Small towable graders?
/ Small towable graders? #1
Joel/ak
Bobcat 324
Anybody have luck with this kind of set up?. Our road is about a mile long and getting rough.
I've done the back dragging with the fel and used our back blade. It works to certain degree.
A few spots I gotta haul gravel in. Old railbed so the ground is solid.
/ Small towable graders? #2
Boy, a mile long I would at least have a land plane. My drive is only 200 feet so the DR grader would probably be enough for a yearly dressing.
/ Small towable graders? #3
Tractor time with time has a good videos on them. There is another guy from another channel that appears with him that apparently is the “grader” guru
/ Small towable graders? #4
York (the York Rake Company) has a series of rakes with drop down blades.
I have a 7 footer. Works OK if the road has enough moisture.
/ Small towable graders? #5
It is hard for me to believe a ground contact implement weighing 168 pounds, with some weight supported on two tires rather than ripping the road, will accomplish much.
This thing does NOT have a integral rear blade to pull material. It is just a light scarifier, which will bounce.
Greetings from SW MI
New here. My name is Joel and lived in SW MI for about 10 years now. We have a little bobcat 324 mini and a Massey Ferguson 1705 over glorified lawn mower.
Consider a Land Plane or Landscape Rake towed by your truck.
Bobcat 324 Compact (Mini) Excavator
https://www.bobcat.com › ... ›
324 Key Specifications ; Horsepower. 13.9 hp ; Operating Weight. 3,571 lb ; Bucket Digging Force. 3,620 lbf ; Maximum Reach at Ground Level. 14 ft ; Width. 38.6 in.
Massey Ferguson GC1705 Dimensions​
Subcompact Tractor
Wheelbase:57.1 inches
145 cm
Length:97.6 inches
247 cm
Width:47.25 inches
120 cm
Height (ROPS):72.8 inches
184 cm
Shiping weight:1433 lbs
650 kg
Ground clearance:6.7 inches
17 cm
I've done back dragging with the fel and used our back blade. It works to certain degree.
Tractor capability is more closely correlated to tractor weight than any other single (1) specification.
The larger wheels and tires on heavier COMPACT category tractors provide more tractive power pulling ground contact implements and logs, pushing a loader bucket into dirt and pushing snow. Larger wheels and tires permit heavier tractors to bridge holes, ruts and tree debris yielding higher operating speed with less implement and operator perturbation.
/ Small towable graders? #6
It is impossible to make worthwhile implement recommendations without knowing your current tractor brand and model.
1. Click on your "illuminated" screen name in upper right corner.
2. Click on SETTINGS in drop down box.
3. On left side of screen, click on ACCOUNT DETAILS.
4. Scroll down to TRACTOR.
If you add your LOCATION to your T-B-N PROFILE, so your location shows with every post your author, you will receive responses germane to your operating conditions.
4. Scroll down to LOCATION.
/ Small towable graders? #7
Consider a 880 pound to 2,600 pound Land Plane towed by your truck.
Consider a 400 pound Landscape Rake towed behind your truck.
Now you can make your SUV or Pick Up even more veratile by equipping it with a York Rake. Maintaining that long gravel driveway or camp road just got a whole lot easier. Simply attach the rake to your SUV or Pick Up via the 2" receiver hitch, attach one end of the control box to the electric/hydraulic cylinder, the other to a 12 volt power source and start raking. Unit is 8' wide and weighs 400lbs.
MORE: Landscape Rake or Land Plane for road site:tractorbynet.com
/ Small towable graders? #8
I made a set of gauge wheels for my blade and added wings on the side to keep the spoil from making humps exiting the sides of the blade. Now that I have a hydraulic top link fine grade control and keeping my driveway smooth is easy peasy.
/ Small towable graders? #9
Why does a mile long need a land plane?
/ Small towable graders? #10
This weights 168lbs. That's a lawn mower attachment not a subcompact attachment. I would look into something with more weight. It's also basicly a box blade on wheels. Dont you have a 3pt hitch?
/ Small towable graders? #11
It's basicly a box blade on wheels.
It is just a light scarifier. which will bounce.
/ Small towable graders? #12
The wheeled box blade would be worth looking into. I have seen some with tilt and with enough weight to do some work.
3 point attachments tend to follow the pot holes and bumps and get transferred to the tool attached to the tractor.
/ Small towable graders? #13
I didn't say "NEED", I said I would at least have a land plane....as a bare minimum. Depending how much traffic and condition of said road, a dedicated grader attachment like GEE RAY has suggested would be nice to have.
/ Small towable graders? #14
I missed that part. Geez that thing does look nearly useless.
It being so light and only have that thin blade I could see it making things worse.
/ Small towable graders? #15
What type of implement that will work best is directly related to the material and structure of the roadbed and surface topping...
A roadbed made from glacial till and packed down and top coated with gravel is much different than a roadbed made from graduated sized material...
This is why I asked. Alot of knowledge on here. Don't want to spend a grand if it won't work.
Was looking for something to tow behind sxs so it's "free floating" if you will. Like what was mentioned, 3 point just follows the tractor
/ Small towable graders? #17
Weight is key here to cut, gather and deposit a hard packed dirt (gravel) road. Simply moving around the loose gravel is a very short term solution. Depending on the condition, looking for a local guy with a road grader and having him dress up the ditches and re establish the crown could serve you well for quite a few years. 👍
/ Small towable graders? #18
That’s the channel I couldn’t remember the name of.
My neighbor has an actual road grader that's been sitting forever. He finally got it going and after about 30 minutes of use, he blew out alot of hydraulics for the belly blade. He had someone quote him $1200 for repairs. I should go in halves if I can use it.
/ Small towable graders? #20
We made us an adjustable box grader and bought a hydraulic top link. It will dig into the hardest gravel parking lot in mid summer. You know how the older you get, the harder you are to impress? I was using the grader on maiden voyage, and I was impressed. I figure it will carry 2 1/2 yards of dirt. Gravel road, it just smooths and gravel goes over the blades. I used it on many different ground types, can't say anything negative about it.
2017 Ram 5500 Bucket Truck (A63689)
2017 Ram 5500...
2014 Bobcat E63 (A64126)
2014 Bobcat E63...
2018 BOMAG BMP8500 TRENCH COMPACTOR (A64279)
2018 BOMAG BMP8500...
(1) UNUSED 12" RUBBER TRACK (A64280)
(1) UNUSED 12"...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
CRATE OF NEW PARTS (A64280)
CRATE OF NEW PARTS...
