Best aftermarket backhoe for 2021 Kioti DK6010
   / Best aftermarket backhoe for 2021 Kioti DK6010 #1
future_vision
Gold Member
New England
DK6010SE HSA
I am most likely buying a used 2021 Kioti DK6010. I can get a new Kioti backhoe with a $1000 rebate bringing the price down to $9000. I am wondering, is this the best way to go? Is there a really good aftermarket backhoe that I should consider that will save me a decent chunk of change? The 2021 DK6010 clearly has warranty left on it. does that get affected by using 3rd party implements?
   / Best aftermarket backhoe for 2021 Kioti DK6010 #2
Do a google search for Woods backhoes. Not sure of the pricing though. I would personally go for the Kioti backhoe, it has a better chance of being matched to the machine and if you have problems with it you are just dealing with one manufacturer. Tends to make things easier.
You definitely want to buy a backhoe with a subframe that is meant for your tractor! Stay away from 3 point hitch type backhoes.
Just my 2 cents.
   / Best aftermarket backhoe for 2021 Kioti DK6010 #3
SNIP
Just my 2 cents.
Make that 4 cents.
Or go ahead and make it a dollar..... I know there are at least a 4 dozen tractor owners right here on TBN with experience on tractor mounted backhoes.
And BTW, if you do find a decent subframe-mounted hoe and it is compatible with your tractor, you are going to be pleasedwith the decent work it can do when the digging is medium or easy.
But even used, I would expect a subframe & hoe in good working order to go for $3K or up, not $1K.
luck,
rScotty
   / Best aftermarket backhoe for 2021 Kioti DK6010 #4
At $9000 for a new Kioti backhoe - this will probably be the most expensive implement you purchase. I would want to be certain that you have $9000 worth of work to be done. You can purchase a whole lot of other good, used implements for that amount of money.
That's a hell of a price to pay - just for being able to say you have one.
I have a decent amount of work to be done but that is mostly in the early stages of the land clearing prepping. This would be things like trenching for electric. Trenching for well pipe. Digging out a septic field. Digging out a hill for a walkout basement. Digging out footings for foundations. Trenching for the runoff on a 600 ft driveway. At some point I'll be adding some other structures on the property that need foundations. I might even pick up some work on the side just for fun if I haven't gotten sick of being in a tractor if that is a thing. Lol! If I run out of projects I imagine I could probably sell it and recoup a decent amount of $$$ for it. Beats renting and excavator for $400/day plus $200 for delivery and pickup and I can take my time if I need to and not rush to get things done before it has to go back.
   / Best aftermarket backhoe for 2021 Kioti DK6010 #6
Oosik, that is the probably the most near-sighted argument I've heard yet for buying a backhoe or not. Do you see that in making the assumption that price is the most important thing to you - that you are also saying the same is true for everyone? That simple expense is the most important aspect of ownership?
But I'd argue that's not the case at all. If it was, we would all use shovels and nobody would own a tractor or any implement. Maybe only basic hand tools if that. And everything we owned would be used & repaired.
For most, there are lots of things are more important than the price. Free time to do projects is probably what most people are short on. That, coupled with age and and simple physical ability.
All real strong reasons for a backhoe.
rScotty
   / Best aftermarket backhoe for 2021 Kioti DK6010 #7
Being able to continually adjust the backhoe boom swing and outriggers from the loader operator seat for balance a must for my hilly property for safety. This is not easy for some tractor mounted backhoes.
Time is a big factor in my economic justification for equipment.
For the same money you could get a used construction backhoe. Bigger, stronger and probably never wear out. Pros and cons to every situation.
Years, decades ago a mini ex would have been useful for the many building and farm projects. Just not as common back then.
They have improved over time but generally not impressed with ag tractor backhoes.
rScotty
"Free time to do projects is probably what most people are short on. That, coupled with age and and simple physical ability."
Ya know that this is one of the big reasons for me buying some of my equipment. There is some pride and value in saying you did something with your own bare hands. People have done that for centuries and we admire that but what price did they pay? Just because you can do something doesn't mean it is smart to do. I know I can do a lot and save money but I also value feeling well into my later years and busted up joints and muscles doesn't sound very appealing. Heck, I've got enough aches and pains now and I've still got a decent number of years to go before retirement age.
As for time? Well, time is at a premium. You can't make more time(well, maybe by staying healthy and not doing stupid stuff). You can make more money. And if you don't take care of yourself you get neither.
Used minis is an option but for $9000? That must be one of the truly minis. I'll have to take a look and see what is out there. I've only really looked at the bigger minis. What size mini would be equivalent to a tractor backhoe?
   / Best aftermarket backhoe for 2021 Kioti DK6010 #10
Mini ex are double the cost but can dig twice as fast. Quick to back fill. Probably why old construction backhoes are cheap. Like to have one but don’t own one. Have used one and wishing I had something like it 40 years ago. The two TLBs I have now meet my needs.
People make a living with Mimi exs. . Not so much with tractor mount BH.
Have to up mechanic and operator skills to use to economically justify more expensive equipment. Excavation and land clearing tough work. You are the one investing for your education. Let us know how it works out.
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
32in. Tilting Bucket Mini Excavator Attachment (A59228)
32in. Tilting...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 New Holland C327 Compact Track Loader (A56438)
2022 New Holland...
2019 CATERPILLAR  XQ35 GENERATOR (A58214)
2019 CATERPILLAR...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
