Pressure washer with suction?
/ Pressure washer with suction?
I got an 8 year old generac and this weekend I tried gravity feeding it. It actually worked quite well. PSI was down from hooking up to the house. I'd say it was running around 1500-1700 psi. Washed the wife's truck and went through about 12 gallons of water. Pump did start to heat up so it gives me an idea.
/ Pressure washer with suction? #22
I use 2 350 gallon IBC totes collecting rainwater to washdown my equipment and a 110 volt 'Pony Pump' to provide the head pressure. Never seen any PW pump that will suck for beans. I had Cats, AR's and presently a Karcher cold water machine. None of them sucked.
/ Pressure washer with suction? #23
I built about 10 of these for trucks, all suction. Why do mine work when others do not? These are positive displacement pumps.
/ Pressure washer with suction? #24
When i unhook hose from frostfree, i drop hose and use pressure washer until it stops spraying. This way i empty hose. No one is going to tell me it wont suck. Its an older honda powered pump.
/ Pressure washer with suction? #26
the spray pattern never changed. Im going to try placing hose in 55 gal barrel and see what happens…..maybe this weekend if rain clears up. Always wondered.
I don't think mine "sucked". I filled up one of those plastic 20 gallon jugs, put in the faucet and hooked up the hose to the washer. It was up on our retaining wall so roughly 4 ft above the pressure washer.
/ Pressure washer with suction? #31
How long was your hose from the water source and how much of a drop?
Hose was 15 ft and the barrel was raised roughly 4 ft above the washer.
/ Pressure washer with suction? #33
I think it is correct to say that belt driven pump pressure washers are ok drawing from a zero pressure source. Belt driven pumps turn slower than direct drive pumps and are less likely to cavitate.
/ Pressure washer with suction? #35
Volume is key...1000 psi is plenty with a 5 gallon per minute pump....
Agreed. Excavator tracks tend to carry a fair amount of dirt and small rocks. It takes volume to wash that away.
Works pretty good. Not gonna remove paint but still knocks mud off
/ Pressure washer with suction? #38
Been my experience that the majority of PW pumps develop very little suction so I always have an inline mounted vane pump supplying the PW pump because I washdown all my equipment using a pair of 350 gallon IBC totes that collect the rainwater from my shop roof. If you use domestic cold water from a tap, you are supplying the artificial head pressure for the PW pump to work. I don't have that.
2022 JCB Fastrac 4220 217HP 4WD Agricultural Tractor (A66734)
2022 JCB Fastrac...
2011 Mercedes-Benz C300 AWD Sedan (A66738)
2011 Mercedes-Benz...
PORTA POTTY (A68842)
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
2013 CHEVROLET CAPRICE POLICE CAR (A66091)
2013 CHEVROLET...
