Pressure washer with suction?
/ Pressure washer with suction?
I got an 8 year old generac and this weekend I tried gravity feeding it. It actually worked quite well. PSI was down from hooking up to the house. I'd say it was running around 1500-1700 psi. Washed the wife's truck and went through about 12 gallons of water. Pump did start to heat up so it gives me an idea.
/ Pressure washer with suction? #22
I use 2 350 gallon IBC totes collecting rainwater to washdown my equipment and a 110 volt 'Pony Pump' to provide the head pressure. Never seen any PW pump that will suck for beans. I had Cats, AR's and presently a Karcher cold water machine. None of them sucked.
/ Pressure washer with suction? #23
I built about 10 of these for trucks, all suction. Why do mine work when others do not? These are positive displacement pumps.
/ Pressure washer with suction? #24
When i unhook hose from frostfree, i drop hose and use pressure washer until it stops spraying. This way i empty hose. No one is going to tell me it wont suck. Its an older honda powered pump.
/ Pressure washer with suction? #26
the spray pattern never changed. Im going to try placing hose in 55 gal barrel and see what happens…..maybe this weekend if rain clears up. Always wondered.
I don't think mine "sucked". I filled up one of those plastic 20 gallon jugs, put in the faucet and hooked up the hose to the washer. It was up on our retaining wall so roughly 4 ft above the pressure washer.
/ Pressure washer with suction? #31
How long was your hose from the water source and how much of a drop?
Hose was 15 ft and the barrel was raised roughly 4 ft above the washer.
/ Pressure washer with suction? #33
I think it is correct to say that belt driven pump pressure washers are ok drawing from a zero pressure source. Belt driven pumps turn slower than direct drive pumps and are less likely to cavitate.
/ Pressure washer with suction? #35
Volume is key...1000 psi is plenty with a 5 gallon per minute pump....
Agreed. Excavator tracks tend to carry a fair amount of dirt and small rocks. It takes volume to wash that away.
Works pretty good. Not gonna remove paint but still knocks mud off
/ Pressure washer with suction? #38
Been my experience that the majority of PW pumps develop very little suction so I always have an inline mounted vane pump supplying the PW pump because I washdown all my equipment using a pair of 350 gallon IBC totes that collect the rainwater from my shop roof. If you use domestic cold water from a tap, you are supplying the artificial head pressure for the PW pump to work. I don't have that.
2022 Polaris 1000 Ranger (A64047)
2022 Polaris 1000...
2025 Intersate Fabrique 12' x 6' Dump Trailer (A62613)
2025 Intersate...
Case 586H 4wd Off road forklift (A63118)
Case 586H 4wd Off...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
