Steel Cutting Chop Saw
/ Steel Cutting Chop Saw #21
I have had a Dewalt abrasive chop saw for over 10 years. No issues with it at all. I just keep a spare disc around. That reminds me I used my spare disc I need to get a new one. I did have one explode and bounce off my face one time haha. That didn’t turn out too bad I just had a couple small cuts.
/ Steel Cutting Chop Saw #22
I have 2 of the Evolution saws the 10" hand held and a 14" cutoff one.
They both work very well.
I have over worked the 10". We had to replace the finger sections in an ag bagger that was some 3/4" plate,
we cut the plate and the weld to remove the sections, we did 2 saw passes maybe an 1/8" apart to remove the originals.
I've only used the 14" cutoff once so far but it worked quite well.
Amazing to cut 3/8" flat stock and then being able to pick up the fresh cut pieces and not burn yourself.
A nice clean cut straight and square with no heat buildup in the material.
/ Steel Cutting Chop Saw #23
I bought one about 2 years ago - very glad I got it. Works perfectly, and is quick and accurate. I would buy it again.
Lou and Code 54...which model? There currently are two..one has a stamped deck and the other is cast and with a bit more of a detent system to set for angles...at a premium of $100.
/ Steel Cutting Chop Saw #25
My cutoff saw is the EVOSAW 380, I'll have to check my other one when I out and about the farm.
/ Steel Cutting Chop Saw #26
You hit on a good point - the blades make a big difference. (At least for abrasive blades). I like the Everett abrasive blades; cut fast and never an issue with one.
/ Steel Cutting Chop Saw #27
Where I work I had the shop (CNC machine shop) buy the Evolution S355 CPSL 14 inch saw with the appropriate blades for cutting stainless steel (300, 400, 17-4). They've been using it heavily for about a year and they like it better than the band saw and the cold saw.
/ Steel Cutting Chop Saw #28
14" stamped deck - I only use it for hobby work and stuff around the house, but I can't say it has given me any problems at all. It works really well and is 100x better than abrasive blade saws.
Guys,
Thank you all for your opinions. As always, TBN is the best site when you need a lot of different views. I ended up ordering the Evo 380. More money than I wanted to spend but figured maybe one of my grandsons will appreciate it some day.
Auger and Bit (A60352)
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
2018 Kubota SVL95-2S (A60462)
2018 Kubota...
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
2013 John Deere 333E (A60462)
2013 John Deere...
4ft Mini Skid Quick Attach Rotary Cutter (A61307)
4ft Mini Skid...
