Bush Hog 306 or Brown Tree Cutter
/ Bush Hog 306 or Brown Tree Cutter #1
60Ford861
1960 Ford 861
Quandary... I have 65 acres with a decent number of 2-3 inch trees. They are tulip poplars which grow in clusters. Tractor is a Kubota L6060. Found a 6ft brown tree cutter for a good price which seems a bit on the big side but would demolish the trees. Otherwise I could go with a bush hog 306 or similar heavy duty cutter. Any experience with anything similar anyone can share. Thought also of getting a loader mounted tree shear for the stuff that is a little too big.
/ Bush Hog 306 or Brown Tree Cutter #2
I'd go for the tree cutter. It may seem overkill, until the day you back over a tree that's just little too big.
/ Bush Hog 306 or Brown Tree Cutter #4
Brown tree cutter would be my choice. I had a Woods BB600X that was a beast. I would say somewhat similar to the brown tree cutter. If you run over it, it eats it up. It was a bit overkill for my New Holland TC40 but it would chomp. What size gear box is on the Brown?
/ Bush Hog 306 or Brown Tree Cutter #6
I would be concerned about the weight of a Brown tree cutter - 1700# - and the required HP. It's going to put your L6060 right on the bottom end of required power and well over the 1200# recommended weight for a rotary cutter.
65 acres sure isn't going to do your tractor any favors using a rotary that large and with the large trees.
If you are in a hurry - hire somebody with a tree sheer. Otherwise - sharpen the 'ol chain saw and get a big PTO chipper.
/ Bush Hog 306 or Brown Tree Cutter #7
I had a recent thread on here about clearing a pasture and there were a number of suggestions. My tree 'problems' are sweetgums and water locust. I am told that both will come back if not treated with herbicide, so, be aware of that. I am going to do that.
As for my removal method, I have been doing it with chainsaw and also trying to pull them up by the roots, which works (chain and tractor) but it's slower going than I wish because I have a lot of trees. With 65 acres, your number of trees might be even more.
I found a 'brush grabber' gizmo online and it looks interesting for quick attaching to sapling (end of a chain) so you can pull them up by the roots. It looks like it would work. We just tie a chain on but I think the brush grabber would be faster and more efficient. Cost looks to be $200 to $400 depending on size.
You can also buy an attachment for a FEL that allows you to dig up saplings by the roots. That looks like it would work.
As for my choice, I just hired a mulcher operator. He is a bargain at $75/hour. Two years ago, I hired a mulcher guy who was across the road working on a neighbor's land and I asked him to come to my land for three hours and he did. I just wanted to see how fast he could clear a trail in dense forest. In three hours, he did what would take me weeks clearing a trail manually with chainsaw and brushcutter and machete. He charged $90/hour. So, I am eager to get the new guy for $75/hour. I will have him mulch all these sweetgums in the pasture and also blaze some new trails in my woodlot. I will not have him mulch the water locust trees as they have horrific thorns and I will pull them all up and burn them to, hopefully, get rid of all the thorns, which are long as your finger!
I have witnessed what a Brown tree cutter can do. It can, generally, do what a mulcher can do. But I saw it on a armor-plated tractor for working in the woods. As others said above, you need horsepower.
Thankfully I have found a bigger tractor to purchase. A kioti RX7320. Roughly 15 more horsepower on a larger, heavier tractor.
Just an update on this. Did end up with an RX7320 and the 6ft brown tree cutter. The cutter is HEAVY but will absolutely demolish anything you cut with it. I can cut through a clump of 3-5 tulip poplars all 3 inches in diameter and it doesn't even pull the engine on the tractor down.
/ Bush Hog 306 or Brown Tree Cutter #10
I notice that you mention a new tractor, but didn't post pictures...
/ Bush Hog 306 or Brown Tree Cutter #11
Did you get the Brown 672?
Its an older model brown tree cutter. 80tc720hd is the model number. Closest new equivalent is a TCO-2625C. A side shot and a before and after of a few trees taken out with it. It's a monster.
/ Bush Hog 306 or Brown Tree Cutter #13
I know this is an old thread, but any updates on how this mower is working out for you with that tractor? Have you used it a lot? Any issues? How do you find the cut when using it in regular field mowing of brush, vs a standard style rotary cutter?
/ Bush Hog 306 or Brown Tree Cutter #14
/ Bush Hog 306 or Brown Tree Cutter #16
Me too.......
/ Bush Hog 306 or Brown Tree Cutter #19
Somewhere around 74/75, I bought a new Marvel tree cuter. I think that Brown is that now. Paid 900$ used it for anything up to 8 in trees. Sold it for 1500$ in 05, looked really bad bad. Guy was happy because new was around 4000$. Every once in a while I wished I had it back. Like someone said, it was a beast.
2016 Chevrolet Caprice Sedan (A61569)
2016 Chevrolet...
2013 Jeep Grand Cherokee AWD SUV (A61569)
2013 Jeep Grand...
SCAN TO RECEIVE TEXT UPDATES (A62129)
SCAN TO RECEIVE...
2005 PETERBILT 335 DAY CAB (A60736)
2005 PETERBILT 335...
THREE POINT MAINTAINER BLADE (A58214)
THREE POINT...
Location Tampa, FL (A61567)
Location Tampa, FL...
