Need a solution. Back problems and my Zero Turn.
/ Need a solution. Back problems and my Zero Turn. #41
It was really nice! If this seat modification doesn't suffice, it (the Titan) will probably be my next mower in the future.
Good to hear, thank you. I just put a 54" Titan in my garage last weekend. Now if it stops snowing, I might get to use it this spring. I didn't get the ability to test it over rough terrain, but it sure seemed like it should work well. I also didn't want to wait too long to pull the trigger, I'm not sure how long local availability would last.
/ Need a solution. Back problems and my Zero Turn. #43
Had to go through all the posts to see how many times Toro came up. A short drive on the dealer lot convinced me the Titan 60 with MyRide was the way to go. After a couple hrs on my old Deines Marty J, I could barely move. Now mowing is a breeze.
/ Need a solution. Back problems and my Zero Turn. #44
My solution was to install an air suspension seat with long suspension travel and adjustment up or down by changing air pressure
/ Need a solution. Back problems and my Zero Turn. #45
I have a fancy seat on my Kubota zero turn mower, it's nice and comfy. I don't have a fancy seat on my tractor though, and I don't feel the loss. The sort of jostling I get on my tractor in the field is a whole-body deal, more akin to riding a bucking bronco (not that I'd know what that's like). I also have a bad back, and after recovering from my last surgery the hardest thing to do was just to turn in the tractor seat so I could go backward and/or see what I was doing pulling rear implements. Maybe a rotating seat for that? Dunno. Anyway, just sharing FWIW, good luck. On the rear facing stuff, I suppose it's useful stretching for back recovery?
/ Need a solution. Back problems and my Zero Turn. #46
Where can i find that air suspension? Thx
/ Need a solution. Back problems and my Zero Turn. #47
It is a Grammer Air suspension seat that came as optional equipment on Kubota Tractors. It is available outside of Kubota. If you need the model number let me know?
/ Need a solution. Back problems and my Zero Turn. #48
I read the OP post, and got an idea of the topic of this thread, I acknowledge that I have not read the 5 pages that follow - my point being that there may already be solutions. (I'm a busy guy :) )
Anyway, I thought that there might be a way that a Fabricator could do something to the original ZTR to retro-fit one of the new suspension seats, or perhaps fabricate a seat base for any preferred seat.
I too have lower back / back issues, so I get it.
MGH-PA - do take care of your back. That is likely a longer term solution. All the best
2022 EZ-GO ELITE...
1/2" Quick Attach Blank Plate (A66408)
1/2" Quick Attach...
Skid Steer Rock Digger (A65640)
Skid Steer Rock...
2020 VOLVO EC200EL EXCAVATOR (A65053)
2020 VOLVO EC200EL...
John Deere 490E Excavator (A62679)
John Deere 490E...
2022 EZ-GO ELITE...
