L2501 and quick hitch question
/ L2501 and quick hitch question #1
gd165623
Member
I have a new l2501 and also got a land pride 1260 mower at same time. Dealer brought it out with mower attached. I removed the mower and now thinking of using a quick hitch. I have a harbor freight quick hitch new in box that i never used on my other tractor. I know about replacing the top hook on the harbor hitch. But my question is by going to quick hitch will the pto shaft still fit. I am new at this and dont want to have to cut anything . Help needed please
/ L2501 and quick hitch question #2
You don't need to cut the driveline. You should have enough driveline to take up the extra 3" or so the hitch will add to the distance between the tractor and mower. The driveshaft should be at least 2" in the tube when the hitch is lifted to full height.
/ L2501 and quick hitch question #3
At the least, you shouldn't have to cut the pto shaft. Adding the quick hitch would require the shaft to be longer, not shorter. The question is, is there enough shaft length left in your current pto shaft when you add the extra "length" of the quick hitch?
/ L2501 and quick hitch question #4
I've got a l3901 with a speeco quick hitch and rc1260 behind it, other than adding bushings no changes were needed. I would assume the l2501 is similar enough to expect the same for you.
/ L2501 and quick hitch question #5
1260 comes QH compatible so it will hook right up
/ L2501 and quick hitch question #6
I have an L2501, the HF quick hitch, and a 5' Brush Hog that was left on my property when we bought it. No go with the quick hitch - it adds 4" and the shaft falls out. Not all the time, not every time, but I only use it about twice a year and it's easier just to take off the quick hitch for the day and know that the connection is solid.
/ L2501 and quick hitch question #7
Just to point out the obvious,
Whether or not an attachment (in this case a mower) is "Quick Hitch compatible", really has nothing at all to do with how long the pto shaft is, and vice versa.
It's referring to the pin and hook dimensions on how it connects to the hitch. Nothing really to do with the length of the pto shaft.
If the shaft has never been cut, it should be (maybe) fine. But each attachment needs to be checked, and shaft measured, the first time you try it.
After that, no biggie.
/ L2501 and quick hitch question #8
Hook it all up. No need to engage the pto until all the length testing is done. Mark the pto shaft with a marker at the point there the inner and outer tubes telescope over each other. Run the deck up and down, tilt the top link all the way in and out if your using a hydraulic top link. If its a manual top link then set it where your going to use it. Check your mark at each step. If your have at enough over lap then your should be good to go. The amount of overlap needed you could probably find in the pto shaft specs. A couple inches minimum of pto tube overlap, as pointed out above, might be just fine for the horsepower and use your indicating.
/ L2501 and quick hitch question #9
Take the QH back and get a set of pats , I did just that and am very happy , I change implements 4 or 5 times every weekend at my farm and it takes minutes,
/ L2501 and quick hitch question #10
There is absolutely NO WAY you can state that, he will have attach everything and measure for himself to be 100% sure. Getting it wrong can cost lots of many and leave a damaged tractor.
/ L2501 and quick hitch question #11
Well, if he has implements now and the hitch adds to the distance from the hitch to the implement, it is possible to make this statement.
Getting a new implement with a PTO shaft, now that's where I have to agree with you.
/ L2501 and quick hitch question #12
Read your statement again ken is correct with the quick hitch the shaft may be too short now the only way to know is if it is hooked up and lifted up and down to make sure it doesn’t fall out
/ L2501 and quick hitch question #13
I still stand by what I said. If the driveline fits without the QH and the QH adds distance between the tractor and the implement, then there is no reason to cut the driveline. The hitch may add up to 3" distance between the tractor and the implement. As long as there is at least 2" of shaft in the tube, then he is good to go. Any less, then he needs to get a longer driveline.
2012 Chevrolet Colorado Crew Cab Pickup Truck (A64194)
2012 Chevrolet...
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
2017 Chevrolet Impala Sedan (A64194)
2017 Chevrolet...
2025 LandHonor RGB-11-72W 72in Hydraulic Dual Cylinder Rock Grapple Bucket Skid Steer Attachment (A64553)
2025 LandHonor...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
2008 SUBARU LEGACY 4 DOOR SEDAN (A65054)
2008 SUBARU LEGACY...
