Pot metal repair
/ Pot metal repair #1
rbstern
GA
LS MT225E, Yanmar 2210
This hinge is from the folding rear seat of my golf cart. Thought it was steel and I would weld it, but once I took it off, realized it's some sort of pot metal, probably zinc.
As a hinge, it does have to handle a bit of stress. Not huge, but enough that I want to figure out a repair that will hold up. Thickness is about 1/4".
Suggestions?
/ Pot metal repair #3
I'm with metalbender; depending on what tools you have available, I would take a piece of fairly heavy wall steel angle and "cut away anything that doesn't look like your original" - (using your broken one as a template)
A mill and a plasma cutter would make it pretty easy, but not the ONLY way to skin that cat... Steve
/ Pot metal repair #4
This would be a very easy piece to make up from steel any small fab shop or buddy with welder should be able to make this up in 20 minutes.
Danno
/ Pot metal repair #6
I've got some rod in the shop called Aladdin, it's for gas welding that kind of stuff (tig would probably work even better).
Best, of course, is fabbing up steel replacements, as the other side should be swapped out as well.
/ Pot metal repair #7
I'd see if it would take bronze braze. I've been surprised at how strong some brazed repairs I've made are.
/ Pot metal repair #8
“Pot” metal term comes from the fact that way back it was started by mixing a bunch of metals in a fire pot and cast. Thus, it is not a single thing like zinc. Likely has zinc, aluminum, lead and other things in it. Very hard to fix. make new.
/ Pot metal repair #9
Yep. Very easy as long as you have at least a drill press for the holes. Angle grinder with cutoff wheels to shape it and grind smooth. For a one-off part like this, you don't need a mill or plasma or anything fancy to get it done. Plus - No welding needed if you do it this way.
/ Pot metal repair #10
might take more than 20 minutes…..
You are right! The piece I would use is at the bottom of the scrap bin and it would take me an hour to get to it and then 20 minutes to make it. If the pot metal survived this long then a piece of steel plate with an ear welded on it will last forever.
Danno
/ Pot metal repair #11
From the picture...it looks like it would be simple to cut one out of a piece of angle iron...easy peasy...!
/ Pot metal repair #12
Rather than remove that much material from a piece of 1/4" angle, I would use 1/4" flat stock and make a "key" with the tab for the hinge pin as the bow or handle and the vertical stiffener at the edge of the drilled plate as the blade. Perhaps there is enough clearance that the "blade" could be as wide as the handle. Then weld the "key" along the edge of another piece of 1/4" flat stock for a new plate--fillet on the inside, corner joint on the outside.
/ Pot metal repair #13
With that being pot metal and containing a fair amount of zinc, be sure to look up "metal fume fever" before you attempt to weld on it.
/ Pot metal repair #14
Them hobo frate propane torch rods would do it.
/ Pot metal repair #15
I'd buff it clean, glue it together (JB Weld maybe). After it set I would then cut some small pieces of metal to cover the crack plus (for bracing), then glue them on with the strongest glue I have handy.
/ Pot metal repair
That is pretty close to what I did. I JB Welded and clamped the two pies together at the fracture. After it set, I trimmed a piece of angle iron as a reinforcement and JB Welded that to the fixture. I drilled and tapped the piece for bolts, one on each side of the break. Put bolts in the tapped holes, cut the excess off, ground them flush.
It's reinstalled and working perfectly.
/ Pot metal repair #20
Probably as good as you can get until you eventually build new.
2025 GIYI GY-P45 Hydraulic Breaker Mini Skid Steer Attachment (A64553)
2025 GIYI GY-P45...
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
2016 Ford Transit 350 Wagon Passenger Van (A64556)
2016 Ford Transit...
UNUSED FUTURE D39-39" MINI HYD TRENCHER (A65055)
UNUSED FUTURE...
KENMORE ELITE REFRIGERATOR/FREEZER (A65055)
KENMORE ELITE...
