Replacment alternator
/ Replacment alternator #1
kinghesh
Yanmar ym2000bd
Hey y'all,
I have a Yanmar ym2000bd and I need to replace the alternator and I am wondering what brand I should use. I have look into it a bit but just wanted to see what people with more experience say.
/ Replacment alternator #2
Hey y'all,
The simplest solution is go to Autozone etc and tell them you have a 73 Datsun (Nissan) 510 without air conditioning. Same alternator and regulator.
Or you could tell them 'With A/C' for more amps, but that alternator is fatter. So you would need to make a longer adjustment strap, longer belt, maybe a different mount under the alternator.
As I recall the Datsun-spec alternator is 25 amps vs 10 as supplied to Yanmar, or something like that. In the same outer shell.
I did this in 2003 (regulator too) and it still works fine.
/ Replacment alternator #3
Rebuild the one you have. I finally had to get mine rebuilt for a YM2000 same starter in 6/2011 for 75.00$. Not the first complaint. US. JD. 240 also same starter. Not much to them. The shop mentioned they could see were I was in the brushes of mine. It quit and I added an extra 3yrs use out of the starter just basicly cleaning it up and turning them around!!! Any Auto Eec. shop should do it.
/ Replacment alternator #4
Just before you spend the money on a new alternator, be certain that the entire alternator circuit is working. That was the problem on my JD, which I found after I spent the money for a new regulator. For my experience, the wiring harness seems to be about the most trouble prone parts of tractors/ATV's, all the things which plug in seem to be more reliable!
Genie S40 Boom Lift (A64047)
Genie S40 Boom...
2016 KENWORTH T680 6X4 T/A DAY CAB TRUCK TRACTOR (A59914)
2016 KENWORTH T680...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
2016 KUBOTA SVL90-2 SKID STEER (A65053)
2016 KUBOTA...
Anderson 24' Tilt Trailer (A64126)
Anderson 24' Tilt...
