which sanding pads?
/ which sanding pads? #1
ArlyA
Super Star Member
Houghton MI (the Lake Superior snow belt) USA
Outlander1000 6x6, Ego lawn mower and shopping for tractor
We have some large picnic tables we care for which are located at remote locations. The finish is starting to peel so they need to be scraped, buffed and refinished. For cleaning and buffing them I thought I'd bring my generator so I could use my 4.5 angle grinder to do that job with. We'd then blow them off with air compressor when done. What pads might we use? I thought about trying these soft pads in 120 grit.
FPPO 5Pcs 4.5" x 7/8" Nylon Fiber Flap Disc Polishing Grinding Wheel,Scouring pad Buffing Wheel for Angle Grinder, Polishing Tools (Grit 120)
/ which sanding pads? #2
Those work out to be about $2.80 each at the price I saw. Normal orbital sander pads are anywhere from .40 each to maybe $1.80 each. At the rate you may be going through pads, I'd suggest you buy an orbital pad sander. The orbital action is going to be more efficient at sanding. The sander itself will be easier to control just using one hand.
I'd also recommend buying both 80 grit and 120 grit. Outdoor wood may need more aggressive sanding to clean up followed by the 120 to get it smooth. Orbital sander pads use hook and loop fastening so they will be much faster to change than changing pads on an angle grinder.
I only have used a corded orbital sander. Can't really speak to whether it would make sense to pick up a cordless version so you don't have to carry a generator or listen to the noise. But I would encourage you to look into a cordless sander if you already have batteries for a cordless drill or other tool.
/ which sanding pads? #3
I've never tried what you showed a picture of.
For sanding flat wood and making it look nice, I use a 5 inch random orbital sander with the 3M disks from Lowes, which are sold in their paint department. For some reason, they do not have them in their tool area where all the other sanding stuff is. They are purple. You'll find that for outdoor projects, starting with the most aggressive disks that you can find will really speed things up. I think 40 grit is what I always buy from them when sanding the exterior of a house. You can always go over it with something finer, but I think you'll find that 40 grit on an outdoor table will do a pretty good job.
If you have something that you really need to remove a lot of material on, Shop Smith has the best flapper disks that I've found. I use them on cedar logs, and they are amazing!!!!
Never buy Gator or Craftsman, they are the worse!!!!!
/ which sanding pads? #4
I would have trouble making the surface level with an angle grinder. I have also not used a flapper disk, but I doubt it would remove paint, - 40 or 60 grit usely does that better. Also, I like a flat sander. Like an orbital sander. I use an old Porter Cable 505. I might use paint remover first, then sand, then treat with an oil preservative like Penofin. I hat removing paint. Not very good at it.
The stain used here before is not being removed, just loose stuff ground off and surface abraided for the next coat. It's the stain type that's nearly like paint which I don't like but I'm redoing it after the fact. If you note another thread here was about poor performance of water based stains.
Those sanding pads I showed are made for running flat, not on there edge like most are.
/ which sanding pads? #7
like ljjhouser said a angle grinder will leave uneven marks or dents, for logs id uses a angle grinder but for planks I always uses a belt sander or a orbital palm sander ... I really like palm sander they are really ergonomic to use.
/ which sanding pads? #8
Back in the day, there were rotary sanders that left swirl marks in the finish and there were belt sanders that were faster, but also left sanding marks. Orbital sanders had and have the advantage of being faster than a rotary sander and the orbital action helps reduce obvious sanding marks on the finish.
The typical outdoor table at our local recreation areas would have a lot of weather checking and would have a lot of surface area to be sanded.
Depending on how bad the finish is, a belt sander might even be worth considering.
/ which sanding pads? #10
Angie grinders with flat sanding disks are great. I usually use a big 9" grinder but the 4.5" ones work fine. It is easy to leave gouges and low spots with the 4.5" grinders. Perhaps start on places you can't see and finish with the top.
Those scrubby pad sanding disks look intriguing, like they could work well. Flap disks work better on metal. Flap disks work better on metal. For the 4.5" grinders they sell these little flexible rubber cups that work pretty well for screwing down the sanding disks. The stiff plastic ones are fine but the rubber ones are better.
Here in the jungle rough cut fuzzy wood is all we get. Planers are all right but forget belt sanders and palm sanders are just for prepping before paint, and sanding between coats of varnish. Angle grinders is how we get anything done in one day. They do leave a circular pattern in the wood but Imyou can get used to that, and you can soften it with a quick pass from a palm sander. They do the job *fast* which makes any imperfections seem less terrible. 1/2 hour into the job with scrapers and orbital sanders you might find yourself reaching for the grinder and a 80 grit disk.
Those 4.5 disks I showed are flat and made to be used flat, not at a angle or on its edge. Nonetheless, the guys here convinced me to use my 4x24 belt sander. 😅
/ which sanding pads? #13
3M Xtract Cubitron II Net Disc, for me, sanding a deck with a ROS, they lasted a long time. But if your going Belt I'd go with a 3M product.
/edit - I've a big sanding project planned so I started doing more research
is a very large test and there is a great graph at 12min 38 sec.
Klingspor comes in behind 3M Cubitron.
Unfortunately the only lengths the 4" wide 3M™ Cubitron™ II Cloth Belt 970DZ comes in are 90 and 91 inches, :(
Maybe try Abrasives - Belts - 4" Belts - Page 1 - Klingspor's Woodworking Shop
/ which sanding pads? #15
My house is cedar plank. After trying many products - semi-gloss OIL stain is the best. It completely soaks in and provides, at least, ten years of protection. To reapply - simply hose off the walls - give it a week to dry - reapply. No sanding required what-so-ever.
But the original finish was a water base something, so I thought I'd have to stick with that. I actually have nearly a full gallon of it
/ which sanding pads? #17
What is the brand and type of stain. Stains weather oil or water soak into the wood and should never peel. Only top coats peel. Does it have a sealer in the stain? Show pictures of what u want to remove. Most outdoor stains are made to be reapplied many times over without sanding between coats. Those are the only ones I use. 🍻
If you ask this question in the looking for a better stain thread. I would address it.
/ which sanding pads? #19
I have grinders, a belt sander and a DeWalt 1/4 sheet palm sander. I'd try the palm sander. It is the one that will sand evenly without gouging.
Hey folks, I own every type of sander previously mentioned. This is outdoor park furniture so speed and durability of finish is the important thing. A belt sander will be tried.
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
Sakai SW354 (A60462)
2022 Braxton Creek Freesolo KITCH 18 ft Travel Trailer (A61574)
2022 Braxton Creek...
2012 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2012 Chevrolet...
UNUSED WOLVERINE HYD MINI STUMP GRAPPLE (A64281)
UNUSED WOLVERINE...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
