Mahindra 4035pst value, and is this enough tractor for me?
/ Mahindra 4035pst value, and is this enough tractor for me? #1
LADPT
Louisiana
Kubota L4240 GST & Mahindra 4530
Background: Family has 3 40-60 acre properties ranging from 2-4 acre bahaia fields, pine timber, hardwood bottoms, food plots, 2 acre orchard, summer/fall gardening, gravel roads and mowed trails. Dad has a Mahindra 4530 4wd w/fel and Farmall planting/cultivating tractor, 6ft bush-hog and disc, box blade, small cultivator. These are rotated around to cut fields/trails, maintain roads and plant but primarily reside 20 minutes away at his place. The result is that many tasks get postponed bc equipment is somewhere else. The other 2 properties are my house and across the highway. I need a tractor to maintain my 1,000ft gravel driveway, cut trails, clean underbrush, maintain a developing orchard, landscaping, and hobby farm (corn, squash, watermelons, food plots, etc).
Local (5-10 mins away) dealers include Mahindra and JD. Most others are available within a 45-90min drive. I’d love a Mahindra 5145 but can’t swing it right now. Need to stay in the $20k range if at all possible.
Neighbor just put his 4035PST up for sale. Asking $20k and includes a Lowery LM60 5ft rototiller (doesn’t cover the tires 🤨). 2013, 381hrs, ML130 loader.
Is that a fair price? Seems a bit high looking at auctions the past year. More importantly, is that enough tractor?
I much prefer the CUT size and style to the larger 4530 I’m use to operating. I’m thinking in the back of my mind I could always sell it and go bigger if needed. But the 115cu displacement is much smaller than the 146cu of the 4530 or the 166cu of the 40 and 45 series. Is this a real concern? Anything else I should consider or look for on this particular tractor?
Thanks for having me here. I’ve been reading and researching here for several years and getting more ready to purchase everyday. Though I’m willing to keep waiting for the right tractor and deal.
/ Mahindra 4035pst value, and is this enough tractor for me? #2
Mahindra 4035 Dimensions​
Dimensions
Length:123.9 inches
314 cm
Width:73.7 inches
187 cm
Operating weight:4367 lbs
1980 kg (gear)
4817 lbs
2184 kg (hydro)
Mahindra 4530 Dimensions​
Dimensions
Length:134 inches
340 cm
Width:72.5 inches
184 cm
Weight:5567 lbs
2525 kg
Tractor capability is more closely correlated to tractor weight than any other single (1) specification.
Within subcompact and compact tractor categories, a significant tractor capability increase requires a bare tractor weight increase of 50%.
In real-life "field" conditions the ~700 pound difference between these two Mahindra models will be barely discernible.
Neighbor just put his 4035PST up for sale. Asking $20k and includes a Lowery LM60 5ft rototiller (doesn’t cover the tires 🤨). 2013, ===381hrs===, ML130 loader.
381 / 9 = 42 engine hours per year. Very low hours for nine years. Very light use.
If inside stored, rather than stored outside, looks to me like a very good offering.
If purchased from a dealer I presume you would pay 7% (?) Louisiana sales tax.
It was lightly used on a horse farm, mostly to move shavings, manure and work the riding arena per the owner.
It’s fairly pink, so I’m assuming not fully “indoors” though maybe had a roof over it.
Yes, would have to pay sales tax on new. Local dealer can order one. All he said was “over $30k”.
I’m not opposed to hitting the road to pick up a used tractor.
/ Mahindra 4035pst value, and is this enough tractor for me? #4
I recommend starting with the nearby $20,000 net, net (including Loader) 4035PST. You are much more likely to get "good" information from a nearby seller who knows he will see you after the sale, in the community.
Family has three, 40-60 acre properties.
Ask the seller if you can take the 4035 to your nearest property for a one day evaluation, returning before 5:00 PM. Return the tractor with the fuel tank full.
I would only consider Mahindra and Deere tractors.
Transporting a tractor for service is expensive and inconvenient, whether you trailer it or the dealer trailers it.
Brand? Models to look at or avoid? Buy new or used?
The design of the Three Point Hitch tractor has been marketed in the USA since 1939 -- 83 years in 2022.
The basic Three Point Hitch tractor design is generic.
Kubota and Deere have most of the market through 6,000 pound bare weight tractors. But this Kubota/Deere predominance is regional.
We have the following brands within an hour of us.
  • Kubota
  • LS
  • TYM
  • KIOTI
  • Massey Ferguson
  • John Deere
I know that a lot depends on the dealer and their willingness to help, but should I stay away from any of these brands?
Start with the nearest dealer and work out.
CREDIT: 'FELIXEDO'
"It has been touched on a couple of times, but not directly as a buying factor.
Every major make has a machine that will do the job(s) you want. Check out your nearby dealers, and go with one you have confidence in.
A great machine with no support nearby is a hassle to repair and maintain.
And a good machine can't make a lousy dealer into a good dealer."
This was the only thing I noticed on both sides. I’ll watch the video again to review. Thanks
/ Mahindra 4035pst value, and is this enough tractor for me? #6
What are you showing the readership in Post #5 ? ? ?
I’d love a Mahindra 5145.
Operating weight = 5,390 pounds
Is it the shiny, new paint? ? ?
I guess the dry-rotted missing rubber isn’t a big deal. Admittedly I have a lot to learn.
Lol yes, and warranty, but mostly HP. That’s my primary worry with this 4035. Will it turn a 6ft bushhog in thick bahaia? Probably similarly to the 4530 I guess. I’m confident a 10hp increase would be more evident though.
/ Mahindra 4035pst value, and is this enough tractor for me? #8
I am clueless. What part of the tractor or implement is in the photo?
Very marginal. You will be cutting a 48" to 60" swathe fairly often in thick Bahia. To cut a full 60" swathe at the time I would want 50 engine horsepower / 40 PTO horsepower.
Mahindra 4035 Power
Engine:40 hp
29.8 kW
PTO (claimed):33 hp
24.6 kW (gear)
31.5 hp
23.5 kW (hydro)
I’d love a Mahindra 5145. Better but still marginal.
5145 4WD
Engine HP 45 @ 2300
PTO HP ******************************38 @ 2300
/ Mahindra 4035pst value, and is this enough tractor for me? #10
I have this exact same tractor, Mahindra 4035 PST (2015), and use it frequently. I do all of what you are wanting to do with the tractor, and it has never let me down. I've brush hogged grass that was taller than me, but I did have to drop down a gear, to Low 3. I use it to clear snow in the winter on a 600 ft driveway, something you won't run into. As to the torn boots on the front steering, mine are the same way, I intend to replace them with a CV joint repair kit that you can buy online. Overall its been a very good tractor, that has dragged trees much larger than I would have imagined.
Well, thanks for the assistance. Had a test drive setup for this afternoon and just got a text it has sold. Back to the drawing board.
Found a 5545 semi-locally I’m planning to drive this evening if the rain quits. Almost exactly the same as my dad’s 4530, just newer, 2019, and with my preferred R4 tires. 2 concerns are: 6ft implements might not fully cover the tires, and I’m not a huge fan of the syncro shuttle. But in this hp range, PST and Hydrostatic cost several thousand more.
Anything particular I need to look over on this model besides regular stuff? Thanks
/ Mahindra 4035pst value, and is this enough tractor for me? #13
I would check with Clif Jones on the Mahindra 5145 or 5155 (turbo) they were quoting sub 30K to me on the 5145 with FEL recently. used is tuff right now, but if you wait a year that may change for the better.
/ Mahindra 4035pst value, and is this enough tractor for me? #14
I prefer the Sync Shuttle myself but YMMV. good luck
Thanks. The 5545 is 2019, 491hrs, 3rd function in front (he was running a grapple). Comes with bucket, 6ft MD bushhog and 6ft box blade for $20k
I like the 5145 for sure. Local dealer wanted $32k, another for $35k. Did see the states only volume dealer had it for $28k….plus tax.
/ Mahindra 4035pst value, and is this enough tractor for me? #16
I would say that is a bargain if the tractor wasnt wreckedor something, low hrs 2019, i would jump on it.
/ Mahindra 4035pst value, and is this enough tractor for me? #17
looks like a good deal, good luck
Somebody else bought before I finished work.
Used market is crazy right now. Think I might take a break for a while.
/ Mahindra 4035pst value, and is this enough tractor for me? #19
I feel your pain i went thru 8 months of shopping and trying to beat everyone else to the good deals, but working full time keeps me from being competitive. all used deals were 3/4 the price of new. I finally got the best deal i could on a new tractor and with the 0% offered by mahindra i call it a wash. it is also nice to know that you have a warranty for 5 years. another nice part about buying new is you can concentrate on the right tractor for you not what you can get if you buy right now.
/ Mahindra 4035pst value, and is this enough tractor for me? #20
Take a trip to Clif jones they are a supporter here and have some good deals. talk to Henry, he is a very motivated salesman. but i would recommend spending some time sitting on tractors. I would also look at the local LS dealer for comparison, MT3 / 4 series, they have some nice tractors with lots of features for good prices.
what ever you decide good luck
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
Electric Golf Cart (A56859)
Electric Golf Cart...
2014 BMW 28I AWD SUV (A61569)
2014 BMW 28I AWD...
Kubota MX5400 land mgmt package
Kubota MX5400 land...
