2001 Bobcat 331
/ 2001 Bobcat 331 #1
Ctentprises
2001 bobcat 331
Hi, 2001 bobcat 331 excavator , hose that operates boom swing burst, it’s the hose that operated the cylinder under the floor plates. Replaced hose, bled cylinder , now the boom will not swing left to right, everything else operates as it should . First time owner and I’m stumped. Any help would be greatly appreciated.
/ 2001 Bobcat 331 #2
Welcome to TBN!
Not sure, but may have to bleed the pilot line for the swing valve or the swing line itself, although most cylinder circuits will bleed themselves
/ 2001 Bobcat 331 #3
I've got a 2002 Bobcat 331 and have a leaking hose for the boom swing cylinder. Did you have to remove the seat and controls in order to access the cylinder? I've removed the floor plate several times, to diagnose the leaking hose. Wondering if there is an easy way to access the hose ends of the cylinder that are under the seat. Thanks. Tim
2008 DRAGON  130BBL VACUUM TRAILER (A65643)
2008 DRAGON...
2023 CATERPILLAR 262D3 SKID STEER (A65053)
2023 CATERPILLAR...
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
1968 MTTI Lowboy Trailer (A62613)
1968 MTTI Lowboy...
EZ-Steer Controller and EZ-Steer Motor (A65640)
EZ-Steer...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
