Water in fuel causes $10,000 damage to my Kubota Grand L6060
/ Water in fuel causes $10,000 damage to my Kubota Grand L6060 #21
I did $6,500 injector job on one of my Kubotas last fall. First time in my life I ever replaced diesel injectors in 35 years. 3 of 4 failed and the one that didn’t was “marginal”. $1,000 to have them tested. Each injector was $1,000 and then there’s labor and other small parts. The Denso injectors cannot be rebuilt.
IMO, the Kubota fuel water separator, the fuel filter and the fuel system in general is a mickey mouse system. Even on my 130HP Kubota, the fuel/water separator is virtually the same as on one of the Kubota 25HP tractors.
My AGCO’s and my Case-IH MX have 2 filters with a separator and a sensor for warning the operator there’s water in the fuel.
/ Water in fuel causes $10,000 damage to my Kubota Grand L6060 #23
Ouch. I'm sorry that happened to you. Expensive equipment often has expensive repair bills. Hopefully your misfortune will help someone else avoid a similar fate. Thanks for sharing.
/ Water in fuel causes $10,000 damage to my Kubota Grand L6060 #24
Glad you had KTAC insurance to cover that. We use a big Mr Funnel to strain water out when filling the tractors
I use mr funnel also. It does waste some fuel, but I just dump the residual in the bottom of the funnel into a fuel can that I use to burn brush piles.
/ Water in fuel causes $10,000 damage to my Kubota Grand L6060 #25
Look at where the air breather is on your fuel tanks that you supply your tractor with. The one on my generator's tank was just a small elbow mounted on top the tank. I quickly put a piece of rubber tubing on it and have it up about mid block on the engine so that it will not catch any water when I wash off the top of the tank.
I recently checked that tank with an oil extractor after finding water in the gearbox of my brush hog. No water.
/ Water in fuel causes $10,000 damage to my Kubota Grand L6060 #26
Yes, it is. On the T4 final units, the fuel needs 'polished' moreso than a pre 4 unit. Why I suggest a Racor or similar unit in the fuel supply system before the electronically controlled injection system. The Racor comes with an on board water sensor that can be wired to a dash light too.
Kubota needs to 'up it's game' as far as fuel 'polishing' on it's late model tractors.
/ Water in fuel causes $10,000 damage to my Kubota Grand L6060 #27
Interesting comment. When I had both of my Kubota's 'tuned up', Dennis pulled the injectors and spray tested them on the stand and replaced them and the cups and charged me the labor rate plus parts and they were all fine. Not even close to 6500 bucks. Far as replacement-rebuild, don't know because all 8 of mine were fine.
I have been fighting fuel issues for years. I do have the Goldenrod filter on my nurse tank. Today, I will try to find their 'water block' filter. I just don't understand what I'm doing wrong. Here are a couple of threads I started in the past concerning my issues.
The mechanic did tell me not to put additives in the tank, because it does not remove the water, but only dissolves it, and it still gets into the tractor's fuel system. I'm not sure if that is totally correct.
/ Water in fuel causes $10,000 damage to my Kubota Grand L6060 #29
Just something I’ll throw out and I’m not saying this happened. I know someone that had problems with a diesel pick up, 6.7 Cummins. Like all high pressure common rails, they can eat injectors and are expensive. He was a contractor and burned a lot of fuel. His Cummins ate injectors at low miles, as in 10,000 miles. They said he had water in his fuel and showed him a jar of contaminated fuel. I always wondered if they kept that same jar of bad fuel and used it over and over to show people.
/ Water in fuel causes $10,000 damage to my Kubota Grand L6060 #30
I bottom drain my bulk tank regularly, draining off an accumulated gook and that goes on the burn pile as accelerant. Any bulk tank that isn't full to the top will collect moisture inside as the it condenses on the interior walls due to temperature changes (just like a cold drink container will 'sweat' on the outside because the contents is colder than the ambient air on the outside). Same thing happens inside a storage tank. Why I always add a biocide, in my case I use Powerservice Bio-Kleen and I also add Powerservice white or silver label diesel additive as well.
They all sweat inside, cannot get around that. Fact of storing diesel.
/ Water in fuel causes $10,000 damage to my Kubota Grand L6060 #31
I presume (don't know for sure because neither of my Kubota's are T4 final units), that, the T4 units are much more sensitive to contaminated fuel than the pre 4 units. Both mine are conventional high pressure injection via a Bosch style injection pump, No common rail, no electronics, the only electrical component on mine is the fuel cut solenoid.
This is the product that I add to my nurse tank almost every time I fill it.
/ Water in fuel causes $10,000 damage to my Kubota Grand L6060 #33
Never used that actually, Being the fact that where you reside is prone to high ambient moisture with cool nights and warm days, I suspect you are collecting condensation in your storage tank. Like I said, I bottom drain off the accumulated gook regularly. Nice thing is, it all settles to the bottom and my pump pick up tube is 6" off the bottom of my bulk tank. One thin g you really have to do is use the correct dosage too. Too little does nothing, too much does nothing either.
/ Water in fuel causes $10,000 damage to my Kubota Grand L6060 #34
Bummer on the issue!
Didn't we have a member from Alaska with the same issue on the same,or similar tractor last year?
He had more like 2500 hours though.
Everything failed, according to Kubota the ECU, pump and pretty much every other Injection related part.
jmo but can't see gambling on a new Kubota without also purchasing KTAC
$10000 for a single repair of what is a low hour tractor is not a gamble worth taking for a single repair.
These failures read a bit like CP 4 pump failures the big 3 HD truck manufacturers have been going through. RAM went back to the reliable CP3 Pumps in 2021. When a CP 4 pump fails it generally shrapnels everything down the line
Not real sure what Kubota is using but thought it was a Denso system?
EDIT: So after re reading the other thread KTAC does NOT Cover this kind of failure,
Kubota Extended Warranty was mentioned though.
/ Water in fuel causes $10,000 damage to my Kubota Grand L6060 #35
Mr. Funnel is supposed to be good for removing water. It makes refueling rather slow though.
/ Water in fuel causes $10,000 damage to my Kubota Grand L6060 #37
On our old school mechanical injection fuel systems,additives that emulsify the water in the fuel to be burned up in the combustion chamber were fine.
New high pressure common rail injectors can't deal with any water.
The high pressure will boil off the water and leave the injector with no lubrication.
The current thinking is to drop the water out of suspension before it makes it way to the injectors.
/ Water in fuel causes $10,000 damage to my Kubota Grand L6060 #38
Like the title says, water in fuel caused me a $10,000 repair bill to my 2017 Grand L6060 with about 1200 hours on it. The water caused rust in the fuel rail which caused damage to the injectors. I have had fuel problems with this tractor since its new.
I have a 100 gal. nurse tank that I use to fuel my tractors. I assume that condensation is happening in this tank. I do add a fuel 'cleaner' to each 100 gallons I put in the nurse tank. I guess this is mostly my fault, because I don't monitor the water separator on the tractor closely enough. I will check it more often now after this.
I am shocked that it has a metal tank. I had a Kubota B7100, which had a plastic tank. I now have a Mahindra 5035 HST, also with a plastic tank. I think plastic is a better choice to avoid corrosion.
My tractor has a plastic tank and is actually 2 tanks connected with a hose and a check valve between the the tanks. My nurse tank is metal.
/ Water in fuel causes $10,000 damage to my Kubota Grand L6060 #40
My 2019 M5-111 last month had catastrophic engine failure as well, 1,200 hours, from the diesel high pressure fuel pump. Cost estimated $17,000. I wonder how many other Kubotas are having this issue. KTAC, Kubota insurance is not covering the claim. I will start collecting contact info from other Kubota owners to see if this is a systemic problem of filters not filtering and maybe hold Kubota accountable. Send your contact info to me at Landruma@aol.com if interested.
Towable Pipe Road Crossing Trailer (A63689)
Towable Pipe Road...
1974 Ford F600 Grain Truck (A63118)
1974 Ford F600...
2020 Freightliner 114SD T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2020 Freightliner...
2016 CATERPILLAR 299D2 SKID STEER (A63276)
2016 CATERPILLAR...
2020 Ford F-150 4x4 Ext. Cab Pickup Truck (A61573)
2020 Ford F-150...
Caterpillar 12H/140H/160H Motor Graders Service and Parts Manuals (A63117)
Caterpillar...
