Replaced the outdated fuse panel in my YM2000 tonight
/ Replaced the outdated fuse panel in my YM2000 tonight #1
treedawg
Dublin, GA
Kubota M6800, Yanmar YM2000
Purchased the fuse box conversion kit from Hoye.
FUSE BOX CONVERSION - CONVERT TO NORMAL BLADE FUSES!: Yanmar Tractor Parts
I was torn between it and the generic replacement for about 1/4 the cost from Amazon or Ebay.
I'm glad I purchased the kit from Hoye. It was direct fit and was shipped with clear instructions.
I had to remove the fuel tank but that wasn't that difficult.
td
/ Replaced the outdated fuse panel in my YM2000 tonight #2
I did the later route. I have an install post somewhere on here. It does make a cleaner look and looks neater. And uou can get the fuses at the gas station or auto parts place or walmart if you need them
You installed a generic fuse panel..??
How bad was it to install..??
I can be painfully but I already had an order going with Hoye so I added the fuse panel conversion to my order.
I really want to add the LED headlight conversion but I can't bring myself to pay $100.00 since I rarely use the headlights anyway.
td
/ Replaced the outdated fuse panel in my YM2000 tonight #4
Yea I ordered one off eBay for like $2.50. It's the exact same thing. I just had to supply my own connectors and source my own bolts to bolt it down. It was no harder to install than the one you put in. There basically the exact same.
/ Replaced the outdated fuse panel in my YM2000 tonight #6
still have the yanmar original. Never had a reason to replace mine
The electrical wiring was jacked up on my tractor and a couple of the old fuses were blown.
The ignition switch wasn't properly connected, none of the dummy lights nor driving lights operated. I didn't even have power to the fuse block.
I wanted to modernize as I corrected issues created from past hack mechanics.
Even the horn works now which will come in handy if I ever find myself stuck behind a slower tractor :)
td
/ Replaced the outdated fuse panel in my YM2000 tonight #8
Mine had solder wrapped around the screws for fuses. Those vibrated in two and stuff would sometimes work and sometimes not. Then I ordered the right fuses from Hoye but they were to long and they were bunched up in the middle. I didn't like how that looked, so I changed it out.
/ Replaced the outdated fuse panel in my YM2000 tonight #10
my fuse box is pretty much hidden. I really never see it unless I'm looking for it.
Fuse block has a cover over the fuses. Pop the cover off to replace the old tube fuses
/ Replaced the outdated fuse panel in my YM2000 tonight #11
Ahh so yours had tube fuses? Mine had the little foil yanmar obsolete fuses. If I had glass I too would leave it. Mine was hidden under the dash with a cover as well.
/ Replaced the outdated fuse panel in my YM2000 tonight #12
My YM240 fuse panel was open and covered with years of crud. I destroyed the tiny bare wire fuses with the pressure washer before I recognized them. :mad:
My repair wasn't elegant but it got me running again the same afternoon and the panel has never needed attention again: I already had some glass tube fuse holders and the correct amperage fuses on hand so I installed these fuseholders across where the old fuses had been. "Good enough for the girls I go with", to quote an old Carpenter buddy. :D
Note I'm not recommending this method to anyone.
I still have the old OEM fuse block if anybody wants/needs it. I think it still has one or two good wire fuses in it.
Price is free you pay shipping.
td
/ Replaced the outdated fuse panel in my YM2000 tonight #14
yes , mie has the glass tune fuses. Never seen what you are talking about. Mine looks to be original
Mine also had the obsolete foil fuses.
td
/ Replaced the outdated fuse panel in my YM2000 tonight #16
I will go to my cabinet in a bit and pull the factory fuse block out.
/ Replaced the outdated fuse panel in my YM2000 tonight #18
Dang it , I forgot. Going out in the dark!
/ Replaced the outdated fuse panel in my YM2000 tonight #19
I can't see how to add pics and I am on my phone and I just took them with my phone? Will bee later when I get on a computer when I post them. Slayer may have a pic or if you really have to see them PM me your cell# or an email address and I will send them to you. Ha!
/ Replaced the outdated fuse panel in my YM2000 tonight #20
td
can you post a copy of the clear instructions? thank you or send me a copy at rodneyvanalstine@yahoo.com.
2012 International Prostar (A61306)
2012 International...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
12' CONTAINER (A60432)
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
2019 Dodge Charger Sedan (A59231)
2019 Dodge Charger...
2017 Toyota Camry Hybrid Sedan (A59231)
2017 Toyota Camry...
