Ferris IS2100z no power to left wheel
/ Ferris IS2100z no power to left wheel
See page 8 of the Manual for trouble shooting. Your issues are likely one of the ones listed. You can access them from the link you posted.
The only thing I read in the manual was that the drive unit could overheat if the fan was damaged. Their solution was to replace the fan.
No mention of sticks or fairys.:unsure:
My filters and fans arrived today. I bought an extra fan just in case. My Mobil 1 won't arrive for a couple more days.
I drained the oil from both drives and examined the filters. Nothing weird. No burnt smells. Oil color was normal and the filters didn't show any metal chips or other scary stuff.
I replaced the fan with no issues. I also bought a spare fan just in case this happens again.
I'll report back once I get the oil in and bleed all the air out.
I'm thinking about trying to design a stick guard to put underneath.
I have the exact same mower and have owned it for 7 years now. Twice mine has done the same thing on the left side. Once, it was just a touch low on the reservoir tank, added not even a cup of oil and then it was fine. Second time, a stick (or something) partially dislodged the release lever underneath the pump (the lever used to release the valve for moving). I opened and closed the lever a few times, put it back and it was fine ever since. Doesn't explain your missing fan blades though. Surprised you didn't hear that happen, were you able to find any of the blades in your yard? Might help to explain how it happened.
I never heard the blades break. ( I do wear muffs.) The blades are pretty thin. I'm wondering if they make them that way so if they do fly nothing else gets destroyed.
My bypass levers were in the normal position, but it's possible I suppose that the left one got nocked around a little.
Another discovery. My mower blade drive belt was rolled about a 1/3 turn. It was suggested to me that a stick could have rolled the belt, then flew up into the fan???????
/ Ferris IS2100z no power to left wheel #23
I was doing my weekly mow yesterday when I went to reverse direction the drive to the left wheel quit. It felt like something was binding. When I moved the left side control lever the engine would load up but the wheel wouldn't turn. After checking for an obstruction underneath the machine I tried to power the wheel again. This time it worked and I drove the machine about 30 yards to the barn and parked it.
First thing I checked was the hydro oil level which was OK. Then I noticed all the cooling fan blades were missing! Since I blow out the grass clippings from that area after every use, I'm guessing that a stick must have wiped out the blades within an hour of my discovery.
Is it possible that the drive unit got hot and that's what caused it to act up?
I checked the clock and I'm overdue on the first hydro oil /filter change. I have 160hrs and the service was due at 100 hrs.
I ordered new filters and 15w50 Mobil 1 along with a new fan.
Any ideas?
Maybe check on the Ferris owners group on Facebook??
/ Ferris IS2100z no power to left wheel #24
Another poster had his blades taken off by bamboo, and he didn't hear it either. You're right, they are really thin, I now doubt they made much noise and broke off in a fraction of a second. The fans must create serious vacuum in the "compartment" because whether I mow for a half hour or 4 hours, the cups on the top of the fans are always full of clippings (I blow out all the debris after every mow like you do).
Your blade drive belt being turned could be the reason like you said. I've had small sticks get jammed under the pulleys before also, so it's plausible one got thrown into the fan. I'm still on my original deck belt (374 hrs) but I did have my hydro belt break after only about 50 hrs, I chalked it up to either a stick or a defective belt.
Glad to hear that your filters and oil looked normal. I doubt there was any pump damage, once you get the oil in you should be good to go. I have to replace my filters and oil in about 5 weeks myself for my 400 hr service.
Overall I've been happy with mine, I had a deere before and it beat me up on the ride, the Ferris is a much smoother ride, I'm a big fan of the suspension. On my next one I will be getting the suspension seat also, though.
I went to my local Ferris dealer yesterday and we discussed the design changes between my 1000Z and the newer models. I noticed that while mowing with the 2100 with it's ICD sloped front mower deck that sticks/junk tend to ride up on top of the mower deck, while my old 1000Z square front deck causes the sticks to go under the deck to get chopped up.
I'm wondering if that's what is causing the problem?????
I'm thinking about adding a vertical or sloped forward plate attached to the front of my 2100 deck to help direct sticks, etc. to go under rather than over the deck.
I don't think this would negatively effect the ICD design. Thoughts?
/ Ferris IS2100z no power to left wheel #26
Glad to hear you are getting things back in order and doesn't sound like any damage was done. My deck on the IS2000 is the square front (ICD came out in 2012 I think). I asked the dealer 2012-13 about the amount of dust/debris kicking out the front and he said there is a modification kit available to make it similar to the ICD decks, but I just live with it.
Now that you mention it, the sloped ICD setup would allow sticks to pass up and over vs under so a piece of sheet stock or angle iron and maybe a flex rubber strip would work to prevent this and should not impact performance.
I mow sticks all the time too, and twice now stick debris has gotten wedged into the dual hydro drive pulley - vibrates a lot when this happens so I know to shut down and fix.
That's funny.:LOL::LOL: I bet I've run over stuff an inch in dia. with my old machine with no issues.
We may be related!
/ Ferris IS2100z no power to left wheel #28
I wouldn't think it would hurt anything at all. Let me know if you do something like that, I mow around hundreds of trees so I'm always mowing sticks myself. My rule of thumb is if it's the diameter of my fingers or less, I mow over it
UPDATE.
I was able to get my new hydro oil and I vented and filled the two drive units. Other than the vent being a little hard to reach, everything went smoothly. Filter change was also trouble free. Hydro gear provided some instructions for purging all the air and that went well.
It doesn't appear that any damage was done due to the broken fan.
My wife and I mowed about 2 acres with the machine and it worked fine.
Lesson learned. Be careful running over sticks.
Before breaking my son's mower again, I returned it to him.
I hate messing up borrowed equipment!
I purchased a new Ferris ISX 2200 mower. It's much like my son's mower except for the updated suspension and Vanguard instead of Kawasaki engine. The new mower is also a 52 inch deck instead of a 61 like my previous mower.
Because of the narrower deck the rear tires aren't as wide, the downside being less traction on hills and slopes. Not a deal killer, just different.
The ride is even better than the 2100 which I found to be pretty good for a ZT.
When I get time I'll look into deck mods. to help feed sticks under rather than over the mower deck.
/ Ferris IS2100z no power to left wheel #30
I have a Snapper Pro s200xt with the ICD mower deck and did the exact same thing last summer.
Stick went up over the mower deck and took the fan blades off my left side fan.
/ Ferris IS2100z no power to left wheel #31
On my two Simplicity ZTR's I go around the yard and pick up the biggest sticks to prevent problems. A couple of times it did happen I stopped and pulled them out. It is dangerous for sure trying to run everything over and especially the big long sticks which don't get ground up by the blades anyway.
Update;
After having the cooling fan loose its blades almost two years ago we haven't had any problems. We have been careful about running over sticks. I still think the slope on the front of the deck acts as a stick feeding device. (I never did any modifications to the deck.)
Yesterday I purchased a new Ferris ISX2200 and noticed that Ferris has gone back to the square front on the deck. I don't know the reason why they stopped making the sloped front. Maybe I wasn't the only one with "stick issues":eek: .
My son will continue to use the 2100 and I'll have the new machine. Best I can tell the only real changes are the updated front suspension and the square front deck.
Hopefully these are actual improvements. Time will tell.
/ Ferris IS2100z no power to left wheel #33
So, you bought an ISX2200 in June 2022 and another new one today? I guess you got a good trade - or why did you get another new one after only two years?
My IS2000 25HP Kawasaki (2010 model) with 470 hours is still running great - square front 52" deck and I run gator blades.
I have pretty bad spine/nerve issues. I bought a 52 inch model thinking it would work out better along some ditch lines. Well that didn't work out. The 52 inch model doesn't just have a deck narrower than the 60 inch. Besides the tires being smaller there are other changes axles etc.. While it rode better than my rigid frame Z1000 it didn't ride anywhere near as good IMO as the ISX 60 inch model.
I put up with the ride for a while but decided I either had to get a smoother ride or hire out my mowing. I also considered a ISX3300 but didn't notice a big ride difference and the price, WOW.:eek:
Hiring out anything is always a PITA and I'd like to do for myself for as long as possible.
Today I mowed about 4ac. and it worked out fine. I could even walk afterwards which is always a plus.(y)
Hopefully this will be my last mower purchase.
/ Ferris IS2100z no power to left wheel #35
Full suspension makes a difference. A heavier machine with full suspension makes a better ride. My Simplicity Citation XL with the 61" deck rides fantastic on my bumpy 4 acres.
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
Paladin 12in Digging Tooth Bucket Excavator Attachment (A64194)
Paladin 12in...
2025 HOMESTEADER 612IT 12FT ENCLOSED TRAILER (A59914)
2025 HOMESTEADER...
Drag Tank, Fill Rite 15GPM PUMP  (A62679)
Drag Tank, Fill...
2024 Ford Explorer SUV (A61574)
2024 Ford Explorer...
