Ideas for cannon ball extraction?
   / Ideas for cannon ball extraction? #231
I saw this cannon today in Carson City, NV. It had a display of "cannon balls" in front.
After examining these .... "cannon balls" .... I wonder-- why didn't you just use the finger holes in the cannon ball and pull it out? :D
   / Ideas for cannon ball extraction? #232
This has been interesting to follow, and I'm glad that you got it out. I wonder if those balls were used for ornaments at one time, and the holes were used to hold them into place on the brass monkey. :confused:
Just a suggestion; before firing it, perhaps you should consult your new friend the armorer, who knows more about cannons than most of us commenting on this thread.
The F's is the size of measure of the powder (grain). For example, Fg is the coursest grain, which burns slower. It goes up to FFFFg, which is very fine and burns very fast. Rule of thumb, .50 or less, use FFFg or FFFFg, .50 or more, use FFg or Fg. I use FFg in my .54 cal
Ahh, yes, now I recall. It's FG, not FS. I remember thinking how will I remember that? (evidently I didn't) but for reference, I was thinking Field Goal..... Well, I sucked at football so guess I couldn't remember that.
Regarding my newest Blast-O-Matic friend..... yeah, now that it's out I'm looking to text him. I've never met him, just chatted via phone.
I might be able to use my borescope to take some internal pictures to save him a drive.
Yesterday, I was at work. (I cover a territory and one location I go to is a prison). I was talking to one of the Security Officers (it was explained to me that they prefer to be called SO's, verses "Guards") anyway, I asked him about any idea where to buy black powder...got a bit into the story and it was amusing to me to see his face during our chat about his retirement account..... pretty dead pan, pretty serious.... when I asked about the black powder and said I had a cannon, his face dramatically "lit up" (seems things that go BOOM interest him far more than his retirement).
He offered to buy the cannon, sight unseen...... for $5.00.
(y)
I told him we could maybe swap his pension to me for it....and we might have a deal. He went back to deadpan.
lol
   / Ideas for cannon ball extraction? #234
I'm glad you got the ball out safely. Congrats on that. As far as the hole in the ball, that may be a vent hole to vent out air pockets while casting the ball in a mold. May help get the molten lead to "fill" the casting mold completely. A ball with various abnormal air pockets in it will not "fly true" on it's way to the target.
If you save both of those balls, you can resmelt them and cast them back into round balls again. I certainly wouldn't dispose of them. Lead is expensive (over a buck a pound) and even if you never get setup to cast balls, someone sure could use them or buy them from you. Maybe one of your new cannon buddies can cast the balls for you, if they have the right diameter casting mold.
It sounds like you have a blackpowder "substitute" powder. That is fine. Load it like a blackpowder load. Also NO AIRSPACE between powder charge and ball, when you seat the ball. Take a picture of the powder can (bottle) when you can. As a VERY rough rule of thumb, when firing a round ball, you should be safe loading 1 grain of powder for every .01 of bore caliber. So a .50 caliber gun should be quite safe to fire 50 grains of blackpowder (or your substitute) behind the round ball. That would be considered a "mild" load. Too much less than that and you risk "sticking" the ball in the bore.
The "5 pounder" mountain howitzer I fired used a whole pound of (real) blackpowder per shot. Not suggesting you go anywhere near that powder charge in your gun. What is the bore size again?
Please be careful, and get that barrel's bore surface clean before you try it. Resistance to movement of the ball (rough/rusted/dirty bore) can sharply increase pressures.
Went to garage to get my cat's breakfast ready....didn't have camera with me. Looked at bottle of powder, said it was a black powder substitute and was slow burning.
Guy at store said it would fire cleaner than black powder so leave less residue. (?)
I think it was called Pdex or Pyrodex, something like that. Yeah I know....'fantastic description' but the cat was rubbing on my ankles hankering for his breakfast.
OCD question....do you mean "grain" as in a "spec" of powder or do you mean it as a unit of weight? "39 grams" for example.
I've been told by my new, never met yet cop friend that roughly 2 ounces should work for a bang and some smoke. If I want to launch a projectile, I should NOT go over around 4 ounces. The guy at the ammo store, gave same guidelines without knowing I had already been told that.
How does two ounces for example, translate to grains? (unless you meant grams?)
Anyway, the bore is right at 2.22 inches so I'm calling it 2 1/4". This was measured at the very tip of the bore.
I've been told I can get some frozen orange juice cans and load them with concrete to fire them, instead of the lead ball. I'm intrigued by that...but figured I'd need it to be maybe a 2" diameter as I'm guessing (without knowing) that you don't want it "TIGHT" against the bore as it might jam. Then again, maybe it's the opposite.... putting a 2" slug into a 2 1/4" bore might allow it to jack sideways and jam.
Thoughts?
(I'll probably just stick to rags but a slug DOES intrigue the mischievous part of me)
Oh, and I discovered my extend-a-hone is not working correctly.
It all works....but the original threaded rod has a swell in it which prevents the hone from "walking" up the threads. My rod doesn't prevent that. I discovered that when I put the hone in, the threaded rod extended say, one inch past the threaded part of the hone. When I finished, I had 7-8 inches of threaded rod on that part so clearly, the rod is turning inside the hone allowing the hone to work its way up the rod.
I need to get a lock nut so I can freeze the hone in place. That infers I've lost/missed some honing action as it was busy moving up the rod instead of rotating and honing.
   / Ideas for cannon ball extraction? #238
Just spitballing here, when you are ready for your first trial ‘BOOM’, what about using a potato, tennis ball or something similar and a bit less lethal? And it could be easier to extract/cleanup if things don’t go perfectly. Of course a video is required for our amusement or your heirs. :oops: Keep updates coming.:)
   / Ideas for cannon ball extraction? #239
This is a situation where I would personally want some real advice from some one who actually shoots a black powder canon. Has this thing ever been fired or was it just a display canon?
There's a guy who comes to local July 4th events to fire his canon. The thing throws red hot sparks 20-30'. I could see it starting a fire in dry conditions. No telling how much $ has literally gone up in smoke.
   / Ideas for cannon ball extraction? #240
What’s the downside of no projectile and using wadded paper or cloth?
Unless you can fire against a hill for a backstop going without a projectile for a first shot seems a lot safer plus being able to keep your balls…
Lenovo Thinkpad T480S Laptop (A53425)
Lenovo Thinkpad...
2018 FORD F-350 (A55745)
2018 FORD F-350...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A56129)
2005 INTERNATIONAL...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2007 FORD F-150 XL TRITON (A55745)
2007 FORD F-150 XL...
