BX2350D will not start when hot!
/ BX2350D will not start when hot! #1
rabbott48
2008 Kubota BX2350D
Kubota BX 2350D will not start when hot!!
/ BX2350D will not start when hot! #2
My older B1700 won't restart when hot except if I reset the glowplugs. The engine seems to cool off very quickly after shutting off.
/ BX2350D will not start when hot! #3
Can you provide any more detail? Does it turn over? etc. What have you checked thus far?
No it does not turn over. I have replaced the fuel stop Solenoid. I have check the fuses, safety switches, replaced fuel filters. When it does start it will not shut off!!
/ BX2350D will not start when hot! #5
Ignition problem? If it wont shut off maybe you have a problem with the circuit the ignition switch is on.
/ BX2350D will not start when hot! #6
Do you have a Volt-Ohm Meter (VOM)? First step is to use a VOM & spend half an hour checking the battery, starter circuits, and safety switches. I'll bet you'll find it then. If not - well, you still had to check those things first.
rScotty
Trailmobile Van Trailer (A63118)
Trailmobile Van...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Kubota L2501 (A62177)
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
