Flail size
/ Flail size #1
harddock
john deere 770 4x4
I have a 23 hp John Deere 770 and want to add a flail mower. I'm concerned about size and only looking for a direct behind w/o hydraulic offset. Brands to avoid, Brands to go with. all helpful
/ Flail size #2
On average figure about 5HP per foot of mower so with your net 20hp at the PTO you would be in the 48" range. What do you plan on cutting, how often and what's the terrain like.
/ Flail size #3
A neighbor has a 52" flail mower and 19 pto HP. Runs it fine.
Brand is a Del Morino Funny Top that can be offset manually. I liked it so much I bought the same model also.
My tractor has 19.5 pto HP, works good.
/ Flail size #4
Good morning harddock,
Please decide "exactly" how much money you can spend and then
start shopping for a 48" flail mower for your mowing conditions.
/ Flail size #5
I have a titan implements fl135 approx 52 inch cut works well on mahindra max 26
/ Flail size #6
1986 Ford 1310 with 19 hp 1.0 L Diesel engine, manual transmission.
It's doing very well with a 5' Ford 917L (side slicer flails).
This mower is not designed for hammer flails, which would likely require more hp.
/ Flail size #7
I'm running a Woodmaxx 62" flail mower with grass Y blades on a BX2200. Lifts and turns it just fine even through tough 3' grasses.
Does a fantastic job of mowing my lawn when I feel like running it.
2018 Freightliner M2 106 AWD Altec AA55 56ft. Bucket Truck (A60352)
2018 Freightliner...
2019 INTERNATIONAL LT625 T/A 6X4 SLEEPER TRUCK TRACTOR (A59912)
2019 INTERNATIONAL...
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
2007 PETERBILT 379 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2007 PETERBILT 379...
New - Front mount rototiller
New - Front mount...
CASE INTERNATIONAL 230 - 35' TURBO TILL (A63291)
CASE INTERNATIONAL...
