What have you done to your Branson today?
   / What have you done to your Branson today? #1,151
Looks good,
as you can see it does fade a bit.
   / What have you done to your Branson today? #1,152
Lou, that is another great solution! Now I have another project added to my list.... I'm not sure if I should thank you or not!......
   / What have you done to your Branson today? #1,154
If you are referring to the ssqa plate with hitch and the quick hitch welded too it.
I should have spaced the bottom out a few inches so as to have more roll back.
   / What have you done to your Branson today? #1,155
Yes, I was referring to the hitch setup. Are you talking about putting a spacer between the bottom of the quick hitch and SSQA?
   / What have you done to your Branson today? #1,156
Yes, with it mounted the way it is now it doesn't have a lot of rollback but has a bunch of curl down.
It would be more versatile with a bit more curl back.
I can actually curl it down to past square with the ground but I have limited up curl.
Ideally it would be pinned and pivot at the top with an adjustable spacer on the bottom.
But it does work as it is, but it could be better.
   / What have you done to your Branson today? #1,157
So I may need a little advice from my friends here. Yesterday, when I came home from work, my wife told me to take the mower off of the Branson, park it up front and leave it unlocked. I looked at her kinda funny but said OK.
So I did just that. I come home today to find the tractor has been detailed inside and out plus waxed.
So my question is does my wife love me or is she getting ready to liquidate my shizzle and move to Florida? :unsure:
   / What have you done to your Branson today? #1,158
I don't know about this... It can go both ways. 😅 Tractor looks great though!
Mine is in desperate need of the same treatment once it gets back home again.
EDIT: Oh nooo! She missed a spot! :eek:
   / What have you done to your Branson today? #1,159
Mmmmmm, is her birthday or special occasion coming up? ..... this might get costly....:oops::rolleyes::unsure:
   / What have you done to your Branson today? #1,160
Best thing you can do is get some dirt and mud on that thing as fast as you can.
Just to be safe.
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A54814)
2016 Ford F-550...
2007 Nissan Frontier Crew Cab Pickup Truck (A55852)
2007 Nissan...
2017 Autocar Xpeditor T/A New Way 31Yd Side Loader Garbage Truck (A55852)
2017 Autocar...
A45G DUMP BED (A55745)
2017 Nissan Frontier Ext. Cab Pickup Truck (A54814)
2017 Nissan...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
