New Oregon Gator Blades
/ New Oregon Gator Blades #1
BravoXray
Elite Member
Nothern Indiana
Kubota BX2230, John Deere 430 Diesel
Installed a set of Oregon Gator blades on my BX. I also leveled the deck, it was 1/2" high on the right side, greased all the spindles, idler pulley, center pivot, gauge wheels, and checked the oil in the gearbox. It's good to go for the rest of the season, if we get enough rain to make the grass grow. After an unusually wet spring, it's been almost two weeks with no rain, and looks like it might be a couple more before we get any decent amount.
/ New Oregon Gator Blades #2
Installed a set of Oregon Gator blades on my BX. I also leveled the deck, it was 1/2" high on the right side, greased all the spindles, idler pulley, center pivot, gauge wheels, and checked the oil in the gearbox. It's good the go for the rest of the season, if we get enough rain to make the grass grow. After an unusually wet spring, it's been almost two weeks with no rain, and looks like it might be a couple more before we get any decent amount.View attachment 751455
Nice!
I been running Gator blades for a few years now on my mowers, their also great for mulching leaves
/ New Oregon Gator Blades #3
I run those blades on my ZTR and they have worked really, really well. Very stout.
/ New Oregon Gator Blades #4
I also put Oregon Gator blades on my 6' finish mower:
The view from the seat with the deck raised:
/ New Oregon Gator Blades #6
Yeh nice! I got those gators on my bradley stander. Awesome blades year round other than early spring...they tend to make a mess of the clipping then. In the fall, they'll mulch leaves well enough w/o even having to block the chute.
/ New Oregon Gator Blades #7
I run them on my ZTR...great blades and they last a LONG time.
/ New Oregon Gator Blades #8
I am thinking of something that will help on my X738 mower and mulching blades might help my build up of clippings, I'd think. Are these resharpenable or require anything too funky to sharpen?
/ New Oregon Gator Blades #9
The leading (cutting) edge is a normal blade and can be sharpened like any other. The mulching fins (the trailing edge) don't get sharpened. These have a lot of uplift. If you have sandy soil, the mulching edge can get eroded fairly quickly. I've been using them for years. I like them for the uplift and leaf mulching. I have some reservations about how much they really mulch the grass, but I do like the blades.
Well, today I finally got to put the Gator blades to the test. They run nice and smooth, so they must be balanced pretty well, and cut really nice. A couple of things I noticed was that they kick a lot of cuttings out of the left front corner of the deck which then pile up on the deck itself and even up onto the floor of the tractor, and they cut 99% of the buckhorn. the old blades left about half of the buckhorn standing, even when the blades were freshly sharpened and running the same speed. Now the yard was pretty dry today, so if that makes a difference or not, I don't know. It was so bad that clippings got into the radiator screen and plugged it up making the engine overheat. I've never seen the temp gauge above a quarter of the way up on the dial, but it got up into the red before I noticed it. I let it cool off and pulled the battery cover and radiator screen and blew them out, then put my long reach nozzle on the air hose and blew the radiator out from both directions. It had pushed some coolant out so I refilled that and everything was back to normal.
But yes, the blades to a great job of cutting grass and do seem to cut it up finer than the stock blades do..
/ New Oregon Gator Blades #13
sounds like the gators are working well for those using, glad a good match is made.
in my own personal use (54" zero turn) i have not been impressed w/Or gator blades & have resorted going back to cheaper blade that i sharpen/replace often. they do just as well as gators. i can get 3 sets for the price of a gator. ramps & impact wrench make it easy.
it's only my opinion, not advising anyone to change over from the gator craze described here, respectfully
/ New Oregon Gator Blades #14
Think the OP will like the gator blade performance.
We use a 6’ woods 3pt finish mower for lawns, orchard and berry patches. Limbs, roots and rocks are common. Switched to G5 gator blades years ago. Using 20-26hp tractor on tough hilly land could notice having a little more power mowing. We like the bigger mower on a small tractor for trimming reach. Thinner blade 0.2 vs 0.25”? Less lift? They give a well chopped mulched clippings out the rear discharge that doesn’t require raking. Good at mulching leaves. Little bit cheaper than OEM blades and cutting edge last a little longer. Two bolt blade attachment has limited manufacturer options.
Properly adjusting any mowing deck important for the best cut.
/ New Oregon Gator Blades #15
Hi lift blades generally give a great cut, but the application is different. Hi lifts won't mulch leaves/grass clipping, gators will. I like gators especially if I'm slacking on mowing, coz they'll chop up those clippings.
/ New Oregon Gator Blades #16
good point, actually didn't realize that difference. each tool has an application. thx
/ New Oregon Gator Blades #17
Man, there's so much variation out there, there's a whole science to what blade works best with which type of deck, notched hi-lifts vs non-notched...there's a rabbit hole to go down into with this stuff (ask me how I know). Wright Mowers has a few great vids going into some of that.
But most commercial landscapers use hi lifts for a reason though...gives a great cut, better than any other blade. If you're consistently mowing (and know your yard doesn't have a bunch of junk in it), hi lifts for sure.
2007 Mack CV713 Granite T/A Pole Truck (A62679)
2007 Mack CV713...
JOHN DEERE 1700 - 8R30" VACUUM PLANTERS (A63291)
JOHN DEERE 1700 -...
Bobcat Skidsteer (A60352)
Bobcat Skidsteer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2025 SF60 60in Hydraulic Side Shift Forks Skid Steer Attachment (A61572)
2025 SF60 60in...
