tank sprayer suggestions?
/ tank sprayer suggestions? #41
What do you guys use to kill weeds with? I have a back pack sprayer but just doing my drive way i have to fill it up multiple times. I have weeds and grass that grows in the middle of my gravel driveway which is 1,300 feet long and that is not even counting the fence line.
I have a Kubota b tractor but i have been toying with the idea of buying a ATV and putting a tank on the back of the racks. Seems like the most maneuverable way?
A 55 gal drum laying on its side on a homemade trailer using some old motorcycle tires and a 12v RV pump. You could make a sprayer bar off the back and just motor along slowly and if you put a valve in you could have a hand held sprayer also.. Easy to build project
/ tank sprayer suggestions? #42
I just figured up the cost to fill a 25 gal tank with weed killer! I use round up Concentrate Plus and it says to use 6 oz. per gallon of water on hard to kill weeds so 6x25 is 150 oz.
64 oz cost me $37.
I'm gonna have to go to the local farm store and find something cheaper. I'm not pay over $100 just to kill weeds!
It's not cheap. I use the generic 41% glyphosate from TSC, 2 1/2 gallons is $135. I mix 1 11/2 gallons to a 25 gallon tank for a 6% mix. For the arena and driveway I mix in Mojave 70 soil sterilizer, kills everything for 1 year. I am able to get the Mojave at my local farm supply for $70. The glyphosate gives me a quick kill and the Mojave keeps it from coming back, that way I only spray once a year.
/ tank sprayer suggestions? #43
I have all the different types of sprayer setups in this post that I use on the farm. They all have their strengths and weaknesses. One thing I would like to add is about sprayer maintenance. After each use I always rinse with water and run the water through the pump and nozzles. For outside storage and before the first winter freeze I pump 50/50 antifreeze through the pump, wand and nozzles. If I forget to do the antifreeze I always have problems in the spring with the roller pump.
For driveways I use 2 oz/gal glyphosate plus 1 oz/gal 2,4-D. I buy the 2.5 gal jugs at TSC. In Summertime have to spray the driveways every month or so depending on the weather.
For fencerows I use 2 oz/gal Crossbow.
For pasture I use 2 oz/gal 2,4-D.
So i went to TSC and they had
Amine 400 2,4 D weed killer one gal dont get price
farmworks 41% glyphosate for $124 2.5 gal
compare N Save 41% glyphosate 1gal for $49.99
All i really need to kill weeds is glyphosate rite? From what i have read using only glyphosate takes longer for the weeds to die.
local farm store was closed
/ tank sprayer suggestions? #45
I add a surfactant to glyphosate.
I think Roundup already has it in the formula.
I don’t know if it helps or not but it kills most weeds fast.
/ tank sprayer suggestions? #46
Roundup does have the surfactant. You can buy it like this or some people use dishwashing liguid. That tends to cause foam.
/ tank sprayer suggestions? #49
For a quick kill on most weeds (not crab grass) I use Amine from TSC. For fence row, road edges, etc I use Gly 41%, and for my lawn I use a PRE-emergent that prevents almost all of them from coming up at all.
If you have a bumper crop of crab grass, you should try MSMA+. (esp if in your lawn) It's the one thing that I found that will actually kill it. It's not readily available in all states, and won't be available from TSC. I get mine on line.
/ tank sprayer suggestions? #50
What do you use to stop leaks on tank sprayers'? My tank sprayer hand wand leaks it has a hose clamp around it it's tight but still leaks.
/ tank sprayer suggestions? #55
Where the hose attaches to the wand, the wand fitting is a compression(tapered bore). Cut the end off and reassemble it. The end most likely has become hard from age.
208315 (A58376)
208315 (A58376)
207280 (A52708)
207280 (A52708)
(INOP) 2004 PETERBILT 378 T/A DAY CAB ROAD TRACTOR (A62130)
(INOP) 2004...
John Deere 2355 Tractor (A61166)
John Deere 2355...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
429133 (A61165)
429133 (A61165)
