rear tires filled weight
/ rear tires filled weight #1
streamin
Gold Member
Conroe, Texas
Mahindra 5035 HST
I'm not looking for an exact weight but on my 50hp Mahindra, I was curious as to how much weight the filled tires in rear weigh. I am buying a new trailer and need the info for the axles I need to get. Maybe there is a formula for the tire size? Or how many gallons did you use when you did yours?
/ rear tires filled weight #2
Messicks has a chart for that kind of info.
Rim guard as one too:
There several other charts available online as well.
Great, thankyou so much!
/ rear tires filled weight #4
I think you will be surprised. I have RimGuard in the rear tires on my Kubota M6040. 755# of RimGuard in each rear tire.
I was surprised , definitely will make a difference in my trailer axles when it is close to rating.
/ rear tires filled weight #6
According to google, windshield washer fluid weighs 7.6 pounds per gallon. I have 30 gallons (228 lbs.)in each rear tire on my 1626. Made a big difference for me.
2012 Gehl DL11-55 11,000lb. 4x4 Rough Terrain Telehandler (A61572)
2012 Gehl DL11-55...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63291)
KNOW BEFORE YOU...
2014 Ford Escape SUV (A61574)
2014 Ford Escape...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
Generator (A61572)
Generator (A61572)
