How agriculture works thread
/ How agriculture works thread #441
Grazing is highly discouraged here because of soil compaction.
That is interesting and somewhat old school thinking. True there is some compaction from grazing but if there is enough plant matter and soil activity it overcomes it. Plus grazing processes the plant matter to break it down quicker and have nutrients available. the thing you cannot do is overgraze because you need the plant matter mulch as well. There needs to be a lot of plant matter left on top.
There is substantial research data that shows an improvement in soil health from grazing but to date I do not think the exact reason has been determined. Some of the theories are having some preprocessed nutrients available and the effect of the bovine digestive system for adding certain enzymes into the soil structure that helps to break down plant matter and encourage soil activity. Some data I have seen tends to lead to the urine being a critical part of the system possibly because of the enzymes - but haying and hauling manure back out is not as good as grazing for soil health. (I reference Dr. Beck for most of this information.)
/ How agriculture works thread #442
Ain't working all that well around here, dryer than a popcorn fart. Stuff is stressed with no relief in sight.
/ How agriculture works thread #444
Loading alfalfa silage using a slightly different setup:
Horses are usually over grazing on pasture, unless a person has enough land and is paying attention.
This is what would be called "poor land management". Weather its horses, sheep or cattle.
/ How agriculture works thread #447
Here's a video I shot a few years ago of a local Aronia Berry operation. Harvest in progress.
/ How agriculture works thread #449
No rain here for the last 2 or 3 weeks and hot as well. Corn is starting to fire up a bit. Needs a drink. Last night we got maybe a sprinkle. Nothing to amount to anything in the rain gage and I've been watering the garden in the evening. I water between 8pm and 10 pm so the sun don't dry it out and the water can percolate deeper into the soil.
One positive thing, don't have to cut the lawns, they aren't growing at all, saving expensive gas...
Very unusual weather here. More like August in late June.
/ How agriculture works thread #450
This is a different way of filling the fertilizer tank.
/ How agriculture works thread #451
I read a report this morning that suggests that drought condition will move westward thru the Summer. We don't have deep subsoil moisture, but surface moisture is enough that a considerable amount of bottom ground will not get planted this year.
/ How agriculture works thread #452
Never seen that done in the US. It takes too long to un-hook and re-hook. Usually the chopper never stops when cutting anything - corn, alfalfa, other crops for ensiling.
/ How agriculture works thread #455
If I could go anywhere on the World for a couple months, it would be Australia. Seems my Soul has been there.
/ How agriculture works thread #456
Australian wheat harvest.
Those massive "mother bins" at the end of the field get me. I know they are necessary there because of the long hauls for the trucks but it is just another piece of equipment to keep the combines running.
That is an interesting system but without knowing what there conditions are like, its hard to see why they are used. Everywhere you travel to, you'll see agricultural things that are not done quite the same. I think its quite interesting to see the differences.
/ How agriculture works thread #459
If there is any, even temporary delay of truck arrival, everything stops. The large cart allows a temporary delay without combine shut down.
Kinze and I believe JD now make a 2,500 bushel grain cart. It's purpose is similar since a semi will only haul 800-1000 bushels.
My family has multiple trucks running back and forth so guys can stop to get lunch or break for some unknown reason. I imagined those carts were made to operate in soft soils where those trucks couldn't. :unsure:
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2012 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59914)
2012 UTILITY VS2RA...
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
2019 LAYMOR SM300 RIDE-ON SWEEPER (A65053)
2019 LAYMOR SM300...
