Chainsaw scabbard
/ Chainsaw scabbard #1
coolbrze
Gold Member
VA
Kubota MX5800
Wanting to mount a chainsaw scabbard on my Kubota MX5800. I saw the SawHaul mounts/scabbards online & they look pretty good but my lift arms are slightly too big. Was thinking there may be another option to mount on the ROPS? Any other good mounts so I can carry my Stihl MS500i w/ 28" bar around easily & safely?
/ Chainsaw scabbard #2
This is what I did with cable ties & reinforced the sides and bottom with PVC than RTV them on.
/ Chainsaw scabbard #3
This works for me.
/ Chainsaw scabbard #4
You may or may not be aware of this, but the SawHaul kits actually come in a larger size for larger tractors. If you look at them on Amazon, the only option is the one standard size (too small). The larger size can be found at the link below. It basically comes with a larger u-bolt to clamp the larger loader arms.
SawHaul Complete Kit for Tractors
I bought the large kit, then decided I didn't like where it sat on the loader frame with u-bolt kit. I ended up drilling two small holes in my loader frame and mounting the scabbard using two 1/4" grade 8 bolts. If you chose to go this route, you'd just need to buy the base kit with your scabbard length of choice. I really like mine.
/ Chainsaw scabbard #5
anyone wanting ideas on how to carry a saw should look at this thread - 16 pages of how TBN'ers do it.
gg
/ Chainsaw scabbard #7
I made two of them from wood with a metal frame to attach it to the equipment. Pic is on a mini ex. Theres hardly room for a 6' tall person much less a 72cc saw with a 28in bar. It dosnt stick out of the rops and isnt in the way.
/ Chainsaw scabbard
Good stuff thanks everyone! Was hoping not to mount the 500i on the ROPS since I think it would be a PITA to get a 28" bar in & out all the time...
/ Chainsaw scabbard #9
I used a Saw Haul brand on my MX5400 with no modification. As I recall there was a version on the SawHaul site that was a perfect fit. It's a great piece of kit by the way.
/ Chainsaw scabbard #11
Either bucket or grapple. 40+ years without a problem. Recognize - I only carry a chain saw when I'm going out to do a job. It's not there all the time.
This is the way I carry most all my tools when going out on the property to do a job.
/ Chainsaw scabbard #12
I have the SawHaul on my MX. Works fine. No problem mounting
/ Chainsaw scabbard #16
Chainsaw and chain holder
Under customization topic.
/ Chainsaw scabbard #17
Wow. I even seen a setup that looks worse than mine in this thread! Mine holds two chainsaws. I just used the chainsaw to bore a slot into a treated wood piece. Two of them one on each side of the loader arm.
/ Chainsaw scabbard #18
Kubota M5640 - Plywood scabbard and go-to saw behind the loader post on one side.
Gas and oil under the loader valves on the other side.
Second longer saw and tool box in the back.
gg
2021 International HX620 Quint Dump (A62613)
2021 International...
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
211299 (A62131)
211299 (A62131)
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
2015 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2015 INTERNATIONAL...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
