Kubota wheel and loader nut torque.
   / Kubota wheel and loader nut torque. #21
FYI check your ZT lug nuts also - found mine to be below torque specs.
Excuse my ignorance but what are ZT lugs... I mean yes, zero tolerance but where are they thanks?
I got those torque sticks, I'm ready to try.
   / Kubota wheel and loader nut torque. #23
I didn’t know either so I looked it up. I don’t think your torque sticks were designed for use with novelty items.
   / Kubota wheel and loader nut torque. #24
Back the the question asked If your lug nuts come loose by them selves it is a sign that the stud thread has been damaged some time in the past you will never keep it tight from now on if you don't replace the damaged studs which is quite easy you will at some point damage wheel once the holes in the wheel become oval the repair becomes much more complicated and expensive
   / Kubota wheel and loader nut torque. #25
I will run away from any tire place that doesn't understand the concept of torque wrench. I've seen a few studs sheered off from "mechanics" using impact guns.
   / Kubota wheel and loader nut torque. #26
I'll run them down with my impact set on low impact and then finish with a torque wrench in a criss cross pattern.
   / Kubota wheel and loader nut torque. #27
I don't know either and I'm not wasting my time trying to figure it out.
If the author can't take the time to type his words, I simply skip down to the next post.
   / Kubota wheel and loader nut torque. #28
Zero turn mower.
   / Kubota wheel and loader nut torque. #30
Zero turn mower.
Why don't you do like I did and Google ZT Lug Nuts. I don't think you will find a reference to a Zero Turn Mower.
2015 INTERNATIONAL DURASTAR 4300 (A58214)
2015 INTERNATIONAL...
2017 FREIGHTLINER CASCADIA WRECKED (A58214)
2017 FREIGHTLINER...
2015 FORD F-250 SUPER DUTY (A58214)
2015 FORD F-250...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2006 Mercedes-Benz Unimog 405 4x4 Flatbed Truck (A56858)
2006 Mercedes-Benz...
Westfield Conveyor (A56436)
Westfield Conveyor...
