/pine
Super Star Member
- Joined
- Mar 4, 2009
- Messages
- 15,059
From the picture...it looks like it would be simple to cut one out of a piece of angle iron...easy peasy...!
A mill and a plasma cutter would make it pretty easy, but not the ONLY way to skin that cat... Steve
I'd buff it clean, glue it together (JB Weld maybe). After it set I would then cut some small pieces of metal to cover the crack plus (for bracing), then glue them on with the strongest glue I have handy.
looks like cast aluminum to me. If ya have a welder making a steel replacement should be easy If you have a couple of propane torches and a steel vice bending one up is also doable.Thought it was steel
