Branson 2910i meter cluster board
/ Branson 2910i meter cluster board
Thank you for the information, I bought or downloaded the manuals. The tractor had sit a couple of years in my neighbors field, she finally sold it to me it also has front end loader,5’ shredder, and 7’ blade ( it is way to big for tractor). Had to rebuild shredder, it had blades that were different sizes ,after a couple years of use, had to replace the head, radiator and fan,and water pump.
It really has been a good tractor.
/ Branson 2910i meter cluster board #22
then its jsut a case of identifying the woring doagram, get a multimeter and check voltages along the conneoctors and compare to the diagram what you should see,.
/ Branson 2910i meter cluster board #23
I sincerely doubt that all those items would fail at the exact same time. I would propose that you don't have bad instruments, but a bad connection from the instrument panel to the rest of the tractor. I would check out the connectors before taking on such a drastic course as changing out all of your instrumentation.
Yep, may be hungry rat damage too. They like to build a nest in tight places the eat the insulation off any wires close by. Also check the fuses. A blown fuse may have saved a fire.
Thanks for sharing your knowledge, I always learn something on this forums .
17601CFL (A61572)
17601CFL (A61572)
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
2019 GMC Canyon SLE 4X4 (A62679)
2019 GMC Canyon...
2013 Hitachi ZX160LC-5N Hydraulic Excavator (A64553)
2013 Hitachi...
Star (A64557)
Star (A64557)
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
