BX2350D will not start when hot!
   / BX2350D will not start when hot! #1
rabbott48
2008 Kubota BX2350D
Kubota BX 2350D will not start when hot!!
   / BX2350D will not start when hot! #2
My older B1700 won't restart when hot except if I reset the glowplugs. The engine seems to cool off very quickly after shutting off.
   / BX2350D will not start when hot! #3
Can you provide any more detail? Does it turn over? etc. What have you checked thus far?
No it does not turn over. I have replaced the fuel stop Solenoid. I have check the fuses, safety switches, replaced fuel filters. When it does start it will not shut off!!
   / BX2350D will not start when hot! #5
Ignition problem? If it wont shut off maybe you have a problem with the circuit the ignition switch is on.
   / BX2350D will not start when hot! #6
Do you have a Volt-Ohm Meter (VOM)? First step is to use a VOM & spend half an hour checking the battery, starter circuits, and safety switches. I'll bet you'll find it then. If not - well, you still had to check those things first.
rScotty
CASE 5200 Grain Drill (A53317)
CASE 5200 Grain...
Emerson 18' Homemade Trailer (A56469)
Emerson 18'...
UNUSED FUTURE FT1000T VIBRATORY ROAD ROLLER (A57192)
UNUSED FUTURE...
2011 Ford Crown Victoria Sedan (A55853)
2011 Ford Crown...
2013 FORD F-350 XL SUPER DUTY- FLAT BED (A58214)
2013 FORD F-350 XL...
UNUSED RAYTREE RMA42' HYD AUGER (A57193)
UNUSED RAYTREE...
