Bobcat 331 joysticks
/ Bobcat 331 joysticks #1
kamakazisports
1998 Bobcat 331 MiniX
I have a ‘98 Bobcat 331 MiniX. I lost hydraulic control with the joysticks. Still have blade, driving & can pivot the boom with foot controllers. Blew ignition fuses just prior to losing hydraulics. Replaced fuse and limped out of excavation site. Tried using left joystick to swing & smoke billowed up from under seat. Disconnected battery. Checked wiring. Only found one wire slightly crimped. I’ll replace that. Seems to obviously be electrical issue. I’ve ordered new relays. Other than the console safety switch which I will check later, any other suggestions. Thanks in advance, Joe
/ Bobcat 331 joysticks #2
Did you ever figure this out ...i'm having the exact same issue with my 331.
2006 Chevrolet Express 2500 Cargo Van (A64556)
2006 Chevrolet...
S/A Utility Trailer (A64557)
S/A Utility...
2022 BOBCAT T76 SKID STEER (A65053)
2022 BOBCAT T76...
2022 EZ-GO ELITE...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
CATERPILLAR CB13 DOUBLE DRUM ROLLER (A65053)
CATERPILLAR CB13...
