Need a solution. Back problems and my Zero Turn.
/ Need a solution. Back problems and my Zero Turn. #1
MGH PA
Gold Member
Northcentral, PA
2005 Gravely 148Z 48" ZTR
So, I'm not old but any stretch of the imagination (37), I have had off and on lower back issues since I was in college due to lifting, but never too bad. I injured it this fall pretty bad and am still recovering/rehabbing. Not sure I will get to 100%, but I have improved. Anyways, my Gravely Promaster 148z is quite rough as most Zero Turns with no suspension are. I have a pretty rough 1.25 acres to mow, and I was hoping to add a suspension seat. However, the factory Gravely suspension seats aren't made for my model, and most of the suspension platforms I've found online aren't very close in bolt pattern.
Living on 25 acres (in the middle of my parents 200+), I have the need for a tractor, even though my dad has a JD990, and was considering just selling the ZTR for a B series to be a jack of all trades gap filler. Right now, my yard has a few spots that I won't take the ZTR, but a tractor is fine, so that would also be a plus. I think the BX will be too small (although probably the better mower), but before I go tractor shopping, I was wondering if anyone had a recommendation for a good aftermarket suspension seat? I've also toyed with selling the mower, and buying another one with a suspension seat and larger deck (one complaint I have with the 48" deck now is the lack of edging trim).
Thoughts?
/ Need a solution. Back problems and my Zero Turn. #2
Might not be enough, but have you ever replaced your seat frame bolts with these? I have lower back pain from battles at work and injuries. I’m pretty big, so the seat suspensions usually bottom out on me.
I put them under my seat in place of the rigid steel on steel mounts and it took a lot of the “shock” to my back away.
Here’s what it looks like done. Cost me about $50 in hardware and a couple hours total start to finish.
Only downside I see from it is you sit an inch higher, but as shot as my seat probably is, it’s not the same height as a new seat.
Been running this way for 2-3 years and I like it a lot. (y)
/ Need a solution. Back problems and my Zero Turn. #4
/ Need a solution. Back problems and my Zero Turn. #5
Look into lowering the air pressure in your tires. It won’t make a huge difference but every little bit helps. I suffer from back problems as well. I also would look into making an adapter plate for a suspension base or seat as mentioned already.
/ Need a solution. Back problems and my Zero Turn. #6
I found an old cloth with filling of some sort seat back cushion I use on my scag turf tiger that helps alot
/ Need a solution. Back problems and my Zero Turn. #7
I also have back issues. I spent $1200 to put a Grammer air ride seat on my Kubota MX5800. It required some modification but the time and $$ were well spent! It made a huge difference in my back pain and I figure it will eventually pay for itself in reduced trips to the chiropractor :)
/ Need a solution. Back problems and my Zero Turn. #8
Another thing to keep in mind is tire size. A larger diameter tire should also improve the ride. So when you mentioned the B vs the BX the B should ride better. I mowed my 2 acre yard for many years with an old Farmall Cub. I had replaced the old pan seat with a nice padded seat with armrests. Was much more comfortable to ride on than my Toro Z turn but the z turn is much faster. Don’t overlook the possibility of an older Ag tractor with capability to hang a mid mount mower.
/ Need a solution. Back problems and my Zero Turn. #9
I like this. I have used old dual coil tappet springs in a similar manner for suspension (not seats) in the past.
/ Need a solution. Back problems and my Zero Turn. #10
Lowering tire pressure is free and will make a difference. You can go lower than what the mower manufacturer says. Like if they call for 10 psi try 8. The drawback will be a slightly less even cut.
Another option would be to level the lawn or at least fill in the larger holes.
/ Need a solution. Back problems and my Zero Turn. #11
have you tried mowing with one of those/your weight lifting belts on? they make some nice velcro ones in different widths...don't know if this will help but might be worth a try
/ Need a solution. Back problems and my Zero Turn. #12
K&M seels self contained (12 volt compressor equipped air ride seat bases. If you have 12 volt starting you have a battery and hooking it up would be easy. Just purchase the base and attach your existing seat.
As for the tire pressure, I already run under the recommended. I have ever since I bought it to soften up the ride a bit.
I do have one (bought it right after this injury). I definitely plan to try it (I was actually on the mower today cleaning up leaves), but I just had an appendectomy 11 days ago, so I don't want to go putting pressure on my abdomen quite yet.
Thank you! They also have a regular suspension seat that fits my exact model, too.
/ Need a solution. Back problems and my Zero Turn. #17
Most all seat base mounts today conform to the ISO mounting spec so most all of them will be bolt on as the attachment holes / studs will line up just fine.
/ Need a solution. Back problems and my Zero Turn. #18
The air ride seat bases aren't cheap but neither are doctor's bills or pain meds. I also have the same issue as you do. getting old sucks and I really don't believe there is a ZTR made that rides halfway good. Not even the Ferris with the suspension rides very well. My buddy has one, he's hot overly impressed with it. Probably be adding the air ride seat base this year as well.
/ Need a solution. Back problems and my Zero Turn. #19
So do I. Like 6 pounds in each tire.
I run 8 psi in each tire and suspension seats
Ride is decent, but the wife and I have a habit of mowing at full sticks/full speed
/ Need a solution. Back problems and my Zero Turn. #20
okay this gets away from suspension modifications but believe it or not it this clam exercise has help my hip and lower back pain.
My daughter went to physio and they gave her this exercise.
I do twenty each side every day and it has been more effective then towels stuffed behind my back, rest, losing weight..... anyway worth a try, eh? I will be 66 in April the specialist wanted to fuse my back in three places in 1989, I am not blowing smoke, nobody knows back pain unless they have been there. Good luck!
2022 EZ-GO ELITE...
2012 Mitsubishi Fuso FEC52S Cab and Chassis Truck, VIN # JL6AMG1A0CK003828 (A65563)
2012 Mitsubishi...
TRAILER MOUNTED LIGHT PLANT WITH FUEL CELL (A65643)
TRAILER MOUNTED...
INDUSTRIAS AMERICA 2426 - 10' OFFSET DISC HARROW (A64277)
INDUSTRIAS AMERICA...
2007 FREIGHTLINER CL120 6x4 T/A DAY CAB TRUCK TRACTOR (A59914)
2007 FREIGHTLINER...
1997 Fontaine FTW-5-8048WSAW 48Ft 34 Ton Flatbed Trailer (A64194)
1997 Fontaine...
