Ideas for cannon ball extraction?
   / Ideas for cannon ball extraction? #41
Ok,
As a black powder gun enthusiast, I can tell you that you absolutely DO NOT want to put ether in that breech and try to touch it off.
Good God.
Black powder is a low pressure combustion. Ether is not. Most of the black powder era guns that were destroyed by firing modern smokeless powders in them were killed because 1) the overall pressure of the charge was too great, and 2) the pressure came on much too suddenly for those old iron, steel and brass frames. The "pressure vessel" of your cannon chamber would never stand the ignition of a fast acting fuel source (like ether).
There is a very good chance that there is indeed a charge of powder behind that ball. The reason I say so is because anyone who knows even a little bit about muzzle loading guns knows you never seat a ball on an empty chamber, because as you see yourself, they are a bear to get out. The "cool" thing about black powder is that as long as it's dry, it will still go off after a century of sitting. Even if you get black powder wet, all you have to do is spread it out (like on a blanket or a workbench) and let it air and sun dry fully, and it's ready to go again.
I would approach this problem from the mindset that there IS A POWDER CHARGE in that cannon. Until such time as the ball is out, and you can visually prove/disprove it with your own eyes. So that means NO HEAT. At least not more than say direct sunlight shining on the cannon casing. NO torches, or flames or any other such things.
I like the idea of compressed air, or compressed water and air. You could try to inject some oil into the chamber side, then stand the cannon on it's muzzle so the oil seeps around the circumference of the ball where it's touching the barrel, and then try a shot of compressed air with the cannon still pointing down. If the cannon ball shifted downwards (at least once), then it should shift towards the muzzle as well. Can repeat this part several times to get the ball to move all the way out.
And I agree you should do your best to clean the inner surface of the barrel first. Make it easier to get the ball out once it starts moving.
   / Ideas for cannon ball extraction? #42
Someone may have already suggested this but how about injecting expanding insulation foam behind the ball?
   / Ideas for cannon ball extraction? #43
After you clean the bore as well as you can how about raising the canon so the muzzle is pointing down and then directing the water from a pressure washer into the hole? Please make sure that you are not in the way of any back blast. I have a 90 degree tip for my pressure washer and I have seen 45 degree ones too. These would help to keep someone out of the way of any back blast. Anyway, water will have a much harder time leaking past the ball than air and the water from a pressure washer is at a much higher pressure than the typical air compressor so the high pressure water just might do the trick.
Good Luck,
Eric
   / Ideas for cannon ball extraction? #44
Good Luck,
Eric
I wouldn't even use a pressure washer.
Town water is 45-65 psi.
Over the bore area , that's a butt load of force. ;-)
Plus, water would quell concerns over powder, and at garden hose pressure, no one is at risk of spray
Plus, if the ball moves , the "pressure" will drop rapidly, limiting any violent expulsion.
Add to the that the flushing action if the ball is just wedged with grit.
All that is required is an open touch hole and perhaps a rubber hose and stopper of some sort to adapt a garden hose fitting to a touch hole.
You might ask at the local harware store if they have them in stock or to order. Just to see the look on the store clerks face.
   / Ideas for cannon ball extraction? #45
Wrap some scotch brite around a piece of closet hanging dowel to clean the barrel as much as possible
Pour some 80 weight gear oil down the barrel and let it soak past the ball. The oil will help seal between the ball and barrel. Then use air again but be careful that ball may come out in a hurry even with only a few psi of air.
Grease gun, gravity. Done ;)
Both ideas are good. They lubricate as well as seal. The grease gun approach basically turns the barrel and the cannon ball into a hydraulic ram. They use the same principle to tension the tracks on an excavator or a dozer. That should be enough force to dislodge a cannon ball! See 1:40
   / Ideas for cannon ball extraction? #46
The grease gun would easily have enough power to push it out if you could seal the gun to the fuse hole. Assuming an air compressor lacked the power I’d probably try a pressure washer next since grease is expensive and it would take a lot to fill the whole cannon.
   / Ideas for cannon ball extraction? #47
Start with grease. If it doesn't drop out, end with air. Grease (or 80 weight oil) seals and lubricates.
   / Ideas for cannon ball extraction? #49
   / Ideas for cannon ball extraction? #50
I'd try a gallo gun. We use this at my employer to clear clogged condensate drain lines. Simple. Blows a blast of CO2 down the line.
If you have a plumber or air conditioner friend, they should have one.
Worth a try.
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
2016 John Deere Gator 825i 4x4 Utility Cart (A55787)
2016 John Deere...
Decorative Mermaid Statue (A55758)
Decorative Mermaid...
2019 John Deere HPX615E Gator 4x4 Utility Cart (A55787)
2019 John Deere...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52706)
KNOW BEFORE YOU...
