Snow plow on FEL
/ Snow plow on FEL #21
Overall, I think that having a snowplow mounted on the FEL is hard on the loader arms and hard on the front axle. For this coming winter I'm planning to remove the FEL and fabricate a plow-mounting system that attaches to the front frame section of the tractor instead. Basically pickup-truck mounts on the front of the tractor. I expect this setup to push snow better, while simultaneously being easier on the tractor.
I had a 5-footer on my little Ford 1210, and these comments are absolutely true. Your 2250 isn't that big, so be prepared for some frustration. 8" of heavy wet stuff will be very difficult to handle. If you could fab an attachment like comment #2 above--see any such on a Ford 800, 801, 2000--- and you will be much happier.
/ Snow plow on FEL #22
I have an old Meyer plow I converted to SSQA and use it on my tractor. Works great. The heavier the tractor the better it will plow. Mine is setup with a chain lift which allows the plow to float independently from the loader. View attachment 750681
Similar to BoylermanCT, my old half-ton plow is mounted with two receivers on the bottom of the bucket (just two pins to secure). These receivers allow the plow to move up and down considerably. Then a chain is used to allow the plow to hang with just the weight of the plow when touching the ground. This prevents the additional down pressure of the loader arms. I tried securing the plow with a solid link instead of the chain and the down pressure is way too high.
/ Snow plow on FEL #23
I run a dozer blade on my FEL, you're right it doesn't float as nicely as a plow with it's own float function. But it works ok until I get a hard enough base to use the inverted blower.
/ Snow plow on FEL #24
I have used a Meyer ST90 plow attached to the loader on my L3010 and like others have said it was easily pushed around by the blade because of the "lever" effect of having the blade so far forward.
After trying that for a couple of frustrating years I added a fixed mount to the tractor and used the loader valve to control the plow. When I eventually moved up to the L4060HSTC I upgraded the plow to a 9 footer.
For me there is no comparison with the direct attach plow being much easier to maneuver and better at moving snow. The only downside is having to remove the loader to attach the blade, but that is no big deal to me.
/ Snow plow on FEL #25
I built 2, one for my t250 bobcat and one for my LS 357, the tractor is way easier and more pleasant to use, the skid steer is too much power and weight, the plow blade wouldn't take it. You will want the 3rd function to be able to angle the blade. I helped a buddy put one on his Ford 1710, for a smaller tractor, 6ft of blade is about all you wantView attachment 750865
/ Snow plow on FEL #26
Can someone running a snow plow on their loader provide feedback on how well it works? I have an L2250 with FEL and am contemplating mounting a snow plow from my skid loader on it. The plow works great on the skid loader, but that's all I use it for. I'm thinking about selling the SL and fitting the plow to the tractor. Thoughts?
I don't use a plow because my research told me that a plow needs speed to do the job right and a snow pusher is ideal for a slower machine like a tractor.
/ Snow plow on FEL #27
Yup, go for it. Mine works great:
/ Snow plow on FEL #28
Built one last year for my neighbor - he luvs it and it is his primary snow removal device - minimal use of his blower except for paths thru the woods and across the field - it works very well.
Just started with making a quick attach bracket and kept going from there - used an old p/u truck plow as the basis of the finished product
/ Snow plow on FEL #29
I run a 7' SSQA plow on my Kubota L4060. It does not float, but there is an inch or two of slop that allows me to put the blade on the pavement without floating the fel arms. The only time I float the fel is when there is a large dip in the pavement.
Last season I put an UHMW Polyethylene edge on the plow, and I really like it. Cuts very well, doesn't scrape the pavement, and it's wearing very well.
/ Snow plow on FEL #30
I have one for mine. Saved me a ton of time over the rear blade for snow. I have a 3rd function so I got the one with hydraulic angle so it saves time adjusting the angle. The nice part about the FEL is you can use your tilt to adjust the angle of attack for different conditions and surfaces.
/ Snow plow on FEL #31
I have been plowing with a FEL snow plow for many years. I think it is the ideal universal snow removal weapon.
Any problems with using one are due to either design flaws, or operator error.
Yes, some stick out real far. But, they don't have to. It depends on how much fabricating you're capable of, and or willing to do. If you're going to mount it to the FEL bucket, it's probably going to stick out a long way. So, I chose to fabricate a dedicated mount, to allow for it to mount directly to the loader arms.
Yes, it needs to be able to float. A truck mounted plow floats via hinges on the bottom, and a chain on top that also allows you to lift it when it reaches it's limit. This is a popular way to float a FEL plow. But, it's not the only way. The bottom hinges can have stops, so the plow will lift when you raise it up. Again it depends on how much work you want to do on the build.
A snow plow that is rigidly mounted, is not going to perform well. It needs trip springs, and the plow also needs to have a few degrees of rotation, to be able to follow the terrain. This means the outer edges need to be able to raise or lower, to an extent, independent of the tractor. Otherwise, you can lose contact with the ground when there is a grade change. This rotation can be achieved as simply as building some slop in the mounts.
As far as the plow causing the tractor to turn when pushing snow, that's operator error. The turning forces are due to the angle you have on the plow. Reduce the angle, and the turning forces will be reduced. A plow does not need to be fully angled to function. It will work just fine at half that, and the turning forces on the tractor will have little to no effect on it. I push a 6' plow with a subcompact tractor, and it goes straight regardless of the amount of snow.
As far as loader arm damage, you risk that every time you use your front end loader. If you can't avoid things that could damage it, and don't use some good judgment, you're going to have issues regardless of whether you have a FEL plow or not. Loader arms are designed to have forces applied to them. This is what what happens when you push the front end loader bucket into the ground.
Don't plow at high speeds, and you're going to limit the forces applied to your rig, in the event something unforeseen happens. Between that, and the trip springs, your FEL arms should not be seeing as much force as they would if you were digging with the FEL bucket.
/ Snow plow on FEL #32
All that is great if you are not doing a large area. I plow a mile long private road and several long driveways which require speed to cast the snow far enough out to allow room for the next storm and to reduce the work load on the machine.
I disagree with your statement that operator error is what makes the machine turn. I can make the machine go straight by not angling the blade at all, but I cannot get any production by doing that. Reducing the plow angle will not work for me as I want to move as much snow as possible with each pass without spilling it out the other end.
/ Snow plow on FEL #33
If you want speed use a truck, a tractor is not going to have the HP to run fast when plowing snow.
Unless you want to use a 150 HP tractor and go fast to break things.
I plow at 2 1/2 to 5 mph with by FEL mounted blade, the snow will curl out past the end of the blade
but it certainly isn't flying off like it will on a truck at 25+mph.
/ Snow plow on FEL #34
Feel free to plow at high speeds if you like. Whatever rig you use, it's much more likely to get damaged when you do it. That's was my point.
Everyone disagrees with the angle of the plow is causing the turning. Then they try it. The clue is, that the tractor doesn't turn until you angled the plow.
Having the plow angled less, doesn't automatically reduce production. Whether it's angled 40 degrees or 25, the snow is still going to that side. And, having the plow angled less, does in fact, present a wider surface in the direction of travel, which means you are technically clearing a wider area with each pass.
/ Snow plow on FEL #35
It's a solid mile from the farm to the pavement and I plow it with mine all the time. The trick to avoid 'plow steer' when plowing the road is to chain up the front wheels (like Lou does).
I have my blower on the back for additional weight and for those drifted spots where the snow comes over the top of the plow.
I have to say plowing is much more fuel efficient (uses a lot less), than using the blower, which is a power eater. Being retired, snow moving is no longer a high priority for me anymore but pulling wayward people out of the ditch (with a snatch strap) is and it's somewhat profitable too.
/ Snow plow on FEL #36
I use a snow PUSHER on my FEL. Drop the pusher and go float the FEL so the pusher glides over the blacktop driveway. I'd prolly gouge the driveway with a plow.
We got 90" of snow last winter. So got a decent workout a few nights on an 1/3 mile long drive on a slight hill. You cant wait for the snow to stop once its like 6" deep the push back up the hill on the return trip gets a little tough.
Plow WITH the storm if its a bigun.
/ Snow plow on FEL #37
Each to their own. Not to belabor this, but the 4060 does 20 mph and there is a definite difference in how the snow rolls off of the blade at a higher speed. I use a direct mount, with a 9 foot commercial blade, which is no different than a truck mount. I have been pushing snow with one type of rig or another since I was 16 (I'm 71) and have never had an issue caused by speed when plowing.
/ Snow plow on FEL #38
I've used FEL plows on all 7 of my Kubota's for over 40 years to plow 1.25 miles of private road. I did manage to break the FEL arm welds on the B7100 HST but I was using a 7' Western plow at the time which generated a bit too much side pressure on the small machine.
In my case, plow shoes are a must with chains on the front tires. To prevent side slippage or gain traction, I just lift the plow a bit to put more pressure on the front tires. The only thing I didn't like was plowing at -10 degrees during a storm on an open station tractor. Under those conditions, I would sometimes plow with the pickup.
My current rig is an L6060 HSTC with an 8' Land Pride blade. I find the ability to pile snow with the FEL to be very handy
The cabbed tractor is so comfortable during inclement weather that I sold the pickup plow.
FEL plowing takes a bit of practice but, due to the increased maneuverability, it saves considerable time over plowing with a truck.
/ Snow plow on FEL #40
Works great on my little Deere 850
2014 Freightliner M2 112 Tandem Dump (A62613)
2014 Freightliner...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
LOT OF MOWER BLADES (A63745)
LOT OF MOWER...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63118)
2020 Takeuchi...
1100 GAL PLASTIC STORAGE CONTAINER (A63745)
1100 GAL PLASTIC...
1993 Ford LS9000 Tri-Axle Dump Truck (A61573)
1993 Ford LS9000...
