Top Brands
/ Top Brands #1
Dagoof
Idaho Falls, ID
John Deere 2520
What are the next best top brands that I should consider when I replace my tractor?
I have a JD 2520 currently. I know JD is king in the world of small tractors, but I'm not locked in to green tractors necisarrraly.
Besides John Deere and Kubota, are there any other brands that compete as far as top tier compact tractors for what I do?
I have 2 acres. Half of it is grass, so I mow quite a bit, but I often drop the mid mount mower in order to hook on to my tiller, or a blade, or a rake, or my quick-tach front end loader. In the winter, I hook up a front mount snow blower and rear mount blade. I also trailer my tractor quite a bit when I go tilling or moving dirt for friends and neighbors.
26 HP and 1,900 lbs has been enough for most all my needs. Honestly, the feature I desire most is probably the ability to quickly and easily change attachments.
/ Top Brands #2
I am not sure what makes you think John Deere is the king of the world of small tractors. They are an OK tractor, but king of the world is a definite overstatement. Kubotas are very good, but expensive. Branson and Mahindra are quality brands to consider. LS and Yanmars aren't that bad either. As far as ease of changing attachments, ease of trailering, etc. they are all about the same. Their are aftermarket aids you can buy that help with attachment changing.
/ Top Brands #3
Peruse this thread:
/ Top Brands #5
First of all, your JD 2520 is a Yanmar engine. So it's green is only skin deep.
And if you're only mowing 1 acre any tractor will do. It's all the other attachments that make the difference.
My BIL has an LS; very nice. I have a Kioti and I like it but it's too big for mowing even my 3 acres. The Kubota BX are very nice but pricy. I suspect who is available in a reasonable distance and price for the SCUT will be critical.
/ Top Brands #6
Is there a problem with your current machine? A Quick Hitch matched to your implements might be all you need.
If you look at market share, Kubota is king in the world of small tractors last I checked.
Lots of great machines out there. LS, Mahindra, Yanmar, TYM, Kioti, Massey, JD, Kubota. Which dealers are around you?
/ Top Brands #7
Branson as well but appears they are going to get merged with TYM. Still it's a good tractor worth considering and I think support will continue but YMMV
/ Top Brands
I like my current JD 2520 well enough. My biggest gripe is that the local JD dealer caters to big farmers and looks at me like a nuisance.
I was under the impression that JD lead the way for implements, ease of attachment, and the like. (Maybe I'm wrong)
Haven't started shopping a ton yet. I can probably find Kubota, Bobcat, and Kioti locally, but their sales stores are not going to be part of any big network.
I've got to have an easy mid-mount mower. loader, and tiller changeability.
/ Top Brands #9
Seems to me you are changing like for like. I would probably stick with the JD in that case and deal with the nuisance JD dealer. Especially if you value dealer networks as nobody else but Kubota seems to have a large established dealer network and they have a similar attitude as JD.
Clarified as JD = bigger farmers, Kubota = lots of smug dealers.
/ Top Brands #10
Anyone know anything about Bobcat?
Bobcat tractors are produced for Bobcat as private labels by Kioti. The only two differences are paint color and price.
Direct from Kioti with orange paint they are cheaper.
/ Top Brands #11
I've got to have an easy mid-mount mower. loader, and easy tiller changeability.
  • Deere has relatively easiest mounting mid-mount mower.
  • Deere also has the only factory quick attach mount for PTO powered implements which connects the PTO shaft.
I have NO personal experience with either one.
VIDEOS:
Seems to me you are changing like for like. I would stick with the JD in that case and deal with the nuisance JD dealer. Only Deere and Kubota have a large established dealer network and Kubota dealers have a similar attitude to JD dealers.
/ Top Brands #13
What are the top brands that I should consider when I replace my Deere compact tractor?
The feature I desire most is the ability to quickly and easily change attachments.
Ventrac. Now a division of Toro.
VIDEOS: https://www.youtube.com/results?search_query=ventrac
/ Top Brands #15
have you considered keeping the JD and just getting a zero turn to mow with? leave the mid mount mower off and the loader can stay on most of the time while the tiller is easy to change.
a ZT is a lot better for mowing, you would save a ton of money and time, my guess is that you spend 2X as much time mowing as you spend on other things. the ZT would cut your mowing time in half or better.
/ Top Brands #17
Not mentioned but an important consideration, what JD implements do you already have? Are any front mounted? You may have to replace at least the front mounted implements due to JD proprietary SSQA design. You should be okay on PTO driven implements as long as you stay with the same basic size tractor. Colors might clash though if you go with Kioti or Kubota... 😂
/ Top Brands #18
Actually I'd say Kubota was closer to king with compact tractors than JD. I only say this because they're everywhere, their market is huge and if a new attachment for compacts comes out they focus on Kubota first due to market share.
Now since Kubota also uses SSQA most other compacts can use those attachments too. My logo picture shows my Massey with a Lane Shark which is excessive at Kubota dealers.
JD's also have a proprietary QC, which has already been mentioned if you have JD attachments you may have to sell them with the tractor.
If keeping the tractor and going with a ZT isn't an option, look to see who your local dealers are, if they'll pickup and deliver as needed and what their reputation is.
Saving a few hundred dollars and having a dealer a few hundred miles away isn't the best scenario.
/ Top Brands #19
I vote for LS. 8 years and 800 hours of trouble free operation.
CT
/ Top Brands #20
Mid mount mowers can be a PITA. Zero Turn will be faster and maybe even a better quality cut.
CT
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
2015 Cat D6T LGP Dozer (A62679)
2015 Cat D6T LGP...
2010 John Deere 1770NT Planter (A63109)
2010 John Deere...
Bulk Lot - (10) 8in x 20ft Fat Lip Pump Hoses (A63689)
Bulk Lot - (10)...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
