TYM)
SR
/ Mahindra Tractors-Should You Buy One? #22
SR
Yep, those models have decent fit and finish. Other models - meh.
/ Mahindra Tractors-Should You Buy One? #23
Yanmar stopped making JD tractors for them around 2000. Now only do the engines.
/ Mahindra Tractors-Should You Buy One? #24
My 2010 JD 2320 was built in Japan by Yanmar. It was built to John Deere design and specs, but still completely built by Yanmar. A lot of the CUT build has recently moved to the US, but John Deere is an international company - which is a good thing.
/ Mahindra Tractors-Should You Buy One? #25
Actually John Deere jumped ahead of the game and joined in with Yanmar. Yanmar shocked the world with the very first 4WD tractors ever. JD noticed this and quickly linked up. Then the next 45+ years, Yanmar made JD compact tractors in green paint all from Japan.
4wd Compact tractors , right?
In utility tractors Oliver had 4x4 in the 1900 and was available in 1962
I have a soft spot for the 30 series tractors of Mahindra, a used 4x4 5530 at the right price would be tempting.
I like the large front tires for a 55hp tractor (9.5 x 24), to many of these new CUTs have lawnmower sized front tires today but jmo
/ Mahindra Tractors-Should You Buy One? #26
SAME Tractors had the first production 4x4 tractor back in 1952. A 25 or 30 HP Tractor with a 2 cylinder air cooled Diesel engine.
/ Mahindra Tractors-Should You Buy One? #27
Apparently the Yanmar dealer I bought mine from was wrong. He told me JD tore up the contract to have Yanmar build their tractors around 2000. But apparently they drew up a new contract. I found this link that shows, as you state, that Yanmar was and perhaps still is building a lot of JD tractors.
/ Mahindra Tractors-Should You Buy One? #28
Those are lawnmower sized too, my 55hp tractor has 11.2 x 24's on the front! lol
SR
/ Mahindra Tractors-Should You Buy One? #29
Ledgemere Farm,
I own both a Mahindra Max 24 TLB and a Kubota M59 TLB. While there is huge difference in both price, weight, and horsepower when comparing the two tractors there are some general take-a ways.
First: Mahindra loves to use hydraulic hose everywhere while Kubota uses tubing where flex is not needed and hose where flex required ( backhoe and FEL joints ). I became aware of the use of hose everywhere when the Mahindra lost a huge amount of hydraulic fluid when I drove over a stick and it speared a hose underneath the tractor and hose tore open. Mahindra did not have any provisions for protecting the underside of the tractor from damage.
Mahindra uses poor quality hydraulic valves whereas Kubota valves appear to be higher quality. If I partially raise the Mahindra outrigger legs on the back hoe or curl the backhoe bucket up, after a few hours the legs will be on the ground and the hoe bucket will have uncurled to hang at lowest point. I have curled the Kubota backhoe bucket and come back a month later and it hasn't moved from where I left it.
Mahindra makes no attempt to protect the hydraulic hoses being routed to the various cylinders on the tractor while Kubota places metal shields or wire wraps over hoses and tubing runs out to hydraulics that could be exposed to damage. I had a hose ripped off an outrigger leg when a large stick became jammed between leg and hydraulic line and I was raising the leg.
The Mahindra's FEL has a significantly smaller curl range than the Kubota. The Kubota will curl in (curl towards the operator) much further than the Mahindra. Helps when transporting a heaped bucket so the load doesn't fall out of the bucket.
The Mitsubishi engine in the Mahindra seems solid so no complaints/ concerns there.
Based on my above 5 years experience with Mahindra Max 24 TLB, I would NOT buy another Mahindra tractor. I would absolutely buy another Kubota, based on my 8 year experience, because the Kubota engineering and build quality appears to be worth the additional expense, ability to do work, and peace of mind that I won't be damaging something while using tractor.
/ Mahindra Tractors-Should You Buy One? #31
Our requirements were
Over 30 horse
Non Hydrostatic, gear trans
4x4
Capable FEL
Skid steer front
Heavy as possible
Added bonus was non DEF, DPF. We looked at Kubota and I don't feel like we sacrificed much if anything. Very hard to find a tractor snob around here, we all use what what works. From our daily driver cars and chainsaws to our tractors. My wood stove does not burn wood any better when its hauled in a $60k tractor bucket and bucked with a $1800 chainsaw. Our sheep have yet to refuse to eat hay hauled by our 4540.
/ Mahindra Tractors-Should You Buy One? #33
Ledgemere Farm,
M59 is a fine tractor, but to replace it today would cost $75K or more.
/ Mahindra Tractors-Should You Buy One? #34
In New Zealand they were importing 4x4 tractors from Europe in the the 1950's so I think 4x4 tractors have been around longer than the tie up between JD and Yanmar
/ Mahindra Tractors-Should You Buy One? #35
/ Mahindra Tractors-Should You Buy One? #36
Mike69440,
Yes, the Kubota M59 is a real work horse with lots of room for expansion, implement wise, and is an overall very rugged machine. I looked into replacement cost to understand what my risk was if machine was stolen ( insurable amount) or severely damaged. M59 are only available used and at a premium and two months ago I priced a new M62 ( M59 replacement ) at dealer. No M62's available until 1 year after order placed and $95,000. OUCH!!
Based upon your response, it appears you may have misunderstood my previous scribe. I was not comparing the Kubota M59 TLB to the Mahindra Max 24 TLB. I indicated I own both and have used both for many years and was comparing the build quality of each brand based on my experience with the two machines. The Mahindra is clearly a very aggressively priced machine to gain market share and it shows in so many ways in its lesser build quality and choice of lower quality components and lesser protection for its components.
/ Mahindra Tractors-Should You Buy One? #37
Ledgemere Farm,
I wouldn't touch one with a 10-ft pole for the above reasons and others, just a cheaply built tractor
/ Mahindra Tractors-Should You Buy One? #38
SR
SR and Airbiscuit,
Based on my experience of currently owning both a Kubota and Mahindra, the issue is not where the machine is built, my issue and concerns with the Mahindra are based on where the Mahindra is designed ( likely India ) and more importantly for what market the Mahindra is targeting. The Max 24 TLB is very clearly designed to be extremely cost conscious so lots of components are inferior to the equivalent Kubota components. The most glaring example of Mahindra cost reduction is their love of hydraulic hose. Mahindra runs hydraulic hose everywhere which cuts cost by severely reducing the number of connectors. Kubota uses hydraulic tubing where ever there is no need for flex and tubing is less likely to be torn/ punctured during use and does not degrade due to light exposure, heat, etc. kubota uses hydraulic hose where ever flex is needed and this means Kubota has many more connections during transitions from tubing to hose and back again.
/ Mahindra Tractors-Should You Buy One? #39
SR and Airbiscuit,
You are not comparing a Mahindra Max 24 to a Kubota M59. Right?
SR and Airbiscuit,
My max 26 has steel hydraulic lines all over the loader
2023 MAD JAX X40 ELECTRIC GOLF CART (A62130)
2023 MAD JAX X40...
2022 Case 5550 Trident Spreader LOW HOUR (A63118)
2022 Case 5550...
2016 Ford F-250 Service Truck (A61568)
2016 Ford F-250...
JOHN DEERE 5403 TRACTOR (A62130)
JOHN DEERE 5403...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
