Ideas for cannon ball extraction?
   / Ideas for cannon ball extraction? #211
I didn't catch the drill size, but if it's not too big, I'd make an ez out with a big lag screw and a chunk of 1/2-13 all thread. Weld the lag to the thread, get a chunk of flat bar with a hole in the middle to pull against, put that on, then a nut behind it, then weld another nut on the end so you can get on it with a socket. When the lag has a good bite, run the nut down to where the bar is in contact with the bore and then keep turning. It should pull it out with any luck.
   / Ideas for cannon ball extraction? #212
Clean the oils out. Clean the barrel with at least a wire brush. Apply some jb weld to a rod and stick that sucker onto the ball. You could probably pull it out then. If it rolled deeper than I’m guessing it will pull out with out to much trouble.
A tractor site and no one, not one person has suggested hooking it up to the PTO and swinging it around by its tail like a dead cat to let centrifugal force work it's magic ! May need to back up to a loading dock to get proper clearance, and don't forget to use a counter weight or it could be dangerous!
Too funny. I have both, should I use the 1000 or 540?
I have a 36" 3/4" Bosch SDS hammer drill bit, and they make a SDS chisel bit 18" BUT, IMO a hammer drill and a 3/4" bit may provide the hammer effect to loosen it up. https://www.amazon.com/Bosch-HC2129...locphy=9002459&hvtargid=pla-523861698414&th=1
I never thought about a bit like that. I might already have one too.
I like the idea, especially with the bit being smaller, I can maybe be more precise with it's location
(Am working today and tomorrow, 100 miles from home so will take a couple days to be sure)
   / Ideas for cannon ball extraction? #215
Drill and tap the flash hole for a small pipe, screw on a fitting, then divert one of your hydraulic lines to it.
It is now a single action hydraulic cylinder with a free piston.
Bruce
Or a big ‘squirt’ gun. :LOL:
   / Ideas for cannon ball extraction? #216
Richard’s very entertaining saga is going to be memorable. It reminds me of this LONG but hilarious and very well described story:
We have the standard 6 ft. fence in the backyard, and a few months ago, I heard about burglaries increasing dramatically in the entire city. To make sure this never happened to me, I got an electric fence and ran a single wire along the top of the fence.
Actually, I got the biggest cattle charger Tractor Supply had made for 26 miles of fence. I then used an 8 ft. long ground rod, and drove it 7.5 feet into the ground. The ground rod is the key, with the more you have in the ground, the better the fence works.
One day I'm mowing the back yard with my cheapo Wal-Mart 6 hp big wheel push mower. The hot wire is broken and laying out in the yard. I knew for a fact that I unplugged the charger. I pushed the mower around the wire and reached down to grab it, to throw it out of the way.
It seems as though I hadn't remembered to unplug it after all.
Now I'm standing there, I've got the running lawnmower in my right hand and the 1.7 giga-volt fence wire in the other hand. Keep in mind the charger is about the size of a marine battery and has a picture of an upside down cow on fire on the cover.
Time stood still.
The first thing I notice is my pecker trying to climb up the front side of my body. My ears curled downwards and I could feel the lawnmower ignition firing in the backside of my brain. Every time that Briggs & Stratton rolled over, I could feel the spark in my head. I was literally at one with the engine.
It seems as though the fence charger and the piece of **** lawnmower were fighting over who would control my electrical impulses.
Science says you cannot crap, pee, and vomit at the same time. I beg to differ. Not only did I do all three at once, but my bowels emptied 3 different times in less than half of a second. It was a Matrix kind of bowel movement, where time is creeping along and you're all leaned back and BAM BAM BAM you just crap your pants 3 times. It seemed like there were minutes in between but in reality it was so close together it was like exhaust pulses from a big block Chevy turning 8 grand.
At this point I'm about 30 minutes (maybe 2 seconds) into holding onto the fence wire. My hand is wrapped around the wire palm down so I can't let go. I grew up on a farm so I know all about electric fences ... but Dad always had those piece of **** chargers made by International or whoever that were like 9 volts and just kinda tickled.
This one I could not let go of. The 8 foot long ground rod is now accepting signals from me through the permadamp Ark-La-Tex river bottom soil. At this point I'm thinking I'm going to have to just man up and take it, until the lawnmower runs out of gas.
'Damn!,' I think, as I remember I just filled the tank! Now the lawnmower is starting to run rough. It has settled into a loping run pattern as if it had some kind of big lawnmower race cam in it. Covered in poop, pee, and with my vomit on my chest I think 'Oh God please let me die .... Pleeeeaze . But nooooo, it settles into the rough lumpy cam idle nicely and remains there, like a big bore roller cam EFI motor waiting for the go command from its owner's right foot.
So here I am in the middle of July, 104 degrees, 80% humidity, standing in my own backyard, begging God to kill me. God did not take me that day .... he left me there covered in my own fluids to writhe in the misery my own stupidity had created.
I honestly don't know how I got loose from the wire ....
I woke up laying on the ground hours later. The lawnmower was beside me, out of gas. It was later on in the day and I was sunburned.
There were two large dead grass spots where I had been standing, and then another long skinny dead spot where the wire had laid while I was on the ground still holding on to it. I assume I finally had a seizure and in the resulting thrashing had somehow let go of the wire.
Upon waking from my electrically induced sleep I realized a few things:
1 - Three of my teeth seem to have melted.
2 - I now have cramps in the bottoms of my feet and my right butt cheek
(not the left, just the right).
3 - Poop, pee, and vomit when all mixed together, do not smell as bad as you might think.
4 - My left eye will not open.
5 - My right eye will not close.
6 - The lawnmower runs like a sumbitch now. Seriously! I think our little session cleared out some carbon fouling or something, because it was better than new after that.
7 - My nuts are still smaller than average yet they are almost a foot long.
8 - I can turn on the TV in the game room by farting while thinking of the number 4 (still don't understand this???).
That day changed my life. I now have a newfound respect for things. I appreciate the little things more, and now I always triple check to make sure the fence is unplugged before I mow.
The good news, is that if a burglar does try to come over the fence, I can clearly visualize what my security system will do to him, and THAT gives me a warm and fuzzy feeling all over, which also reminds me to triple check before I mow.
And now back to Richard and the regular scheduled programming ……..
   / Ideas for cannon ball extraction? #217
Don't know if this has been suggested, but maybe load it with dry ice to shrink the cannon ball and loosen it? Might need to insert a pvc pipe section inside the barrell in contact with the ball and then load the dry ice inside the pvc pipe so the dry ice doesn't touch the barrell and shrink it too. Could even heat the barrell to expand it while the dry ice shrinks the ball?
   / Ideas for cannon ball extraction? #218
Personally, I would be concerned that since lead is a soft, soft metal that any amount of hammering on the ball will cause the ball to mushroom out in width, further cementing it to the barrel.
They used to sell concrete anchors based on the same principle and they were wonderful anchors.
Just kibitzing from the arm chair...
All the best,
Peter
   / Ideas for cannon ball extraction? #219
JethroB --
You should post your story to the Groan thread. Absolutely hiilarious.
   / Ideas for cannon ball extraction? #220
Time stood still.
I have read this before somewhere, but it's still as hysterical as ever!
2020 DRAGON ESP...
2018 K-TEC 1228 PULL TYPE DIRT PAN (A52707)
2018 K-TEC 1228...
2024 CATERPILLAR 242D3 SKID STEER (A52707)
2024 CATERPILLAR...
2013 Audi A6 AWD Sedan (A56859)
2013 Audi A6 AWD...
2016 Chevrolet Cruze Limited Sedan (A53424)
2016 Chevrolet...
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A57193)
UNUSED LANDHONOR...
