BX2350D will not start when hot!
/ BX2350D will not start when hot! #1
rabbott48
2008 Kubota BX2350D
Kubota BX 2350D will not start when hot!!
/ BX2350D will not start when hot! #2
My older B1700 won't restart when hot except if I reset the glowplugs. The engine seems to cool off very quickly after shutting off.
/ BX2350D will not start when hot! #3
Can you provide any more detail? Does it turn over? etc. What have you checked thus far?
No it does not turn over. I have replaced the fuel stop Solenoid. I have check the fuses, safety switches, replaced fuel filters. When it does start it will not shut off!!
/ BX2350D will not start when hot! #5
Ignition problem? If it wont shut off maybe you have a problem with the circuit the ignition switch is on.
/ BX2350D will not start when hot! #6
Do you have a Volt-Ohm Meter (VOM)? First step is to use a VOM & spend half an hour checking the battery, starter circuits, and safety switches. I'll bet you'll find it then. If not - well, you still had to check those things first.
rScotty
2009 FONTAINE TRAILER CO. 48 X 102 SPREAD AXLE FLATBED (A60736)
2009 FONTAINE...
2007 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2007 INTERNATIONAL...
2018 Ford F-150 Ext. Cab Pickup Truck (A61568)
2018 Ford F-150...
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
2008 MAXX-D FUEL TRAILER (A58214)
2008 MAXX-D FUEL...
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2020 Mack Anthem...
