Kubota wheel and loader nut torque.
/ Kubota wheel and loader nut torque. #21
FYI check your ZT lug nuts also - found mine to be below torque specs.
Excuse my ignorance but what are ZT lugs... I mean yes, zero tolerance but where are they thanks?
I got those torque sticks, I'm ready to try.
/ Kubota wheel and loader nut torque. #23
I didn’t know either so I looked it up. I don’t think your torque sticks were designed for use with novelty items.
/ Kubota wheel and loader nut torque. #24
Back the the question asked If your lug nuts come loose by them selves it is a sign that the stud thread has been damaged some time in the past you will never keep it tight from now on if you don't replace the damaged studs which is quite easy you will at some point damage wheel once the holes in the wheel become oval the repair becomes much more complicated and expensive
/ Kubota wheel and loader nut torque. #25
I will run away from any tire place that doesn't understand the concept of torque wrench. I've seen a few studs sheered off from "mechanics" using impact guns.
/ Kubota wheel and loader nut torque. #26
I'll run them down with my impact set on low impact and then finish with a torque wrench in a criss cross pattern.
/ Kubota wheel and loader nut torque. #27
I don't know either and I'm not wasting my time trying to figure it out.
If the author can't take the time to type his words, I simply skip down to the next post.
/ Kubota wheel and loader nut torque. #28
Zero turn mower.
/ Kubota wheel and loader nut torque. #30
Zero turn mower.
Why don't you do like I did and Google ZT Lug Nuts. I don't think you will find a reference to a Zero Turn Mower.
/ Kubota wheel and loader nut torque. #31
I just did that and the search results were more generic lug nuts but several did mention lawnmowers. While ZT could have multiple meanings I’d bet money the poster in question meant zero turn.
/ Kubota wheel and loader nut torque. #32
/ Kubota wheel and loader nut torque. #33
Recently just repacked bearings and new tires on airstream tri-axle. BIL had given me a case of torque sticks a few years ago but old torque wrench habits are hard to change. Used the 100ftlb torque stick on 36 nuts. Rechecked with torque wrench surprising accurate. The torque sticks instructions had information on calibration and use. Should have torqued to 80 or 90 then 100 using different sticks. Never use for loosing nuts. Confidence in using them to check tractor lug nuts.
See mis handling of torque wrenches in auto, truck, tractor shops. Not returning to zero when storing, not in case or ever checked for calibration. In my industry everything had specifications, checked and torque wrenches were carefully handled.
Yep I’m the white haired old guy at the rest stop parking lot checking torque and hub temps on camper or equipment trailers. Check torque several times after new assembly. Hub temp most every time.
Lug nuts and spark plugs are probably the most over torqued of all threaded fasteners.
/ Kubota wheel and loader nut torque. #34
Zero Turn mower. Sorry about the initialism.
1999 MACK MIXER (A65643)
1999 MACK MIXER...
Landhonor 3-in-1 Welding Machine (A66408)
Landhonor 3-in-1...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
Wolverine Quick Attach Mulcher (A66285)
Wolverine Quick...
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
Caterpillar 572E Tracked Pipe Layer (A64553)
Caterpillar 572E...
