Source for "Kickout Ring" aka "Circular Cotter" ring/pin?
/ Source for "Kickout Ring" aka "Circular Cotter" ring/pin? #1
joea99
Marbletown NY
Kubota B21, JD 240GT
Looking for small quantity source for what are known as "kickout rings" a version of the circular cotter ring or pin. OD is a hair or two under 2 inches.
These are used to secure some pins on 3pt implements and I am bound to lose some one way or another. It is a lot easier to have spares on hand than to try and rig up a "it'll do for now" deal.
I've found some, but either too small or 100 minimum. There gotta be some, somewhere.
Turns out Kubota has a part number for it 67156-34340. So, that settles that. Except, being as cheap as I am, I'll keep looking for substitutes.
/ Source for "Kickout Ring" aka "Circular Cotter" ring/pin? #3
Check McMaster Carr. Should've a lot better prices:
Tried. A bit small.
/ Source for "Kickout Ring" aka "Circular Cotter" ring/pin? #5
I think what you are referring to is called a lynch pin and you can find them at almost every farm store or Tractor supply etc.
/ Source for "Kickout Ring" aka "Circular Cotter" ring/pin? #6
Sort of looks like they range from $2.25 to $2.75..... Bailing wire is probably only thing cheaper...
It's the shipping that gets me. I'll just order some next time I need other parts.
/ Source for "Kickout Ring" aka "Circular Cotter" ring/pin? #8
Not that I'd recommend it...
/ Source for "Kickout Ring" aka "Circular Cotter" ring/pin? #9
Harbor Freight assortment in the barn and no complaints...
I've got a box. Used a couple already, seem fine. I'd like them better if the pin had a flat on one side.
/ Source for "Kickout Ring" aka "Circular Cotter" ring/pin? #14
I have those rings on the 3PT hitch of my JD650 (NOT lynch pins)
I too was worried about loosing/destroying one,,
Then, I found a spring that looks like a giant screen door tension spring.
It is the right diameter (close enough) and correct wire size.
All I would have to do is cut 1.5 turns off of the spring with an angle grinder, and I would have a new ring
Best of all,, the cost is ZERO!! WOOT!!
Skid Steer Tree Boom (A65640)
Skid Steer Tree...
Hesston 3717 4-basket Pull-type Hay Tedder (A66408)
Hesston 3717...
Massey Ferguson 10 Square Baler (A65640)
Massey Ferguson 10...
(30) 3"x9' Steel Posts (A66408)
(30) 3"x9' Steel...
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
1986 Ford 7710 Tractor (A66285)
1986 Ford 7710...
