Mahindra 5155 Anyone?
   / Mahindra 5155 Anyone? #261
Hi all.
Been following this thread since I decided to buy the 5145. I'm in the pnw and we bought ours to clear logging slash, establish a large garden/farm and feed our sawmill logs. Really like your skidder attatchments, I ordered a cheap 3 pt lift/skidder off amazon. We will see if it works, our log diameters go up to over 5 feet. Grapple (Baeber) and third function valve are ordered through our local dealer and picked up pallet forks this week.
We picked up the tractor yesterday! What a tractor, love it. The shifting is so much more intuitive for me than I thought it would be, way better than hydro.
Few things I have issues with, bucket level rod fell off, no grease in any fitting, there were some random bolts in the cock pit, hazards switch doesn't work (lights came on at 2am last night) if you push or pull it sometimes they will flash once, clutch has a "catch" to it- you have to push it and move the shuttle to get it to fully disengage, starting can be a test of patience.
I think dealer is ultimately responsible. The only 5145 in the state was not our local dealer, I'm sure when we take it in for the third function our local guys will get it dialed in.
I will try to adjust the clutch and see if that will take care of it.
Thanks again for all the information you have all posted.
   / Mahindra 5155 Anyone? #262
Not the best saw log but I had to test it out.
   / Mahindra 5155 Anyone? #263
Hi all.
Nice tractor! Sounds like it should be great for your chosen applications once you get the bugs straightened out. Dealer is definitely responsible for all of that stuff, it should never have left the dealership in that condition. Have you greased the fittings yet? If not, definitely do so before you operate it further. Your pins and bearings will thank you down the road.
As for the clutch - definitely start by making sure that gets greased as well. Below the clutch pedal, on the floorboard, under the rubber floor mat, you'll find two grease fittings. These lubricate your clutch rods and linkage. If the rest of the tractor never got any grease, chances are that linkage didn't either and that could be part of your problem. The clutch pedal should operate smoothly throughout it's entire throw of travel. Put some grease to it - fully depress and release the clutch pedal a couple times - then add a little more grease. It should start to smooth out.
Also, since the dealer apparently did a half-ass job assembling your tractor chances are your clutch and shift linkages need to be adjusted as well. Information on how to do the clutch can be found on pg. 7-20 of your owners manual. It's very easy. As for the shift linkage, you won't find anything in the manual, but I found how to adjust it beneath the tractor and posted about it earlier in this thread.
Congrats on the new 5145, though! They're awesome machines.
   / Mahindra 5155 Anyone? #264
My 5155 came with two sets of quick connect male ends to attach to an implement of choice. They are 1/2" AG fittings. The fittings on the tractor are called breakaway fittings - nothing to push or pull on the tractor side. To connect the fittings, firmly push the male fitting (implement side) into the tractor-side female. It'll pop into place and attach securely. To disconnect, just give it a firm yank. It'll pop loose without leaking hardly anything.
They are designed that way to prevent damage to the tractor's hydraulic lines in case the implement lines were to ever become tangled in a spinning PTO shaft. But, they work really well for easy connect/disconnect, too. Honestly, I went through the same thing when I first used them because I'd never had factory-installed remotes before. But yeah, just shove the male fitting in to connect them and pull it out to disconnect - easy.
Really! Funny, I did the same thing and calculated an estimated weight using the weights listed in the manual plus the loaded tires - came out to 7,996 lbs. My old 4540 weighed 7,496 lbs., and I was accustomed to the way my pickup behaved while towing it. Towing the 5155 home I kept thinking to myself, "This thing is definitely more than 500 lbs. heavier." That would explain why! So, thank you for doing that, Andy! That's good to know.
Nice, great news regarding parts availability! Sounds like you've got a really good dealer, honestly.
Walt...thank you so much for the info on the rear remotes. I tried it and it worked just as you said. Haven't seen those before but it's a great idea to prevent further damage if something happens to the hydraulic lines on the implement side.
   / Mahindra 5155 Anyone? #265
No problem! Like I said, I went through the same thing the first time I tried to use them. Yeah, they're pretty handy.
   / Mahindra 5155 Anyone? #266
OK Walt and all others, try this one. Walt mentioned that the main clutch and PTO clutch linkages need to be greased and that the zerks are under the floormat in front of the clutch. This is shown in the lube photo in the owners manual. I went to look on my 5155 and found it is nothing like the photo. No zerks are evident as in the photo and lifting the floormat would be a major task. See my photos attached. The only thing I can think of is to cut the tops off the two raised circles and hope the zerks are there. Any advice?
   / Mahindra 5155 Anyone? #267
Thanks Walt.
I read that post on the clutch adjust and will reread when it dries out enough to climb under it. I greased everything in the book.
You need to peel back the rubber mat.
   / Mahindra 5155 Anyone? #268
Also, from the Mahindra Tractor Owners - USA group on Facebook, there is a discussion about front axles on Mahindra tractors after one 1635 broke apart at the hub and one comment by a tractor mechanic is, "Mahindra, and all the other tractor brands have a front axle rating. You’ll find the spec in your manual. Although Mahindra is built heavy, the front axle rating is much below what it takes to teeter-totter a tractor on the front end." This comment was not regarding the 5145/5155 specifically but I could not find a front axle load spec in my manual. Just wanted to share the info and suggest checking bolts at the hub. Might also want to join that group on Facebook.
   / Mahindra 5155 Anyone? #269
Thanks Walt.
Well, it didn't look like it was possible since it was attached to the nearby sidewall but it can be released from the sidewall and be peeled back just enough to service the two zerks. The dealer had done that. Thanks for what should have been obvious to me.
   / Mahindra 5155 Anyone? #270
You have to lift the floormat to get to them, I recall thinking it wasn't too much of a process at all. In your photos, you can see two round, gray plastic pieces just below the "Instructions" sticker. They are simple push tabs and they hold the floormat in place. Use a flathead screwdriver or similar tool to pop them out, then the floormat will lift free enough to access those fittings.
The floormat looks like the clutch linkage goes through it, but it does not. The mat is sleeved and will pull away from the linkage easily.
Nevermind, glad you got it! I was responding to your first post without reading the second.
   / Mahindra 5155 Anyone? #271
Well we got Big Red back last week and all is well, except i hit the fuel filter with a limb while grappling some brush, it put a big dent in my fuel filter and messed up the ring that secures the filter. No leaks but i will have some work to do during the 50hr. I must say this thing digs a lot better than i expected.
   / Mahindra 5155 Anyone? #273
Well I, for one, am glad your issue is resolved; but maybe what you REALLY need is an excavator :)
-Simon
no I need a tank, and thought that I had bought one lol. The spider gears was most likely a heat treatment issue. On the other hand I bought the tractor to use and it will not be a 500hrs looks brand new bargain for someone after 5 years. If I need an excavator I will be renting that. The tractor was purchased to provide me with a reason to get off of my computer and be more active, and it has accomplished that. I do not see any reason to beat it to death by doing things that it cannot do, but at the same time I did my research and bought equipment that should do what I need without over stressing it. I fully believe that the tractor will pick up some scars and warn out parts along the way. At the very least everyone else should learn something about the 5100 series from my experiences/misadventures/screwups lol.
You should be good to go. I think your problem was probably one bad spider gear that let go and took out the rest of them. My impression of the 5155 when I was looking at buying one has only been further solidified after putting about 45 hrs on mine. It’s a very stoutly built and well thought out machine. It’s capabilities are so far above the 1538 it replaced it’s in an entirely different class. And I loved my 1538! I just went over mine last weekend with the grease gun and not only is the number of zerk fittings impressive for a modern piece of equipment, as I was laying underneath it greasing it the overall build and heft of everything is equally impressive. All of the controls feel really good (with the exception of the 3 point lowering knob), and getting it out on the road and running through the gears in high range felt good too. It shifted very smooth at speed, and pulled some steep hills in high range 3rd gear. I have the 50 hour service coming up soon and I’m looking forward to that. Something kinda neat about being the first person to crack open the drain plugs etc since it left the factory.
   / Mahindra 5155 Anyone? #275
Glad to hear you worked it out.
Does anyone else have an issue with the knob that adjusts the speed of operation for the 3 point lift?
My knob is acting like the shaft is bent below the floorboard, ie hard to turn then easy then hard and the shaft changes direction while turning.
Yes, mine seems to be bent. It was bent when I got the tractor, although I did not know it. I will have the dealer check into this when I do the 50 hour service. I have 27 hours on it now.
   / Mahindra 5155 Anyone? #276
Keep reading the thread we found that that issue is normal I posted a section from the service manual that illustrates that assembly, it is funky and looks like they made a mistake in design and thru together a fix that wile feeling funky should be durable.
   / Mahindra 5155 Anyone? #277
Speaking of the service manual, do you have a printed manual? At any rate where did you get the one you have? My dealer called Mahindra and told me, this morning, that Mahindra does not have printed repair manual at this time.
   / Mahindra 5155 Anyone? #278
down loaded pdf from Bob's, and to my knowledge Mahindra has not released a printed copy yet, also Bob's service manual is exactly the same as the Mahindra one including some missing info.
   / Mahindra 5155 Anyone? #279
I can't find Bob's service manual. Do you have a link you can share?
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A59823)
KNOW BEFORE YOU...
Crown RC5535-35 Stand-On Electric Forklift (A59228)
Crown RC5535-35...
AUCTION STARTS HERE @ 9AM (A60429)
AUCTION STARTS...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2019 KOMATSU D155AX-8 CRAWLER DOZER (A60429)
2019 KOMATSU...
