Source for "Kickout Ring" aka "Circular Cotter" ring/pin?
/ Source for "Kickout Ring" aka "Circular Cotter" ring/pin? #1
joea99
Marbletown NY
Kubota B21, JD 240GT
Looking for small quantity source for what are known as "kickout rings" a version of the circular cotter ring or pin. OD is a hair or two under 2 inches.
These are used to secure some pins on 3pt implements and I am bound to lose some one way or another. It is a lot easier to have spares on hand than to try and rig up a "it'll do for now" deal.
I've found some, but either too small or 100 minimum. There gotta be some, somewhere.
Turns out Kubota has a part number for it 67156-34340. So, that settles that. Except, being as cheap as I am, I'll keep looking for substitutes.
/ Source for "Kickout Ring" aka "Circular Cotter" ring/pin? #3
Check McMaster Carr. Should've a lot better prices:
Tried. A bit small.
/ Source for "Kickout Ring" aka "Circular Cotter" ring/pin? #5
I think what you are referring to is called a lynch pin and you can find them at almost every farm store or Tractor supply etc.
/ Source for "Kickout Ring" aka "Circular Cotter" ring/pin? #6
Sort of looks like they range from $2.25 to $2.75..... Bailing wire is probably only thing cheaper...
It's the shipping that gets me. I'll just order some next time I need other parts.
/ Source for "Kickout Ring" aka "Circular Cotter" ring/pin? #8
Not that I'd recommend it...
/ Source for "Kickout Ring" aka "Circular Cotter" ring/pin? #9
Harbor Freight assortment in the barn and no complaints...
I've got a box. Used a couple already, seem fine. I'd like them better if the pin had a flat on one side.
/ Source for "Kickout Ring" aka "Circular Cotter" ring/pin? #14
I have those rings on the 3PT hitch of my JD650 (NOT lynch pins)
I too was worried about loosing/destroying one,,
Then, I found a spring that looks like a giant screen door tension spring.
It is the right diameter (close enough) and correct wire size.
All I would have to do is cut 1.5 turns off of the spring with an angle grinder, and I would have a new ring
Best of all,, the cost is ZERO!! WOOT!!
New/Unused Wolverine 6 Way Dozer Blade (A65583)
New/Unused...
Cattle Feeder (A65640)
Mobark Beever M12RX Wood Chipper (A65579)
Mobark Beever...
Gehl RS6-34 (A64119)
2019 VOLVO L90H WHEEL LOADER (A65053)
2019 VOLVO L90H...
1991 Wilson Hopper Bottom Trailer (A66285)
1991 Wilson Hopper...
